12-06-2020, 09:50 PM | #9395 |
Rep 1,058
Installed my m3 inspired gloss black mirror caps and painted gloss black front lip I have had sitting around for around 3 months or so. Waiting for it to stop raining and I'll get better shots tomorrow evening or so. I really really really need to find a body shop/custom shop to open my passenger headlight to swap the lens. Wet sanding and polishing it does nothing -_-
MY13: TTE400 Stage 2 turbo, Spec Single Mass flywheel + Stage 3+ Clutch, FTP V2 Turbo Inlet, Evolution Racewerks Charge pipe + Boost pipe + Intercooler, Turbosmart Recirculating Diverter Valve, aFE grill scoop + aFE Magnum Force Cold Air Intake, B58 coil retrofit, eBay Downpipe, Active Autowerke muffler, DW400 LPFP, B58TU HPFP, M5 s63TU injectors, Bimmermilvs, e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block
MSCD3184.50 |
12-07-2020, 02:00 AM | #9396 | |
Rep 833
Drives: BMW F36, E36, E93
Is your car not lowered either? Just found your second post. Thanks
Such Fun
If you finde any spelling mistakes in my posts you may keep them, no return required |
12-07-2020, 03:21 AM | #9397 |
Rep 125
Not lowered. I might do it at a later stage. Will see how when I install the bodykit. Yes I have add on for the kit. Front and side CF lips.
12-09-2020, 08:39 AM | #9398 |
Rep 749
Drives: F31 320d xDrive M Sport
Fitted the winter wheels yesterday evening (haven't been driving much the last 2 weeks and the temperature was still above 10C when I was... finally got round to it now it's low single figures and below).
Fitted the wheel spacers too, 15mm rear, 12mm front. Got some 10mm and 5mm in the garage so can play around as I decide which works best. Didn't take any pics in the dark, but did get a few shots as I went out on the bike this morning.
haagm58809.50 |
12-09-2020, 11:29 AM | #9399 |
Rep 145
New spark plugs, air filter, cabin filter and wiper blades myself. All parts from FCP for right around $100.
Had a local shop change the oil, differential fluid and brake fluid. Also had the transmission pan done again for the second time in 6 months because of a hairline crack that apparently developed in the last new pan. The shop was great and warrantied their work, and I got 2 ZF fluid replacements and filters within 6 months. Should mean that a majority of the tranny fluid is now brand new. |
haagm58809.50 bissonettem7.50 |
12-10-2020, 11:27 AM | #9402 |
Rep 4,031
Given that I barely drive in the dark these days....I might try this!
2012 BMW 328i E93 | Deep Sea Blue Metallic - 2015 BMW 328i F31 MSport Sports Wagon | Alpine White - BMW CCA DelVal
aps335.50 |
12-10-2020, 12:57 PM | #9404 |
Rep 535
Finally got around to covering that creepy wood trim. I seriously considered some of the interesting textured film from 3M but figured since the car has carbon fiber accents on the side skirts and mirrors I might as well bring it into the interior.
12-10-2020, 07:11 PM | #9406 |
Rep 919
Drives: F30 328d Sport Line
Nice job! How did the wrap process go? Any major lessons learned?
12-10-2020, 08:05 PM | #9407 |
Rep 271
Test fit
erickonphoenix1722.00 jared21927168.00 |
12-11-2020, 09:01 AM | #9408 | |
Rep 535
I found the heat gun to cause more problems than it helps. The best strategy was just to slowly work the vinyl from the center of each piece out then work the edge to get any air bubbles out. Also take a pic of each piece before you wrap it. Although I was able to create each seam around the silver part of the trim there was a couple of instances when I wasn't exactly sure where to cut. I don't know why the DIY videos don't mention this but contrary to what you would think the four door handle trims are actually the most challenging to wrap. There's multiple curves that invite air bubbles to form when you try and get the edges down. I found each one took about 30 minutes of work to get clean but you won't want to do them back to back because your fingers will be wore out. I did two before I went to bed then the other two the next day over lunch. By the way, do browse the other designs in the Rvinyl catalog. I kind of went with the pedestrian carbon fiber but they had some cool modern woods and some cool metal designs. Quite an impressive inventory. good luck |
haagm58809.50 GaryBMW 20123.00 |
12-11-2020, 09:54 AM | #9409 | |
Rep 919
I did mine last winter and completely agree with you. The door handles were the most difficult pieces and yes, start with the center first...the heat gun is your friend but slow and low is the way to go (a little heat over a long period of time). |
erickonphoenix1722.00 GaryBMW 20123.00 |
12-11-2020, 11:36 AM | #9410 |
Rep 10
jb4 tune, charge pipe, down pipe, fmic, PS 1 turbo, afe intake, New HPFP and fuel injectors, shocks and springs and m perf brakes.
All on a 2012 335i N55 that BMW put a NEW engine in a year ago (or 15k miles)
BRAND NEW N55 engine put in 6/2018 (or 15k miles ago) on this 2012 335i: JB4; Momentum air intake; VSRF Catted DP; Turner FMIC; CTS chargepipe; M Performance Exhaust and Brakes and new OEM HPFP and fuel injectors.
haagm58809.50 |
12-11-2020, 02:36 PM | #9411 |
David
786
Rep 2,010
Car wash *yawn*
12-11-2020, 02:45 PM | #9413 |
David
786
Rep 2,010
Not a must, I personally like it, breaks up the white as well.
12-11-2020, 02:48 PM | #9414 |
Rep 535
12-11-2020, 02:50 PM | #9415 | |
David
786
Rep 2,010
What I'd never do is the full door protector. Those are hideous.
erickonphoenix1722.00 |
12-11-2020, 04:13 PM | #9416 |
Rep 749
Carpet on the wall... I did that in an old garage... drill a few holes in the brickwork, put some rawl plugs in, screw some carpet offcut to the walls. Doesn't look great but stops the damage.
