BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Why does 340xi 6spd get weaker MPPSK?
      01-22-2018, 03:50 PM   #1
GA/\/\/\/\A_CT
Drives: ‘20 m340ix
Hi,
I’m new to the forum and recently bought a 6spd 2016 340xi with track handling package. I’ve read that the MPPSK for a 6spd manual 340xi would only be about 25lbs of torque increase whereas the 8spd auto received 40+ from an otherwise identical kit.
Why does the 6spd get the watered down torque upgrade? Is it for reasons of Concern for clutch wear/failure? Is there a way to get the full strength MPPSK with a 6spd car?
Thoughts?
      01-22-2018, 11:05 PM   #2
goj
goj's Avatar
Drives: 2016 EBII 340i 6-MT
The transmission must have a lower torque rating
BMW CCA Member #516012
2016 340i, Estoril Blue, Manual Transmission, MPE, MPBBK, HRE FF04
Instagram: @brandons340i
      01-23-2018, 03:52 AM   #3
GA/\/\/\/\A_CT
Drives: ‘20 m340ix
I guess, but I’d really like to know if it’s the transmission or the clutch that is the weak link.
      01-23-2018, 06:07 AM   #4
jalkster
Drives: X3MC
Pretty sure its just the fact that you will be more inclined to wear the clutch faster with extra torque, and since its a fully warrantied package, they water it down a bit.
Current: 2021 M340i
Previous: 2020 X3M Comp BM3 E30 & 2016 340i 8AT DME Stage 2 | FBO/Catless Meisterschaft Catback | Ohlins R&T
      01-23-2018, 11:04 AM   #5
goj
goj's Avatar
Likely not a weak link but more a decision that will for sure not sacrifice the longevity of the clutch.
      01-23-2018, 11:21 AM   #6
xlover
Drives: 2023 X7 40i
like above, its probably for transmission/clutch longevity and reliability, if it makes you feel any better it was the same on the MPPK for the 335, less torque in the manual
      01-24-2018, 02:24 PM   #7
GA/\/\/\/\A_CT
Drives: ‘20 m340ix
Is there any way to get the full strength MPPSK with a manual? I’d sign a waiver on my clutch to get it.
      01-24-2018, 02:38 PM   #8
bimmer456
Drives: 340i
Get a JB4 tune. Or you might be able to convince someone to upload the 8AT firmware to your car and still be covered by warranty though clutch is wear and tear item, so you would just be replacing it more often unless you chose not to go all out very often and took it easy except for the occasional drag race against an MT firmware car.
      01-25-2018, 10:11 AM   #9
DrifterX
DrifterX's Avatar
Drives: 2016 340i M Sport 6MT+RWD
While I see how clutch longevity could be a reason, I don't think it'd be a big factor. I personally think it's to mitigate damage from human error (a bad/mistimed shift) which can potentially cause a ton of instantaneous stress on the transmission (i.e. applying too much breakaway torque)...
C'mon, we've all done it at least once before
2016 Estoril Blue II 340i M Sport | ///MPPSK | 6MT | RWD | Fully Loaded
BM3 Stage 2+ 93 | B58TU HPFP | VRSF v2 Catted Downpipe | 550i Clutch
      01-25-2018, 11:09 AM   #10
GA/\/\/\/\A_CT
Drives: ‘20 m340ix
Drifter, that could be...but then how do we explain the M3/m4 or m2 manuals not having less power than their DCT counterparts?
      01-25-2018, 11:22 AM   #11
paul e
Drives: 340i xDrive 6MT
Are they the same manuals in the M and the 340?
      01-25-2018, 10:37 PM   #12
G.Newt
Drives: CT4-V Blackwing 6MT
My understanding (could be wrong!) is that we have the same clutch/transmission since the E9x BMW's. The 550i/335is clutches are an OEM upgrade. More than likely, the M's have an upgraded or different clutch/tranny than we do.
2022 CT4-V Blackwing 6-speed
SOLD: 2016 340i xDrive 6-speed
DAW v2.5 turbo E40 | Dorch S2 | VRSF DP | MST intake | AWE catback | 335is clutch | CSF heat exchanger | RK Autowerks intake manifold | Orange M Perf Brake Kit | KW Street Comfort coilovers | GTS taillights V2
      01-25-2018, 11:59 PM   #13
eluded
2JZ-GTE
eluded's Avatar
Bulgaria
3038
Drives: 340 6MT, 50e, others
This
      01-26-2018, 01:12 PM   #14
kern417
Cheapskate
4447
Drives: 2018 440i |2016 340i | 2010 X5
Frankly, these are all just guesses. I've also heard the opposite in other applications, the assumption being that the auto needs more power to compensate for additional weight and driveline losses.
The answer is: we don't know.
Youtube/Instagram/TikTok: @kern417
      01-27-2018, 10:22 PM   #15
DrifterX
DrifterX's Avatar
The manual transmissions are designed to be able to handle the power those cars put out. M cars are more expensive for a reason
This.
All we can do is speculate.
kern4174446.50
      01-28-2018, 01:15 PM   #16
ivegotklas
Drives: 2017 M240i
Can't upload firmware for an AT on a manual. Complete different transmissions. How'd you expect that to work.
      09-20-2018, 06:31 AM   #17
GA/\/\/\/\A_CT
Drives: ‘20 m340ix
Bump
The most reasonable speculation I’ve heard lately is that the 340 manual tranny is not rated to handle as much power as the 8AT...thanks for skimping on the manual trannies BMW. Way to screw the purists!
      09-20-2018, 11:18 AM   #18
bimmer456
Drives: 340i
Get an aftermarket clutch and BMS tune.
      09-20-2018, 12:42 PM   #19
drunkenup
Drives: 2009 135i, 2021 F150
B58 manual box appears to be the same or evolution of the same GS6 45 that was in the E9x N55.
I know of several who have broken those gearboxes, lost synchros, lost gears with bigger turbos. I can't recall any failures on the GS6 53 on the older pre-2011 N54 cars and those cars often push more power. That is probably why BMW gimps the tune for the manual car.
MHD | BMS | VRSF | APEX | RECARO | TC Kline | BERK | Turner Motorsport | Eibach | BMW Performance
      09-20-2018, 03:03 PM   #20
bimmer456
Drives: 340i
It used to be that manual boxes could handle more torque now it's the auto. Though it seems torque converters are better than DCT.
      09-20-2018, 04:39 PM   #21
bimmer456
Drives: 340i
Swap a 6MT from an M3 should be able to handle 355 HP B58.
clutch, mppsk
