BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > PSA: Before you buy the GoFastBits DV+ diverter valve
      07-18-2018, 02:02 PM   #1
GatorF30
Drives: EBII F30
There hasn't been too much discussion on this topic, so I figured I would share my experience with the GoFastBits (GFB) DV+ diverter valve. It's a pretty popular upgrade on here carried by several site sponsors.
First, some background on me and my car. Some of you may know me as another name in another life (I was infamous on E46fanatics with my supercharged orient blue 330 and later my E30 Super ETA). I've been around the block a few times with BMWs. My current F30 is a 6MT that's FBO with an MHD Stage 2+ Tune, ER Catless Downpipe, eBay intercooler, Burger Tuning intake, Miami Performance charge pipes, and MPE.
After installing the GFB's DV+ diverter valve, I started experiencing compressor surge at partial throttle and during gear changes. Additionally, based on my logs, the car was cutting boost significantly from about 15-16 PSI to 6-7 PSI at WOT while rowing through the gears. It felt like the powerband hit a brick wall, but it was puzzling to me as every other parameter looked just fine on my logs and the car pulled strong when it wasn't WOT.
So I did some more research and remembered that when I had the DV+ installed, it was done with the optional main spring fitted. Basically what this spring does is hold boost longer and allows the diverter valve to open and close progressively based on how much boost is in the system. This allows for better throttle response because it's not releasing more pressure than needed in between openings.
My theory was since the stock diverter valve opens and closes fully regardless of boost levels, the ECU and its many boost fail-safes was triggering due to having more boost in the system than expected versus stock function. Thus the "overboost" issues presented.
So how to fix? Simply remove the main spring from the DV+ so it functions as what is essentially a stronger, better designed, stock diverter valve.
The spring in question is pictured here:
Since removing it, the car has had zero issues with overboosting and no more compressor surge. The drawback is that throttle response slightly suffers due to being reverted back to stock operation (yes, it's noticeable). While I cannot speak to this being an issue with any other tune, nor do I know if it's something that can be corrected via changes in the tune itself, but just sharing my experience in case anyone else is having a similar issue.
      07-18-2018, 02:23 PM   #2
enemigo13
Drives: F32 LCI 440xi citrineblack
ewg or pwg? overboost on gearshifts usually make hpfp pressure go down->ecu targets lower boost then. how was your rail pressure during gear changes?
      07-18-2018, 02:36 PM   #3
kern417
Cheapskate
4447
This is common across all platforms. I've seen people talking about compressor surge back to 2014 on volkswagen forums. It's the nature of the kit. If you're not letting all the air out, it'll be pushed backwards in the system. Most cars can compensate for it though.
I only upgraded on my volkswagen because the rubber diaphragm on the OEM valve was known to tear and fail. They later released an updated valve with no rubber. I haven't heard any issues with the BMW DVs though so I figure why bother.
      07-18-2018, 02:39 PM   #4
GatorF30
Drives: EBII F30
EWG
There was actually a spike in rail pressure.
https://datazap.me/u/kpeng/hot-clima...0&data=3-13-14
      07-18-2018, 02:40 PM   #5
GatorF30
Drives: EBII F30
MHD recommends using stock DV with their tunes and stock turbo.
      07-19-2018, 06:43 AM   #6
enjoythemusic
enjoythemusic's Avatar
364
Drives: 2014 BMW 435i Dinan Stage 4
Thanks for heads up! While no log here to say either way, the Dinan Stage 4 435i with 8AT feels fine and DV+ seems to be working in spec. Maybe it's a MT thing due to your car's MHD Stage 2+ Tune software for engine mgt?
Enjoy the Drive,
Steven
2014 435i M-Opt, M LSD, Dinan CAI/IC/BTurbo/Stage 4, ER TIC/CP, GFB DV+, Fabspeed HJS cat DP & Mich PS4S.
      07-19-2018, 07:13 AM   #7
kern417
Cheapskate
4447
...ok.
      07-19-2018, 11:36 AM   #8
JaredG_F30
JaredG_F30's Avatar
1106
This is good to know as I'm 6MT as well. I have the DV+ sitting on a shelf in my garage waiting to be installed. I'll probably just wait until the stock DV gives before making the switch.
