01-19-2022, 11:18 AM | #1 |
Rep 841
Homelink Garage Opener
Is there any way to “boost” the garage door signal from the Homelink?
I back out of the 2 car garage. The opener receiver is in the middle of the garage between the bays. I hit the button. The door closes…every time. I return and pull back into the same spot, hit the opener. Usually nothing happens, but sometimes it will open. If not, I press it again, maybe it opens and maybe not. It will work eventually. Three, four, maybe 5 presses. This has been going on a while, today it just frosted me. Any ideas? |
01-19-2022, 12:55 PM | #2 |
Rep 4,876
I don't believe so. How old is your opener? When we built our house in 2008, the Chamberlain opener that was installed by the builders just didn't work at our particular physical location (weird interference). They replaced it, and still no good. I could basically rub the bumper on the garage door, and it might not open.
About 6 years ago I bought a Chamberlain MyQ opener (wifi). That one is brilliant. I can now open the door from the end of the block. |
01-19-2022, 12:58 PM | #3 |
Rep 2,808
Drives: F33 430 and F39 M35i
Mine was having issues. It would work less than half the time. It was the logic board. Garage door opener is from 1998. Lol. Replaced the logic board solved it. I bought a myq add on last year. Never got around to installing it and it’s lost somewhere.
01-20-2022, 09:25 AM | #6 | |
Rep 47
Drives: 2017 BMW 340i, 6MT, RWD
What I believe the issue to be is a wireless dead spot. These occur with most wireless communications systems and can be caused by interference points or the natural amplitude nodes at various distances from a transmitter. There's likely no issue with your Homelink, but experiment with positioning and see if it solves your problem.
2017 340i, RWD, 6MT, MPPSK, LSD
Gone but not forgotten: 1999 328i (E46) |
01-20-2022, 09:29 AM | #7 | ||
Rep 785
335i rwd auto, 2015 with m performance LSD and Dinan stage 2. Cts charge pipe, mad 5" stepped intercooler.
01-20-2022, 01:06 PM | #8 |
Rep 562
Drives: 2017 BMW 330i xDrive
I have a similar issue and agree it must be positioning, but it could be my opener itself, too.
Coming home I can open that thing halfway down the block. Backing out of my driveway, I will sometimes have to get my front bumper inches away from the door before the stupid thing will close. I've even had to resort to throwing a backup handheld remote in the door pocket because it seems to prefer that one sometimes. I don't believe it's the car, it's possibly a dead spot like the above posters mentioned. But, I'm also convinced that garage door's sole purpose in existing is to piss me off, so that's a solid chance it's that, too.
2017 330i xDrive Imperial Blue Exterior / Venetian Beige Leather with Oyster Accent Interior / Anthracite Wood Trim |
Jvac432.00 |
01-20-2022, 11:04 PM | #9 |
Rep 58
Never mind the Homelink garage door opener, I used to have trouble with the garage door transmitters that came with the garage door opener. I tied a longer antenna to the receiver of the garage door opener and problem solved.
You could also try turning the antenna on the receiver 90 degrees from its current orientation. That might help it catch the signal from the transmitter across its length rather than down its length. |
01-21-2022, 11:09 AM | #10 |
Rep 1,560
As E30M CW said, work with the opener antenna first. Moving it around or maybe even adding more wire to it.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg 2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg. |
01-24-2022, 10:37 AM | #11 |
Rep 562
As an update on this, I fooled around with the antenna wire like the above posters suggested and it actually does seem to be working somewhat better now. Not 100%, but better. I just pointed the end of the wire towards the front of the house.
Very fortunate for it, because I was about one failure to shut away from taking it out back and setting it on fire.
01-25-2022, 08:27 AM | #12 |
Rep 4,876
For me, adding wire didn't help, it was area interference impacting the board in my door opener.
As a FYI, messing with the antenna length can have negative impacts to performance as well. The length is such to get a 1/4, 1/2 or full wavelength based on the openers frequency. Adding 3' of wire that is outside those optimal lengths can make it worse than no wire changes at all since you get out of those optimal ranges and start encountering signal cancellation from the reflections. |
02-05-2022, 02:31 PM | #13 |
Rep 841
Possible resolution.
Below there is a picture of the receiver from my 15 year old Casablanca ceiling fan. The receiver failed, I bought a new one and installed it, no issues there.
Notice the little “hook” shape at the end of the antenna wire. The “hook” shape has a plastic form around it to keep the shape, I’m sure it’s no accident. I put a similar shape at the end of the garage door antenna. It hasn’t failed to work yet. |
02-12-2022, 01:52 AM | #14 | |
Rep 1,386
I parked in the third spot outside my house yesterday and my 328d Homelink failed to open the garage door after multiple attempts. My ML will open the door from two houses away coming down the street, but as soon as I pass the main garage door it can get flakey. |
02-13-2022, 08:45 AM | #15 |
Rep 841
Not looking to argue or debate, I just thought it notable that the Casablanca fan folks actually had a part made to put the antenna in a shape and keep it that way.
I would also think (hope?) that anyone designing a remote garage door opener would realize the signal has to pass through the actual garage doors. |
02-13-2022, 03:39 PM | #16 |
Rep 4,876
I believe the actual reason is to insulate the end of the antenna wire so it doesn't short out on anything. Putting the heat shrink on the straight wire can get pulled off, doing the loop won't. The garage door antenna hangs in free space so there isn't the same concern.
