01-24-2022, 11:33 PM | #4973 |
Rep 48
8 Core Snapdragon 450 with MSM8953 Board
I have the 8 Core Snapdragon 450 with MSM8953 Board. Will these firmwares work on my unit. My GUI looks like the legit pictured.
Thanks in advance. |
01-25-2022, 01:42 AM | #4974 | |
Rep 1,048
So best is to show us a Image of your System Info Screen. The normal KSW-Q image won`t fit for sure, For KSW-Q-S (Sd425) i do have 1.6.0 at http://bit.ly/ota-share Kri |
01-25-2022, 10:02 AM | #4975 | |
Rep 48
01-25-2022, 10:49 AM | #4976 |
Rep 40
For me there's no such a hidden menu, I assume you mean not the "Factory" menu
01-25-2022, 12:52 PM | #4977 |
Rep 2,366
Drives: E63 645Ci
I didn't mean anything as the guide wasn't written by myself. The guide says to disable BT in Factory Settings (KSW/Chinese settings) first and then move to Android settings for next steps.
01-25-2022, 05:49 PM | #4978 | |
Rep 48
01-26-2022, 09:31 AM | #4980 | |
Rep 48
He Also told me it doesn't have wireless Android auto and one day it started working. I learned I had to unpair my cars Bluetooth to make the wireless AA to work. Thanks for all the help Kri! Last edited by R0N; 01-26-2022 at 07:10 PM.. Reason: added wireless |
Kri1083.50 |
01-26-2022, 10:21 AM | #4981 | |
Rep 1,048
but when i look at their website it seems they have some kind of mess with their product data and images Kri |
R0N18.00 |
01-26-2022, 02:37 PM | #4983 | |
Rep 31
Larger app tiles
<client>GS</client> Should I change that line to <client>ALS_6208</client>? |
01-27-2022, 03:24 AM | #4985 | |
Rep 1,048
Kri |
01-27-2022, 04:43 AM | #4986 |
Rep 31
01-27-2022, 04:50 AM | #4987 |
Rep 2,366
Drives: E63 645Ci
First post explains everything about factory_config.xlm and if you download one of these files it will have all options unlocked to so can copy that to your own file.
01-27-2022, 07:23 AM | #4988 |
Rep 31
01-28-2022, 06:16 AM | #4990 | |
Rep 40
1. Goto "Factory" settings by entering the password. 2. Uncheck the "BT" checkbox which is already checked (Your phone won't be paired anymore and can't make calls using the HU now) 3. Restart the HU 4. Right after restart, goto "Android Settings" and go to the Bluetooth section 5. There won't be any paired devices here if you haven't done this already. So use the "Search" option to search for "rec" 6. Click "File received by ...." in the search results and wait till the Bluetooth device appears. 7. When it does, click "pair device.." and pair the OBD adapter or any BT device as you would normally do on the phone. 8. Head back to the "Torque Pro" app and config the Bluetooth device there. 9. Viola, Torque, or any other app that uses Bluetooth will work, but you miss your phone calling feature. For me, it was not important anyway as I'm pared to my car's original Bluetooth for callings. |
01-29-2022, 03:53 AM | #4991 |
Rep 40
Headunit MCU Version: 615095dALS-C&C-KTL-DC-211208
Android Version installed: Android 10 System Memory config.: 4GB / 64GB Device tried to connect: ELM 327 OBD2 Adapter Bluetooth Connection successful: yes Comment: Wanted to connect my obd2 adapter to use the Torque Pro app, the device was paired successfully and I don't mind that the Bluetooth phone option is not working. |
01-29-2022, 08:00 AM | #4992 |
Rep 17
Hi all, i don't know if this problem reported previously, i've search the forum without luck. I have an andream split unit SD625 4gb 64gb updated to v3.0.8 since last summer. Before few days the screen start to show some blue and red horizontal lines and after few minutes went completely black. I still hear the music from the radio and can change stations (blind). It appear also that there 7s backlight on the screen. I can tell this because when is dark i can see the backlight on the screen. Does anybody experience this issue and is there any fix? I don't thing is a software problem. Btw, i disconnected everything and reconnect it back but still the same. Also, both sides are black (idrive and android). Any help from anybody?
Regards, George |
01-29-2022, 08:05 AM | #4993 | |
Rep 2,366
Drives: E63 645Ci
01-29-2022, 12:17 PM | #4994 |
Rep 17
This is what i was afraid of. I will try to reach the seller and ask . Thanks for the quick reply
