BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > ☛☛ MHD Flasher F+G Series B58 - OFFICIAL RELEASE ☚☚
      06-21-2019, 02:56 AM   #67
azzetz4life
Drives: BMW 535i 340i
just flashed to stage 1 (18 340i 6MT)
anyone else's running this had a few questions to bounce off a MT
1-2 feels bad ass but 3-4 seems to have a stutter mid way through gear...
      06-25-2019, 09:06 AM   #68
azzetz4life
so when did the latest update go live?
since i've only been flashed for less than a week.
      06-25-2019, 09:33 AM   #69
MHD Tuning
MHD Tuning's Avatar
Drives: M3F80#M5F90#340iF31#SupraA90
♦ MHD Flasher F+G-Series 1.31 UPDATE ♦
B58 specific update:
- We added a transmission choice menu for OTS maps. The DME can report an unscaled torque to the AT transmissions that have been flashed with xHP for improved transmissions operations.
- A particle filter delete flash options was added to make full power and no CEL if you remove the particle filter.
- Some minor bugs were corrected in the OTS maps, that were causing shadow codes.
      06-28-2019, 10:50 AM   #70
Seattle335
Drives: 2015 M4
2007 335i  [0.00]
2005 SL 55 AMg  [0.00]
2007 Porsche 997 Turbo  [0.00]
Hi - I have a few q's - I have the MPPSK tune on my 340, is that version saved if I have to revert to 'stock'?
I have a '17 340 M-Sport, with track handling - do I need an upgraded IC for Stg 2?
Also, is there any iOS support, or do I have buy an Android device?
2018 R8 V10 - Ara Blue/Gray
2019 M2 Comp - HS/Black/Orange
2017 340iX - GS/Black
2003 M5 (56k miles) - CB/Black
      06-29-2019, 05:33 AM   #71
azzetz4life
your mppsk tune is supposed to be saved in ur stage 0 file from my understanding but i myself have not down graded since i went up to stage 1.
no ios 😐.
you will need a android device / a proper k+dcan cable /and a ots usb c adapter.
worth it tho, your car will be noticeably stronger. even off stage 1
stage 2 i think just "requires" A downpipe.
      08-01-2019, 05:56 PM   #72
MyNameIsNotSure
Drives: 2018 M3 ZCP
I have a 2016 340i, just wondering how do these maps operate in regards to throttle response? I've read (and noticed) the throttle response in comfort and dsc-off is pretty linear, which I prefer over the frontloaded throttle in sport+. Will adding this tune keep the throttle characteristics the same throughout the drive modes?
      08-01-2019, 10:37 PM   #73
F3085258
Drives: 2016 X5M
I have MHD stage 2 and the throttle maps seem the same. I also prefer comfort throttle mapping.
      08-10-2019, 05:46 PM   #74
neonnblack
Drives: 335i 6MT/e46 330xi
looking for some insight on two logs i ran after flashing stage 2. Car has intake and downpipe. stock otherwise.
I'm not used to b58 tuning(compared to n55) so this may be normal. Seems wgdc is way too high, egt was huge, and timing correction seems to be higher than it should be. And the logger showed i had a random spike to 30+psi at the end. The car drove and felt good otherwise. Both were done with traction control off, trans in sport manual one in 3rd and one in 4th.
https://datazap.me/u/neonnblack/new-...og=0&data=3-19
https://datazap.me/u/neonnblack/log-...0&data=3-10-19
edit: the car got a cel for a super knock. among other things. cleared it and all is fine so far. i can't see this being anything but bad fuel?
      08-11-2019, 03:03 AM   #75
enemigo13
Drives: F30 340xi
seems you're at altitude and ambient temperature is quite high. your timing sucks also.
      08-11-2019, 10:08 AM   #76
neonnblack
https://datazap.me/u/neonnblack/new-...&data=3-19
https://datazap.me/u/neonnblack/log-...8;data=3-10-19
hot and dry in the high desert. I added half a can of octanium to the gas. Hopefully it improves things.
