05-31-2020, 05:22 PM | #1 |
Rep 638
Tire peeling? Is this normal?
Was just cleaning my car today for the first time this year and I noticed that the tire looks like it's peeling a bit around the wheel? Not sure if this is normal just wondering if anyone knew and could chime in. Thanks!
Current: 2022 M240i xDrive
Previous: 2018 440i xDrive, 2012 135i |
05-31-2020, 05:48 PM | #2 |
Rep 332
Do you have correct pressures? It looks like the rim protect is rubbing on the rim. Maybe you push it too much around the bends?
05-31-2020, 06:20 PM | #3 | |
Rep 638
05-31-2020, 06:22 PM | #4 | ||
Rep 332
Are these run flats? I personally think that for go flats you need to increase the pressure a bit, but that is just me. |
05-31-2020, 06:36 PM | #5 | |||
Rep 847
https://www.intercotire.com/using_ch...etermining_psi |
05-31-2020, 07:05 PM | #6 | |
Rep 209
Your life is a book and you are the author. Along the way there are fans, critics, editors etc that influence, change, refine and/or mess up your story. But at the end of the day, YOU are the writer and it is YOUR story.
06-01-2020, 09:21 AM | #7 | |||
Rep 638
Non run flat - Michelin A/S 3+
06-01-2020, 09:23 AM | #8 | ||||
Rep 332
Edit: I would be running the pressures a bit higher, but don't take my word for it |
06-01-2020, 09:31 AM | #9 | |||||
Rep 638
Just wondering if it's something I need to be concerned about?
06-01-2020, 09:39 AM | #10 |
Rep 1,560
I have seen some peeling in that area caused by the tire install. It shouldn't happen, but if that is what caused it, I don't think it should be a problem unless the bead didn't seal completely and the tire is leaking air. You could take it back to where you purchased it or a tire shop to be sure it isn't a problem. Random answers from the web won't necessary address your issue. I will just give you ideas about various things which may have caused your problem.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg 2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg. |
