Login
06-21-2020, 12:47 PM | #155 |
![]() ![]() 95
Rep 322
almost OT
Did 200+ miles MA-CT-NY-NJ on Saturday and I got a very nice 33.6mpg for a 240ix Convertible MHD Stage 3 on 93 with the top up but AC on |
06-21-2020, 02:12 PM | #156 |
![]() ![]() 104
Rep 120
Almost any tune is focused on WOT engine operation leaving light and medium loads barely touched. You should thank BMW for that MPG in the first place, not the tune.
06-23-2020, 11:49 AM | #157 |
![]() 3
Rep 55
Went to Stage 2 OTS with their new app. Using the wifi dongle, the OTS tune took around 2 minutes. I had issues with the license input on the app since they no longer have a store inside the app. I'm struggling to know if the tune even stuck. I don't see it anywhere in the app, but is there a way to see which tune you have installed?
06-23-2020, 12:01 PM | #158 | |
![]() ![]() ![]() ![]() 147
Rep 458
Go to Codes > Read DME Codes
It will show which tune is installed in your car. Quote:
2018 340i LCI - MPPSK Catless AT RWD - M Sport - Shadow Edition
MPPSK - Self Tune - Pure Boost Custom Tune - MHD Stage 1 - MHD Stage 2 Fuel: 92 RON - 88 OCT |
08-20-2020, 08:35 AM | #159 |
![]() ![]() ![]() ![]() ![]() 34
Rep 777
So how acurate are the updated HP and torque graph after the remap?
I'm on stage 1 93aki and notice that the needle can go up to ~300kw and ~600nm under WOT.
2016 BMW F36 440i GC M Sport
2018 Audi FY Audi SQ5 2020 BMW G07 X7 3.0d M Sport |
08-20-2020, 11:10 PM | #160 | |
![]() ![]() ![]() ![]() ![]() 472
Rep 655
Drives: Your mom crazy
2016 340i xDrive M-Sport MPPSK
Pure800; Dorch Stg2 hpfp; VRSF DP; AP intake MHD; Wedge Performance E50 tune; xHP Stage 3 Forgestar wheels & KW coilovers 10.45 1/4; 2.75 0-60mph |
11-22-2020, 12:30 AM | #161 |
![]() 5
Rep 15
What would you recommend on a high-flow cat? I assume hard is too much for the cats, but medium might be somewhat acceptable?
2018 BMW 340i GT | BMS Intake | Autowerke Catted DP | MHD E30 Mix Stage 2 Tune
11-24-2020, 05:45 AM | #162 |
![]() 1762
Rep 1,248
Posts ![]() |
MHD BLACK FRIDAY SALE 2020
15% off on all MHD tunes / licenses from our Webshop. Visit: https://mhdtuning.com/collections |
11-24-2020, 09:07 AM | #163 | |
Rep 400
![]() Quote:
I'm planning to do MHD & xHP to take advantage of the synergies in settings and wifi adapter. Anyone know if xHP does Black Friday sales? I can't find anything online.
My 2017 M240i: MHD, xHP, Modded OE Intake, CTS Turbo 200 CPSI Cat DP, Dinan Mid-pipe, M Performance LSD & Rear Diffuser, BMS Exhaust Tips, Apex EC-7 Wheels, M-Tech Front Lip, iND Painted Mirror Caps, Smoked Reflectors
11-24-2020, 01:39 PM | #164 | ||
![]() ![]() ![]() ![]() 61
Rep 964
11-25-2020, 12:45 PM | #165 |
![]() 146
Rep 184
Today i had a dyno session at pureturbo's belgium to log all the OTS maps (stg0 till stg2hpfp ) in mhd . all runs were done on E30 , numbers are in whp . Stock turbo
M140i DP , OPF delete , MHD stg2 93oct , xhp stg3
11-25-2020, 09:18 PM | #166 |
![]() ![]() ![]() ![]() 53
Rep 716
11-26-2020, 03:13 AM | #168 |
Rep 458
Just to confirm all runs were done using E30 maps running on E30 fuel ? not 93 maps running on E30 fuel ?
Thanks for sharing very impressive numbers.
11-26-2020, 02:22 PM | #170 |
Rep 400
I have the OE cat and intake. Before I flashed MHD, I did a code read. There were no codes and all the readiness monitors were 'complete'.
ECU status: - - Readiness - Misfire: Complete. Fuel System: Complete. Components: Complete. Catalyst: Complete. Heated Catalyst: Not avail. Evaporative System: Complete. Secondary Air System: Not avail. A/C Refrigerant: Not avail. Oxygen Sensor: Complete. Oxygen Sensor Heater: Complete. EGR System: Complete. Then, I flashed MHD stage 1 93 Oct map, waited 30 seconds, started the engine, let it complete the cold start procedure, turned off the engine and then read the codes. Now, many of the readiness monitors are 'incomplete'. ECU status: - - Readiness - Misfire: Complete. Fuel System: INCOMPLETE. Components: Complete. Catalyst: INCOMPLETE. Heated Catalyst: Not avail. Evaporative System: INCOMPLETE. Secondary Air System: Not avail. A/C Refrigerant: Not avail. Oxygen Sensor: INCOMPLETE. Oxygen Sensor Heater: INCOMPLETE. EGR System: INCOMPLETE. Is this expected/normal?
11-27-2020, 03:57 AM | #172 | |
![]() 10
Rep 31
![]() Quote:
Could I only purchase the "MHD Flasher License" without any maps? Last edited by blvvet; 11-27-2020 at 04:11 AM.. |
11-27-2020, 08:14 AM | #173 |
![]() 1762
Rep 1,248
Posts ![]() |
11-27-2020, 09:14 AM | #174 |
![]() 10
Rep 31
12-01-2020, 08:32 AM | #175 |
![]() 1762
Rep 1,248
Posts ![]() |
No sir you cant run a EU map on a USA car. It's always the right map for your car based on the factory reading.
12-03-2020, 05:46 PM | #176 |
![]() ![]() 28
Rep 275
i have the same cat and would like to know as well
2020 M240i Coupe RWD (ZF8) - AP Intake - AA Catted Downpipe - Remus Non-Resonated Catback Exhaust - xHP ST3 - Dinan Springs and Bumpstops - BMS 12mm Front and 15mm Rear Spacers - GazP Side Skirts and Rear Extensions - 20% Window Tint - Carbon Fiber Mirror Caps and Eyelids - IND Painted Reflectors
