01-13-2021, 02:08 AM | #1 |
Rep 13
Rear ended in parking lot (F32)
Got rear ended by a Ford truck backing up with a giant tow hitch attached to it in a parking lot. Wanted to share the damage and cost of repair for science.
Total cost of repair: $3500 Parts (Repl= replaced, R&I=Remove/Repair and install) REAR BODY & FLOOR Rpr Rear body panel-CENTER UPPER R&I Rear body trim R&I RT Trunk side trim w/o navigation-SET BACK R&I LT Trunk side trim w/o navigation-SET BACK R&I Floor cover R&I Storage compart TRUNK LID Rpr Trunk lid-2 BODYLINES AND UNDERSIDE R&I W'strip on body-SET BACK Repl Opt OEM Nameplate "428i" Repl Opt OEM Emblem R&I License bracket R&I Trunk lid trim REAR LAMPS R&I RT Tail lamp R&I LT Tail lamp R&I RT Backup lamp R&I LT Backup lamp REAR BUMPER Repl Rear bumper Repl Opt OEM Bumper cover 428i, 430i w/o trim lines w/o prk sensr Repl Add for park sensor Repl Opt OEM Park sensor holder kit Repl Opt OEM Adhesive kit Repl Opt OEM Molding strip gloss black Repl Opt OEM Center support Repl Opt OEM LT Molding strip retainer Repl Opt OEM RT Molding strip retainer Repl Opt OEM Impact Repl Opt OEM Lower reinf Repl CORROSION PROTECTION |
01-13-2021, 05:29 AM | #2 |
Rep 408
Darn, sorry for your damage. Sounds about right on the quote. I'm dealing with a front left fender/bumper hit and Gieco is estimating $4600.00. Hang in there, it's amazing what good body shops can do.
01-13-2021, 10:36 AM | #4 | |
Rep 13
Sadly, there were no cameras and the other person is concocting a story....I have let my insurance provider know. Their insurance provider was a jerk and said it sounds like a 50/50 fault to him if there were no witnesses or cameras. |
01-13-2021, 12:57 PM | #5 |
Rep 234
I'm an estimator for a body shop and I would never write that trunk for repair. Once the metal stretches to a certain point it loses its integrity. If you have the means, remove the lining and check the back side of the repair area for exposed metal that will corrode, and take a small magnet to the outside of the repair area. If the magnet will not stick you know they just filled it with body filler.
j2dad5389372.00 |
01-13-2021, 03:03 PM | #6 | |
Rep 13
Didn't remove the liner yet to check underneath, but checked by sticking the magnet as you mentioned and it barely stuck where the dent was. Is using filler bad for these type of damages? |
01-13-2021, 03:23 PM | #7 |
Rep 833
Drives: BMW F36, E36, E93
I am surprised that is was actually worth to repair the trunk lid. It needed to be resprayed anyway. or not?
Such Fun
If you finde any spelling mistakes in my posts you may keep them, no return required |
01-13-2021, 03:59 PM | #8 |
No 55mph
1622
Rep 8,476
I would not accept that trunk lid being repaired either - in fact my insurance company (Nationwide) would never pay to repair a panel (unless it could be done by Dent Wizard)
I've been told numerous times by their adjusters that no shop wants to repair panels with filler & such anymore - they all want to simply replace the panel with new At the very least you should demand that they replace with a used trunk in perfect condition - esp. since they are gonna have to paint the entire trunk anyway...
01-13-2021, 05:01 PM | #9 | ||
Rep 234
01-14-2021, 11:10 AM | #10 |
Rep 2,432
Drives: 2021 M2C
Bummer! I hate a$$holes!
01-18-2021, 11:44 AM | #12 |
Rep 10,256
ViCosPhi, thanks for sharing. Could not agree more with earlier comments. The trunk ought to be replaced.
This is a good time to consider a dual channel dash cam with a dedicated battery for parking mode, such as Cellink NEO. More than worth it to eliminate unhelpful 'he said, she said, they said' dialogs. |
01-18-2021, 01:36 PM | #13 |
Rep 1,079
Sorry to know about this. Did the truck driver not see you back there? Some trucks around here are raised so high I would be surprised if they couldn't see a small car right behind them. Makes me want to install the Blackvue dual dash cam that I was thinking of selling, definitely need the battery pack to keep it running during parking.
01-19-2021, 10:02 PM | #15 | |||||
Rep 13
Thanks. Got the pics and gonna put it all in the file with all service documents. |
07-11-2021, 07:58 PM | #16 |
Rep 13
UPDATE:
Geico folks have been phenomenal in handling this case and they pursued this long enough to get a 50/50 judgment which softened the blow for me as half the cost was reimbursed by other party's insurance. |
natesi204.00 imperfectluck426.50 |
07-12-2021, 01:25 AM | #17 |
Rep 833
I'm sorry for you since I can't believe the truck driver could fabricate a story which makes you pay 50%?
Such Fun
07-12-2021, 07:19 PM | #18 |
Rep 13
07-13-2021, 07:44 AM | #19 |
Rep 833
Does this mean you weren't stationary in the parking lot? It happened on the road?
Such Fun
