06-19-2020, 12:29 PM | #309 |
Rep 814
Drives: 2021 BMW X3 M
I decided to pull the trigger on this setup after surfing through this thread. I tried to get a couple of pictures from different angles.
Estroil Blue F30 x OEM 437m Wheels x H&R Sport Springs. Tire Sizes: 245/35/19 Fronts and 265/35/19 Rears wrapped in brand new Firestone Firehawk Indy 500's. Alignment: -0.5 degrees of camber up front and -1.5 degrees in the rear. (Within factory specs) I know I asked about running 245/40 but I wasn't sure if it would rub. If I had to do it again I would definitely put a 245/40 on the front. It would fill in the small gap up front and I am sure it would clear with this drop. The rear is filled in perfectly.
2014 BMW 335i M-Sport - SOLD
2020 BMW M340i - SOLD 2021 BMW X3M |
jcarv2033.00 |
06-19-2020, 02:03 PM | #310 |
Rep 814
For sure next time around I will get the 245/40 and report back.
09-05-2020, 03:18 PM | #311 | |
Rep 11
I have some Vorsteiner V-FF 112s (19x8.5" ET30 front 19x10" ET45) coming in Wednesday and I want to order some Michelin PS4S tires. I am trying to go 245/40/19 front and 275/35/19 rear. I am honestly only worried about the fronts rubbing but I hear depending on the tire, there might be enough clearance. I am running on the Stock M Adaptive Suspension, my car is a 440i XDrive Coupe with MSport, Track Handling, and MPPSK. |
09-05-2020, 11:05 PM | #312 | |
Rep 11
https://imgur.com/gallery/Zp4r8Ar But basically, this is me running 225/40/19s in the front. I was wondering about the guy who had rubbing on his F30. I see he isn't using the Michelin Pilot Sport 4S tires, I picked the sizes mentioned above because the tread width is just short of the actual rims. Tires from differing manufacturers may have the same tire size but they can be spec'd quite differently. So in the case of the PS4S 245/40/19, it has a tread width of 8.4" vs the actual 8.5" rims. And for the PS4S 275/35/19, it has a tread width of 9.8" vs the 10" rims on the rear. IMO, tread width matching the actual rims is much more important than going with "the widest rubber you can fit" and this is mainly for handling purposes. I always have the option to downsize to 35/30 vs 40/35 however, I would like the higher sidewall considering I live in the NY area where potholes are quite plentiful. I am sick and tired of playing hide and seek with potholes in Manhattan and my Bridgestone Potenza S001 run flat tires are ridiculously harsh despite having the adaptive M suspension (less harsh than having plain old M suspension). Another reason is, unfortunately I can't find the link but someone mentioned on these forums that he wished he went with 40/35 sidewalls compared to 35/30 because it would have "filled in the gap". I go on quite a few spirited drives when I go around the twisty roads in the Poconos so I really do not want to deal with rubbing at all. Anyone with a F32 + Michelin PS4S tires who can give me some advice? |
09-06-2020, 12:16 PM | #313 | |
Rep 9
09-06-2020, 04:32 PM | #314 |
Rep 11
Here is a much better picture of the vents for the brakes.
For those with Track Handling Package F32s, I don't think messing with this is a good idea. You can still roll your fenders however. Last edited by itwasluck; 09-06-2020 at 04:40 PM.. |
09-06-2020, 04:35 PM | #315 |
Rep 11
I hear you are running 245/40/19s in the front. I was wondering if this is still possible to run with the stock M Adaptive Suspension (without any rubbing). I understand you are on lowering springs. Please correct me if I'm wrong.
09-06-2020, 06:12 PM | #316 |
Rep 814
I ended up doing 245/35/19 because I couldn't get anyone at all to confirm if 245/40 would fit. But I have thicker tire. It has not rubbed at all. On stock suspension, you can definitely pull off 245/40.
