BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > N20 turbo oil feed pipe issue common?
      07-16-2016, 06:05 AM   #1
Twenty2Three
Drives: BMW 328i M Sport
Hello from across the pond...
in the UK 99% are diesel drivers so would not get a adult response from this enquiry
It appears I have a smokey start up and some digging on the net suggests its going to be the turbo oil feed pipe.
Is this a major issue, anyone had it replaced.
Car is under warranty so fingers crossed they will sort it FOC
      07-16-2016, 09:14 AM   #2
etinifni
etinifni's Avatar
Drives: 2012 328i Modern Line
Dealer replaced mine a few weeks ago and so far no more exhaust smoke after the car has been sitting. My SA told me if it does start smoking again the next step would be to replace turbo.
:wave:
      07-18-2016, 08:17 PM   #3
Gbm4th
Drives: 2021 BMW X3.0E
I also had my oil feed line replaced under warranty. Usually only happens when the car sits for over 12 hours and the oil accumulates.
After they fixed my oil feed line I had an engine fire; failure of the new oil feed line dripped oil onto the catalytic converter. Also fixed under warranty.
Now I have sludge in the engine and Vanos failures. I think it is time to look at something other than a BMW.
Good luck.
George
      07-19-2016, 07:46 AM   #4
jkwhar
Drives: F30 328i Xdrive | F15 x35i
Good luck.
George
How many miles do you have and what mile was the oil feed line was replaced?
n20, oil feed, turbo
