01-21-2021, 03:31 PM | #1 |
Rep 1,134
Transmission Upgrade?
So my transmission died and now I have to either replace it or rebuild it. If I rebuild it can the clutch packs be upgraded? If I change it, is there a direct fit replacement that can handle more abuse? It’s a 340i so it’s a 8hp50
Thanks Last edited by msk340i; 01-21-2021 at 03:36 PM.. |
01-21-2021, 04:05 PM | #2 |
“M”ing
53
Rep 52
Damn sorry to hear that, HP70 is becoming a common and cost effective replacement, might be worth thinking about
01-21-2021, 04:05 PM | #3 |
Rep 1,134
01-21-2021, 04:19 PM | #4 |
Slow Poke
Rep 15
Do you know how it died? What stg XHP tune were you running and how much power were you putting down?
There's 2 details threads in this forum on swapping over the HP70, not a full direct fit - requires some modifications/different flywheel and some recoding of the ECUs but certainly do-able. |
01-21-2021, 04:23 PM | #5 | |
“M”ing
53
Rep 52
01-21-2021, 04:36 PM | #6 | |
Rep 1,134
01-21-2021, 05:29 PM | #7 |
Rep 3,368
These guys have been doing good work...it's not cheap though. Chris Miller on Facebook is contact
https://www.puredrivetrainsolutions.com/zf-8p |
01-21-2021, 05:37 PM | #8 | |
Rep 1,134
01-21-2021, 09:20 PM | #9 |
Rep 1,452
*$6,999 with their torque converter, which you probably want.
2022 CT4-V Blackwing 6-speed
dmanb2b2124.50 |
01-21-2021, 11:33 PM | #10 |
Rep 3,189
Check these guys out. I know it says Supra, but should be the same trans. Much more affordable
https://www.jackstransmissions.com/t...supra-services |
dbright0377.00 |
01-22-2021, 08:15 AM | #11 |
Rep 3,368
01-24-2021, 04:31 PM | #14 |
Rep 179
I sent an email to jacks transmissions to see if their rebuild is compatible. If it is I'm sure that will be because the clutch.packs are interchangeable. Ill update when I hear back from them.
01-25-2021, 10:57 AM | #15 |
Rep 1,134
01-25-2021, 11:03 AM | #16 |
Rep 1,134
01-25-2021, 11:12 AM | #17 |
Rep 3,189
01-25-2021, 11:24 AM | #18 | |
Rep 1,134
https://www.ebay.com/itm/8-Speed-Aut....m46890.l49292 https://www.ebay.com/itm/8-Speed-Aut....m46890.l49292 https://www.ebay.com/itm/8-Speed-Auo....m46890.l49292 |
01-25-2021, 06:19 PM | #20 | |
Rep 420
You need from N57. From diesel engine 3.0l. 330D, 335D, 430D, 435D, 530D, 535D. F body.
M140IX. Turbo Pure 800 Cast.
01-25-2021, 06:21 PM | #21 | |
Rep 420
