View Poll Results: Does your b58 consume coolant? | |||
Yes | 141 | 62.67% | |
No | 84 | 37.33% | |
Voters: 225. You may not vote on this poll |
12-30-2020, 04:24 AM | #243 | |
Rep 82
12-30-2020, 05:19 AM | #244 |
Rep 833
Drives: BMW F36, E36, E93
Not sure what age your car is (profile?) but BMW updatet their cap with a new number.
17117639020. Do you want to have a look if you still got the old one?
Such Fun
If you finde any spelling mistakes in my posts you may keep them, no return required |
01-08-2021, 02:02 AM | #246 | |
Rep 833
https://www.leebmann24.de/kuehlmitte...517643067.html They must be having a laugh? Will they take the engine out?
Such Fun
01-10-2021, 07:53 AM | #247 |
Rep 99
Dude the pump is under $200 bucks. Plus another $200 for labor at a BMW indie shop, $60 for coolant. Way cheaper and just saved yourself a ton of money.
01-10-2021, 08:04 AM | #248 | ||
Rep 271
Cleaned off all the white residue and applied some silicone grease to the threads. Cap now screws on and off easily and no coolant loss for over a year - 5k miles.
2017 F36 440 LCI - Smoked Topaz | Auto | M Sport Plus | HUD | ICON Adaptive Headlights
01-15-2021, 06:42 AM | #249 |
Rep 919
I'm 'sipping' very little coolant, but it is going somewhere. Not out the caps. Maybe an ounce every 1,000 miles. I'll get to looking better when it gets worse.
...and now I'm hearing b58s might be having oil pressure issues, though perhaps only in our tuned variants...idk. I'm keeping mine stock and praying!
02-12-2021, 05:38 PM | #250 |
Rep 28
I have a coolant issue as well. I had gotten the low coolant warning intermittantly every 6 months or so, for the last year. I just put more coolant in, fine. But this last month, I have gotten the warning 4 times. I always refill... comes back. The last little while I get a puddle under my car some mornings.
Took it to BMW. They pressure test. No issues they say. Send me the video of the inspection, say everything is dry. I see the white residue on parts under the car, but they wont listen to me. If the car leaks on heat soak after shut off... that would probably be cap related? I'm guessing? It's a weird issue no doubt.
2016 - 340i Msport, MPPSK, and track handling package
2004 E46M3 - BBS RGR, BMW Motorsport 3.91, Eibach Pro Street S Coilovers (500/600), GC plates, Swaintech coated SSV1 Headers/SS catted/resonated section 1, Karbonious CSL intake, Shrick 280/272 cams, CSL DME Conversion, TTFS tune |
02-12-2021, 06:38 PM | #251 |
Rep 833
If you've got to refill so often now, I would invest in a new lid
Such Fun
02-14-2021, 11:39 AM | #252 |
Rep 28
My car is under the full extended warranty. They can deal with it.
02-14-2021, 11:53 AM | #253 |
Rep 833
even better
Such Fun
03-20-2021, 12:21 PM | #254 |
Rep 1
I'm also having the coolant loss problem. Took a guess and replaced the main reservoir cap. That didn't help. Finally found that after the engine reaches operating temperature and while operating around 2500 rpm (in park) the coolant pump appears to be leaking. Ordered a new water pump last week. Hoping that once the old pump is off the failure mode will be obvious. What helped me get to this diagnosis was a very thorough investigation after driving the car and found some small pools of moisture on the plastic underbelly of the car.
BWbimmer276.50 |
03-20-2021, 12:36 PM | #255 |
Rep 833
Was your problem resolved?
Such Fun
03-26-2021, 09:28 AM | #257 |
Cheapskate
4447
Rep 4,993
My car is a 2018 and had some loss. Also the cause of leaks are pretty widespread, so it could be anything. It's not limited to a specific model year.
03-27-2021, 11:38 PM | #258 | |
Rep 139
03-29-2021, 11:15 AM | #259 |
Rep 562
Drives: 2017 BMW 330i xDrive
Want to add my experience here, hopefully it will help others...
I too, am experiencing coolant loss. 2017 (07/17 SA build) 330i xDrive. Bought in January with 28k miles, now at 34k (REALLY need to stop taking joyrides). At 31k, was having an issue that I thought had nothing to do with coolant. AC system was short cycling and therefore not working very well. After trying to figure it out myself (couldn't) I brought it to my dealer. They found the secondary coolant tank to be bone dry, the one for the AC and intercooler system. AC was short cycling to protect the engine and prevent overheating. No warning light, but it looks like the auxiliary tank does not have a sensor. Added coolant, pressure tested twice over two days, found no leaks and everying was working great again, so off home it goes. Now at 34k, I found my AC short cycling again. Popped the cap, and while not bone dry, it was low again. Added coolant and everything is fine again for the time being. I didn't have to add very much, maybe a cup tops. This thread has given a lot of helpful information, so I'm going to dig further into this on my own and post my results. I have not checked the main tank yet, or checked for evidence of coolant loss near the caps. Naturally, I spilled some filling it so I'm going to have to clean everything off and keep an eye on it. My guess is, at least in my case, that the cap(s) are the main culprit here. With the small amount lost, regular 3k top off intervals, and two negative pressure tests, it would make the most sense given the consistency and lack of worsening progression. I'm going to clean, inspect, and fully top off both tanks and caps. I'll monitor them, watch for any signs of leakage, replace one or both caps and return with my results. BTW, caps can be found for $10 each at RockAuto, so if this appears to be increasingly common, it would make a good first start to inexpensively try to correct the issue without a trip to the dealer. Unless of course, the caps themselves are just a defective design and regular top offs are going to become necessary. *EDIT* Sorry, didn't read closely enough...thread title clearly says B58 but my mind saw B48. I'll still follow up, might be useful information anyway. Last edited by auburnf30x; 03-29-2021 at 01:35 PM.. |
03-30-2021, 08:19 PM | #260 |
Rep 562
Ok, so a few things...
Part numbers for the coolant caps appear to fit virtually all BMWs made for several model years, regardless of the platform or engine involved. I’d be curious to know if other platforms have the same issue. I got a recent (last 1000 miles) oil analysis back from Blackstone, no antifreeze at all found in the oil. I can’t find anything directly saying so, but I’ve gotten the impression that these things are regular wear maintenance items and must be periodically replaced. Given that they are simple mechanical devices with rubber seals working under pressure it would make sense. Moving on to mine in particular, I found evidence that there is coolant escaping around the cap seals, from one side in particular. One side shows both the threads and cap have recent residue all the way down to the base. My main reservoir is full with no signs of recent leaking. Threads and cap are dry. It does, however, show the white dust that others have mentioned as a possible sign of past leaks, so I may replace it anyway. I’ll report back after I’ve had the new one on for a while to see how it improves. |
03-31-2021, 01:58 AM | #261 | |
Rep 833
Thanks
Such Fun
03-31-2021, 09:08 AM | #262 | |
Cheapskate
4447
Rep 4,993
04-04-2021, 03:40 PM | #263 |
Rep 131
I chased this issue around for a few months, today I discovered that my issue is a leaking water pump seal. So, anyone whose issue is not solved by cap replacement may want to check there.
04-04-2021, 03:54 PM | #264 |
Rep 10,256
How many miles are on your vehicle? Was the issue diagnosed by the dealer?
