04-06-2021, 12:30 PM | #199 | |
Rep 3,860
Your audio system IS calibrated from factory specifically for your model, to give you the best (as in universal acoustic precision) performance whilst making inevitable compromises. You can play with the settings to see what sound YOU like the most, depending on the type of music and volume you typically listen to. Chances are you will deviate from the acoustic accuracy, but that does not matter as much as you subjectively enjoying the sound. It is not an exact science. I have boosted the low frequencies a bit as I enjoy hearing bass even at low volumes. Is this "improving" the sound? Technically not. But for my ears it is. And that's what counts. Good luck and enjoy! The HK is IMO a great system (as long as you have the correct expectations).
04-07-2021, 10:54 AM | #200 |
Rep 8
Ahh thanks for that. I did ready all of the posts but through ignorance skipped over the LCI reference, have since educated myself to understand what it means :-)
I will tinker - but also agree that for me the sound is great, certainly a real jump forward over the standard system in my last F10 5 series. |
11-13-2021, 04:55 AM | #201 | |
Rep 4
I've been using this setting for years and am so satisfied. Thank you. |
11-13-2021, 08:43 AM | #203 |
Rep 944
The point of the eq is to improve the linearity of the response, as standard (eq flat) the response is awful (Well it was in my '15 MY 435).
Read from the start and you'll see what its all about. PS. I see you have a G30. This thread is for the HK system in the F3x models. The OP had a F30, and it is based around his measurements. However it improves the F36 I have and others have tried it in the F31 and reported good results. |
12-07-2022, 01:59 PM | #205 | |
Rep 90
Drives: 435xi GC
https://www.harmankardon.com/bmw.html |
01-24-2023, 11:31 AM | #206 |
Rep 92
Thanks OP for the settings! I didn't pick up on the non-linearity but after trying out the settings, it's pretty evident that the HK system is trying to muddy up the base and get a boomy sound from the midrange at 200hz. On my 2012, the L7 sounds pretty distorted when using an iPhone with bluetooth. I like the cleaner sound with L7 off but I am not sure if the same EQ settings would apply. Does anyone know if these settings would still provide a linear response with L7 off?
02-02-2024, 07:29 PM | #207 | |
Rep 21
02-03-2024, 02:51 AM | #208 |
Rep 3,860
Yes - HK did when they performed a precise calibration of the sound specific to your vehicle type with professional equipment!!
Just to eventually read that people are asking for universally applicable to every type of music tips for how to go away from the calibrated sound before they have even bought the vehicle and heard the sound!! This is the moment I imagine when sound engineers start pulling hairs…..
02-03-2024, 08:28 AM | #209 | ||
Rep 16,054
Skyhigh1879.00 NealfromNZ520.50 |
