08-13-2020, 09:34 AM | #1 |
Rep 97
Coding MSport Brakes
Does anybody know how to code for MSport brakes in the rockville, MD area? Will compensate efforts with beer or money if that is preferred.
I'm about to swap my base brake setup for the 4pot front and 2pot rear MSport brembos and I feel like it's safer to code the car (abs/dsc settings, potentially proportioning?...). Thank you in advance! |
08-13-2020, 02:48 PM | #2 | |
Rep 479
OSUClevage51.00 BeFantastic12.50 |
08-13-2020, 11:18 PM | #3 | ||
Rep 97
08-14-2020, 12:18 AM | #5 |
Rep 479
*Post edited from original to clarify info better*
The only coding upgrade as far as I've read would be the Mperformance brake option (SPBR). This would be done when upgrading any of the calipers from Bosch to Brembos. I recently upgraded the rear calipers on my 335i from single piston Bosch to double piston Brembos. I also added stainless steel brake lines. Prior to coding, the brakes actually felt worse than the original set up. I thought there was air in the line, so I re bled them but had the same results. After coding, the pedal is much firmer and the car brakes more linear. Definitely less of a nose dive at higher speeds. I have not noticed a difference in the traction control system and have not had to activate ABS yet, so I cannot speak to that. The coding definitely increases line pressure and possibly the pressure bias as well. I'm sure it affects ABS and traction control too. This may be different on each model i.e. 328/330 to 335/340. It appears the 328/330 use a 340mm front rotor on the Msport kit where as the 335i/340i use a 370mm rotor on the Msport kit (same size as Mperformance). https://www.bimmerworld.com/About-Us...-Sport-Brakes/ |
learntocode53.50 BeFantastic12.50 |
09-11-2020, 11:24 AM | #6 |
a bit obsessed
70
Rep 85
A local option I know of is RVGParts. Ask for Valentin.
I found him when I looked for dealers on the xHP website. He is in Gaithersburg and does coding as well as the xHP trans flashes. I had a very positive experience and found him to be responsive, and ready to go at the time of the appointment. He is coding me for the M Performance brakes tomorrow. I’m strongly considering codemybimmer to add Sirius radio, and it does look like a great idea, but if you are looking for a local guy and are more intimidated by ENET cables than wrenches (like me), I would talk to Valentin. I don’t really care too much about coding aside from the brakes. |