SPI Films Blog/DIY Vids
      07-19-2018, 12:00 PM   #9
HKD126
Drives: 2014 335i, 2009 335xi
I just ordered the DV+ for my 2014 EWG 335i. BM3 custom stage 2 93 tune and will be installing a methanol injection kit and tuning for that. Boost doesn’t hold that well up top at 18lbs and drops a bit. I’ll be installing this to hopefully solve that.
      07-19-2018, 12:20 PM   #10
enemigo13
18psi up to redline with stock ewg turbo? it’s probably joke, right?
kern4174446.50
      07-19-2018, 02:14 PM   #11
HKD126
No joke.
      07-19-2018, 02:49 PM   #12
BMW DIY Guy
BMW DIY Guy's Avatar
Drives: 2019 M2 Competition
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
I have seen as high as 18.6psi on my stock turbo and my AA tune, along with all of the other supporting components. I have the DV+ installed including the main spring, and works beautifully thus far.
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy **
'Nimona' G87 M2 Build Thread
'Lillith' F87 M2 Competition Build Thread
1QuikWS61620.50
      07-19-2018, 02:54 PM   #13
GatorF30
Drives: EBII F30
Are you 6MT or 8AT?
      07-19-2018, 02:55 PM   #14
BMW DIY Guy
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
Are you 6MT or 8AT?
6MT... STICK LIFE.. *laugh*
      07-19-2018, 03:00 PM   #15
GatorF30
Drives: EBII F30
We are a dying breed, my friend.
      07-19-2018, 03:30 PM   #16
HKD126
My tune is a custom BM3 tune. Still in progress as well.
      07-20-2018, 11:51 AM   #17
enjoythemusic
364
Hmmm... great replied. Sounds like a tune problem.
Enjoy the Drive,
Steven
      07-21-2018, 09:37 AM   #18
enemigo13
seen as high or seen at 6500rpm? 18.6 psi is not a problem even with stock
pwg turbo but at 3000-3500rpm, and who needs there 18.6psi?
      04-13-2019, 10:55 AM   #19
johnung
I just ordered the DV+ for my 2014 EWG 335i. BM3 custom stage 2 93 tune and will be installing a methanol injection kit and tuning for that. Boost doesn't hold that well up top at 18lbs and drops a bit. I'll be installing this to hopefully solve that.
I'm curious how you made out with DV+ and meth installs? I'm about to go to BM3 St2 EWG 93 Octane tune. What did you customize on it? Thanks!
      10-17-2019, 12:29 PM   #20
tboudre
tboudre's Avatar
Drives: 2011 LeMans Blue 335xi E90 N55
I'm running a 2011 BMW 335i xDrive with 6-speed Automatic transmission. I'm having thermostat stuck problems so, I figured I'd replace thermostat, water pump. Figured I'd do the GFB DV+ upgrade while I was down there. Also had a few diverter stuck codes, so I ordered an new piedmont diverter valve as well as the GFB DV+. No turbo upgrades or downpipes, just the JB4.
My question: Spring or no spring?
Are the troubles only with manual transmissions? Any worries with stock turbos & the spring?
Thanks a bunch,
Troy
2011 335i xDrive ///M-Sport LeMans Blue Navigation iDrive 15% Tint N55 E90 - BMS Intake, Le Mans Blue Grilles, Le Mans Blue Rear Diffuser, Alpina B3 TCU Flash, Misc Coding, Matte Black Badge, Gloss Black Exhaust Tips, Blue Calipers*, VRSF Charge Pipe*, Cyba Scoops*, JB4, Sport Oil Cooler Valve, FlexFuel Wires, GoFastBits DV+ - Approx E30 fuel mix
* Painted 7251 Cobalt Blue Metallic - Matches LeMans Blue
      10-17-2019, 12:44 PM   #21
DreamerJoe
Drives: 2017 340i M.G. w red interior
Thanks a bunch,
Troy
I have had no issues, but I installed mine without the main spring. it said it would improve performance with the main soring installed, but might cause a CEL and that was a no go for me.
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
      10-18-2019, 08:01 AM   #22
zole2112
Modder of everything I own
zole2112's Avatar
147
Drives: 2013 335i Xdrive
Subscribing, I'll be installing my GFB sometime in early spring. Collecting as much info as possible, I was planning on installing the main spring, I figured go big or go home lol.
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
