BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Andream MMI Box - Wireless CarPlay & Android Auto
      08-04-2020, 11:33 AM   #3939
mako2388
Drives: X3 f25 2016
Originally Posted by cossie1 View Post
NO
If you do that, your unit will no longer accept the newer updates.
Which means if Andream / Carlinkit / Bimmertech / Roadtop etc stop doing updates for the older boxes, your newer unit will also no longer get any updates.
So it's not advised to flash the custom firmware for the newer B units?
      08-04-2020, 11:35 AM   #3940
bowen159
Drives: Mini
Hi,
Just wanted to what a great job you’ve done!
One thing I’ve noticed today after installing the custom firmware v2 to my Mini, the volume for the navigation is low. When I go to increase it when the Navigation is talking, it increases everything including the radio via the Tunein app. This then makes the radio too loud.
I’ve tried setting the volume to ‘Loud’ in Google Maps settings but is doesn’t appear to do anything.
Any ideas?
      08-04-2020, 11:39 AM   #3941
Glayham
Drives: BMW 435I M Sport
Gemini_pack_bin
This is a great thread. I've ended reading all the CarPlay stuff and gone and purchased and fitted a Road Top version of off Amazon. Very pleased!
Question: I've seen the firmware and MCU upgrades at the beginning of the thread. However none of them work for me.
I'ver used the RoadTop NBT versions below
v2.1.0.6.lt.b
MCU 20.06.02
I get the following message: no Gemini_pack_bin
Any ideas? thanks
      08-04-2020, 11:45 AM   #3942
chambo622
Drives: F31 328i M Sport EBII
v2.1.0.6.lt.b
MCU 20.06.02
Any ideas? thanks
Try reformatting the flash drive again with FAT32. I had this issue and the file name error was a red herring, it picked up the update files fine after doing this.
      08-04-2020, 11:49 AM   #3943
i3BEV
Drives: BMW i3
v2.1.0.6.lt.b
MCU 20.06.02
Any ideas? thanks
You have one of the newer "B" units like me. There's currently no compatible software.
      08-04-2020, 11:57 AM   #3944
mako2388
Drives: X3 f25 2016
Awww boooo I really wanted that widescreen layout!
      08-04-2020, 12:15 PM   #3945
muniz_ri
Drives: BMW 320I
I thought that I read last week or so that Andream started adding AA wide-screen support on their new units. Is that not the case?
      08-04-2020, 12:27 PM   #3946
mako2388
Drives: X3 f25 2016
I don't have the widescreen layout that is shown on page 1. I have an 8.8 in screen. My version is B_V1.0.0, it's possible the B_V1.0.2 has this, but the update didn't work for me. Not sure why but haven't investigated much yet.
      08-04-2020, 12:29 PM   #3947
cossie1
Drives: 2015 F82 M4
Yes the B_v1.0.2 has the widescreen in it, but no dpi fix.
      08-04-2020, 12:29 PM   #3948
Glayham
Aww thanks for that saves me trying any further.
I have though managed to update the MCU to 20.06.02
      08-04-2020, 12:55 PM   #3949
MrSeabass
Drives: BMW X3
Hey, I'm close to pulling the trigger on one of these MMI add-ons, and I've read through the thread quite a bit, but I want to make sure I've got all the answers I need before making my decision. Vehicle is a 2013 X3 F25 35i, manufacture date 04/2012 with 103K miles, CIC system 8.8", rear and side mirror cameras. MMI device I plan on ordering is a RoadTop model from Amazon, AA usage only.
1. Will there be any issue with the top/overhead parking view, or the side mirror cameras regardless? All documentation I've seen so far only mention front and rear cameras, but nothing about side mirror cameras.
2. Is the additional(?) USB female cable required for install? Can the USB port inside the center console be used for any and all MMI USB connection/functionality? Likewise, am I going to need to run a 3.5mm cable to the aux port in the center console?
3. Do I need to be concerned about any 'widescreen' issues, based on my 8.8" screen size?
4. Is there any additional storage provided by the MMI unit/impacting the CIC storage space? I am researching swapping out the HDD for a possible SD-to-IDE adapter upgrade or similar in the future.
5. *Purely an opinion*, but is there any incentive to spend the extra money on a complete touchscreen replacement android auto upgrade vs just the MMI addition? Is the software/hardware/support for one type of upgrade more stable than the other?
That's all I can think of for now, thanks!
      08-04-2020, 01:02 PM   #3950
mako2388
Drives: X3 f25 2016
Was able to update the to 1.0.2 with a different USB drive and got the MCU updated too. Still don't have the widescreen though
      08-04-2020, 01:15 PM   #3951
cossie1
Drives: 2015 F82 M4
Sorry my mistake.
It was v2.1.0.8.multiusb.gpe.b that they fixed it in not the B version
      08-04-2020, 01:35 PM   #3952
xDHC
Netherlands
94
Drives: F20 116i
Tested over the course of 1 hour today, 100% calls go over idrive now and not mmi on latest custom firmware on AA. I even see call history in idrive.
Do note, i use latest bimmertech mcu.
      08-04-2020, 01:41 PM   #3953
cerij101
Drives: BMW 520d F11
Originally Posted by bowen159 View Post
Hi,
Any ideas?
Think I may hold off updating if that's the case
      08-04-2020, 01:46 PM   #3954
muniz_ri
Drives: BMW 320I
My experience has been the same. Everything works great. I also love being able to use the phone button on the steering wheel and also the auto launch feature and having AA ready to go when I get into my car.
      08-04-2020, 01:51 PM   #3955
jjra
Drives: E90 > F48
Hi all,
Congratulation to people involved in the development of the new custom V2, wich is a fantastic job. It works fine, and now the auto day/night mode works again in AA, and of course, the new autostart AA feature is great.
mako2388 , I had issues with the new widescreen layout in a Samsung S8, I can't see it. The solution was the resolution of the phone screen, if it is set to 720 the old widescreen is shown, but if you select 1080 or more, the new widescreen layout appears. Check your phone resolution display if possible and try it.
      08-04-2020, 02:08 PM   #3956
mako2388
Drives: X3 f25 2016
Sorry my mistake.
Ah OK. I'm sure I'll get it eventually. I'm happy things are working, was having serious issues the first few days it was installed (cursor issues) but everything works now at least!
      08-04-2020, 02:17 PM   #3957
mako2388
Drives: X3 f25 2016
Originally Posted by jjra View Post
Hi all,
Ah I will give that a shot. I have a oneplus 7 pro which has like a "smart" setting where it switches the res by what you are doing. I can set it to high and see if that changes anything. Thanks for the suggestion!
      08-04-2020, 03:09 PM   #3958
cerij101
Is the OP7 Pro wired or wireless AA?
      08-04-2020, 03:46 PM   #3959
corduroy
Drives: '16 X5 xDrive40e (F15)
Wow, great work!
I can confirm that my phone calls don't go through the MMI. I'm using the Road Top (early) MMI for NBT with wireless AA. It will show that I'm on a phone call (as pictured) but it's not using bluetooth to control the call. BT doesn't show connected to the MMI.
edit: photos
      08-04-2020, 04:07 PM   #3960
Kyokushin
Kyokushin's Avatar
49
Drives: F32 428i, F32 420i
Can anyone play with Carplay and BT? Maybe there is also way to configure it with Apple to use BT for calls.
andream, android, android auto, apple, carplay, mmi, retrofit