09-07-2020, 11:03 AM | #317 | |
Rep 11
Honestly, I think I'll just order the Michelin PS4S tires today (245/40/19 front 275/35/19 rear). If it fits, great. If not, I'll just return it and go with 35/30 side walls. Thank you for the quick response and for the reassurance that I needed. On Stock M Adaptive Suspension, I hope these clear. I'll definitely post an update after I get the tires/wheels fitted for those wanting to do a similar setup. I know most people run the usual 235/35/19 f 265/30/19 r. But depending on the tire manufacturer, you want to match up the tread width to the rim width as much as possible. Never go above, try to be within 0.5" and you will have superior handling to other setups who simply fit the fattest tires they can (which they boast about but in the end it leads to no increase in handling and/or performance). For people living in the NY area, trust me, your gonna want to go with the biggest side wall possible. You (and your back) will thank me later. |
09-07-2020, 12:02 PM | #318 | |
Rep 814
09-07-2020, 09:22 PM | #319 | |
Rep 11
09-11-2020, 01:51 AM | #320 |
Rep 20
My turn F32 435i oem 437m19'' Ferric grey
Front 19x9 pirelli pzero 235/40r19 Rear 10x10 michelin super sport 255/35r19 442m vs 437m Last edited by kenshirosan; 09-11-2020 at 01:57 AM.. |
09-11-2020, 08:56 AM | #321 |
Rep 963
Couple more pics of the 285/30 tires on the rear. I think I have room to lower the rear even further if I wanted to and I would probably still not rub.
2018 Azurite Black F80 M3 ZCP
2019 Phytonic Blue G05 X5 2013 Glacier Silver F30 335i (sold) |
alohasurftoad3069.00 DLag30103.50 |
09-15-2020, 11:04 PM | #322 |
Rep 62
Just got my v1’s today
KWV1’s, Remus sport exhaust, VSRF hi-flow cat, TIC & Charge pipes, 5” stepped intercooler; turbosmart BOV,MST V2 inlet, MHD Stage 2, oem m437 wheels, m performance alcantara steering wheel.
omeroon0.00 |
09-16-2020, 07:30 AM | #323 | |
Rep 611
09-20-2020, 07:02 PM | #324 |
Rep 1,105
Pulled the trigger this weekend and purchased a used set of OEM 437m. They have the stock Michelin pilot super sports 255/35 in front and 275/35 in the rear. Still have not added them to my RWD 435i. I've only found out about some poke that occurs with these rims after purchase lol.
From all the research I've done all this weekend it seems most people are lowered and worry about rub. I will not be lowering my car because I feel it's low enough as is. But wondering what tire size will reduce poke. 245/40 fronts and 265/35 rears? Or 245/35 fronts and 265/35 rears?? Anyone that is not lowered and running these wheels, preferably another 4 series non gran coupe owners please chime in!!! Thanks in advanced |
10-02-2020, 03:49 AM | #325 |
Rep 11
Update
F32 440i XDrive with MSport/Track Handling Package/MPPSK Stock ride height with M Adaptive Suspension Front 19x8.5 ET30 245/40R19 Rear 19x10 ET45 275/35R19 Michelin Pilot Sport 4S Vorsteiner V-FF 112s No rubbing at all but extremely tight in the rear to the point where a tire from a different manufacturer (but same size) might have rubbing issues. |
10-02-2020, 09:02 AM | #326 | |
Rep 28
10-17-2020, 12:05 AM | #327 |
Rep 10
Finally got through the whole thread, but not sure if I have the right answer still. Have a set of OEM 437M's heading my way and drive a 2015 435i GC M Sport. Not lowered and not planning to do so. The consensus seems to be 235/40/19 and 265/35/19 may be best for my situation?
11-06-2020, 08:42 PM | #328 | |
Rep 499
Drives: F36 440i
11-15-2020, 01:11 AM | #329 |
Rep 71
Drives: (sold)335iS, 440ix Gran Coupe
These pics are really convincing. Might have to jump on the bandwagon!!
11-18-2020, 09:09 AM | #330 |
Rep 3
Your car looks great! How much camber are you running on the front and back?
