05-21-2019, 08:00 PM | #529 |
A family of bimmers
2745
Rep 7,741
That looks great. Perfect fitment and finish on them. I almost went with those but didn't want to clean them.
06-19-2019, 09:26 PM | #532 |
Rep 381
Drives: 2018 340xi tanzanite blue
19's on a drive f30 with coilovers
9.5 et 40 can i fit 275/35 in the rears without rubbing? I'm at -1.2 camber back there. |
06-20-2019, 02:20 AM | #533 |
Rep 147
V710s in gunmetal with Hankook Ventus V12 Evo2
19x8.5 et35 - 245/35-19 19x9.5 et45 - 275/30-19 Lowered on KW V1s Next set of tires I'm going with 245/40-19 and 275/35-19 Michelin PS4s and raising the car a bit over 1/2 an inch. |
08-11-2019, 08:26 PM | #535 |
Rep 3,752
finally I got my wheels and can post here.
VMR v804 Gunmetal 19x8.5 +35 wrap with 245/35r19 indy 500 19x9.5 +45 wrap with 265/35r19 indy 500 stock m-sport suspension Still debating lowering it.
JUST an F36....extra door, slower than you
AWE Quad Exhaust, Bootmod3 VMR v804 GM 19" Staggered |
wdeerfield2745.00 Localmotion110.00 |
04-04-2020, 02:43 PM | #537 |
Rep 18
V801's in Hyper Silver
I had originally purchased a set of V710's in gunmetal from VMR. I quickly realized mounting them, that the wrong bolt pattern had be machined on the front wheels (I was informed that this does not happen very often last time being back in 2016). Long story short, with no more V710's in stock, VMR was kind enough to allow me to pick a different wheel in stock at a discounted rate. I went with the V801's in hyper silver and boy does it look great. I honestly like the look of the V801 on the F30 better than the V710 because of the sharp lines. The hyper silver really contrasts with the blue vs the gunmetal, as well. Shoutout to Justin at VMR for being awesome and making sure I was taken care of and in a timely manner. I am a happy customer!
Wheel and tire specs: Front - 19x8.5" ET35 245/35/19 Rear - 19x9.5" ET45 275/30/19 For those of you wondering what tires to throw on a wheel with those specs, I would recommend 10/10 to go with the 245 and 275 set up respectively. You will be happy you have a meatier tire. It fills the wheel well better and gives for an aggressive look from the rear; and the best part, NO RUBBING. Feel free to private message me if you would like pictures closer up to see fitment, tire height/stretch, etc. Last edited by It's Oz; 04-04-2020 at 03:21 PM.. |
wdeerfield2745.00 |
08-19-2020, 08:15 AM | #538 |
Rep 79
08-19-2020, 08:21 AM | #539 |
Rep 79
09-18-2020, 01:35 PM | #540 |
Rep 808
09-18-2020, 05:31 PM | #541 |
Rep 11
[QUOTE=Cstyles;15859702]I just installed the new VMR V810 flow-forged series, and my expectations are beyond exceeded!
I was originally looking at Forgestar but when VMR released their own flow-forged wheel, the CSL-esque design told me instantly this was the wheel I needed! Allen @ Simply Tire in Toronto hooked me up with pricing that was equal to buying out of the USA, so shopping local was a no-brainer. I could not be any happier with the wheel design and fitment, they just look to be about perfect for the F30 body lines. Thought I would start a thread where people can post their VMR setups as well. 2013 335i x-drive with DHP H&R Sport Springs (for x-drive) Continental ExtremeContact DW 19x8.5 +35 with 245/35/19 19x9.5 +40 with 275/30/19 (love the new look from the rear with these, very aggressive!) Absolutely positively no rubbing at all with the H&R sport springs. This is the perfect fitment for anyone looking to go wide without worrying about rubbing. You have x-drive and the difference in diameter of the front and the rear tire is 1.2% (recommendation for x-drive is to keep the difference as low as possible, in general below 1%). I'm curious how the car is reading that for you? i'm looking to get the same set-up but I'm worried about the 1.2% variance. |
11-03-2020, 06:57 PM | #542 |
Rep 49
I just got back from installing my VMR V804. They were about 10 pounds lighter than the OEM wheels. I can already feel a difference in acceleration.
wdeerfield2745.00 |
04-17-2021, 07:36 PM | #543 |
Rep 33
Picked these up in November and finally came around to throwing them on!
Bringing this thread back from the dead! (Drop is H&R Sports) V804 19x8.5 et35 19x9.5 et45 Tires: Continental ExtremeContact DWS 06Plus 235/40R19 265/35R19 VMR Weight W/ Tires F:45.2lbs R:47.2lbbs OEM 403m Weight W/Tires F: 52.5lbs R: 53.8lbs |
alohasurftoad3067.50 Sonic440i36.50 |
04-18-2021, 09:44 PM | #544 | |
Rep 53
04-18-2021, 10:16 PM | #545 |
Rep 10,249
Very sharp appearance. Great choice!
04-19-2021, 02:12 PM | #546 | |
Rep 33
Tails can be found on aliexpress or https://www.kiesmotorsports.com/prod...le-tail-lights |
06-11-2021, 12:02 PM | #547 |
Rep 28
VMR V710 gunmetal
Front: 19 x 8.5 +35 on 225/40/19 Michelin PS4S Rear: 19 x 9.5 +45 on 255/35/19 Michelin PS4S Stock M adaptive suspension for xDrive Now I need my damn Eibach springs to come in already |
Desertnate390.50 Dimi_M11.00 |
06-16-2021, 09:24 AM | #548 |
Rep 133
So I'm absolutely obsessed with the stance of OP's car. I ADORE that big, fat, nasty looking squat.
I'm looking at buying some Enkei RAIJIN-19's from TireRack but am a complete wheel and tire noob. Are the width / offsets of wheels universal? I.E., OPs specs are below: 19x8.5 +35 with 245/35/19 19x9.5 +40 with 275/30/19 If I buy Enkei's with the exact same size and offset, am I going to be able to fit those same tires on there too? Or do different brands / wheels fit a little bit differently? TireRack lets me equip 'em to my car, so I suppose they are guaranteeing they fit, but I just wanna be sure I'm going to have that super wide look if I do pull the trigger. EDIT: Holy SMOKES, then I saw the car literally right above this and now I NEED some VMR710s. So I've got a 440I GC with M-Sport suspension. Any reason I won't be able to run the above set-up? I've seen some users going with a +45 offset on the rear, as I understand it a higher offset will pull the wheel further into the wheelwell correct? So +40 is more aggressive than +45? Last edited by culpability; 06-16-2021 at 09:49 AM.. |
06-16-2021, 09:52 AM | #549 |
OHIO STATE
643
Rep 693
Drives: 2021 BMW M340i
Hello! Can you provide the specs on the wheels and tires please?
Present: 2021 BMW M340i Mineral White
Past: 2018 BMW X5 Mineral White, 2018 BMW 340i Alpine White, 2016 BMW F15 X5 xDrive / Glacier Silver, 2011 BMW 335xi / Alpine White, 2008 BMW 135i Sedona Red |