      08-29-2019, 06:21 AM   #77
aadum
aadum's Avatar
Croatia
56
Drives: 330xd e92 ,520d f10, 540i G30
i have issues with 540i automatic....car is hesitating between 1500 and 2000rpm....then above 2500rpm goes like crazy...
in addition to above after driving bit hard for a while ,as soon as i stop for a traffic lights car starts to act strangely. It stutters so much that sometimes i think engine stopped ...
MHD is reviewing map but haven't heard from them for a while.
I am on stage 1 95-103 octane map. Only mod I have is Remus exhaust which retains flap like original.In Croatia we don't have less than 95 but I am running on 100 Octane fuel
Do you also have some strange smell sometimes like burnt electronics/clutch, something like that?
My burble setting is on 0.7 sec 2200rpm STOCK LIKE.
      09-04-2019, 09:21 AM   #78
pauli18c
pauli18c's Avatar
Drives: 2017 BMW 340i M Sport
Do these flashes take care of the catless downpipe CELs?
Trying to decide on which downpipe, and dont want CEL issues
Or should I be looking at catted versions?
2017 340i M Sport Alpine white / Coral
Dorch Stg2, CTS catless, xHP, Custom MHD
      09-04-2019, 01:29 PM   #79
Solid67
Drives: 2019 M240i xDrive MP Edition
Yes, with Bootmod3 or MHD, you can flash off the CEL that appears when using a catless dp.
      09-05-2019, 09:21 AM   #80
kern417
Cheapskate
Drives: 2018 440i / 2010 X5
Forgot to post in here, but I started a log review thread. I just want to compile as much data as possible so we can have some good data visible to everyone. I have bootmod3 but it's not limited to BM3. I am focusing on OTS tunes since custom tunes add a lot more variation. Feel free to post up and join the discussion.
https://f30.bimmerpost.com/forums/sh....php?t=1648722
Instagram @kern417
      09-14-2019, 09:30 AM   #81
marcthedark
Drives: M240i xdrive Convertible
The 95-103 Octane map is not "from 95 to 103" but rather 95 US method or 103 European method and with 100 you are below the 103 required
kern4173251.00
      09-20-2019, 05:58 PM   #82
MHD Tuning
MHD Tuning's Avatar
Big update for MHD F+G Series S55 & B58 users:
_______
- S55 update
◦ Pricing reduced!
◦ Added stage 2+ maps!
◦ Added a 460hp C.S style map and a 500hp G.T.S style map, included in the base flasher license!
◦ Stage 1 / 2 maps updated to 1.08 (improved timing).
◦ Added a switchable start-up roar option
◦ fixed OPF delete option
- b58
◦ all maps updated to 3.0
◦ added support for the upcoming XDI pump.
- Ignition turns off at end of a flash.
- For tuners: added a list of codes to deactivate (b58 / b58tu1) at flash time.
_______
The B58 users get fully updated 3.0 maps which will especially improve power on lower octane gas, we also improved smoothness, drivability and power delivery.
_______
The S55 licenses prices has been aligned with other engines, this means the Flasher license no longer costs 299 but 249 and the map packs are 99 instead of 149.
We also added CS & GTS style engine maps (included in flasher license), added GTS style startup roar and improved our ST1 and ST2 maps.
Fully new Stage 2+ maps are now available (included in the ST2 maps pack) which will target around 10-15HP peak power and up to 60nm of torque more than the Stage 2 variant. We highly recommend using this map only with high flow downpipes and NGK plugs.
PURE340i103.00
kern4173251.00
      10-22-2019, 03:39 PM   #83
viperstang1
viperstang1's Avatar
Drives: 340i, alpine white
hi guys....
im here contemplating on flashing MHD stage 2. i was hoping to hear from a few people on here as to there results? and feedback. i have a few questions....
1. what boost does stage 2 target?
2. were there any special map changes required to get car to run properly?
3. is anyone here running stage 2 with Meth?
      10-22-2019, 07:40 PM   #84
OzBMR
OzBMR's Avatar
Australia
537
Drives: BMW M140i
MHD Stage 2 is great, nice options, smooth and solid power gains.
I use the 95 octane/102 RON map and blend E30, goes very well combined with xHP Stage 3 transmission tune, about 420 whp. I have stock downpipe and intake.
1. 16 - 19 PSI for my car it ramps up boost as the RPM increase, which I like
2. Nope
3. Not me. If you run the 95/102 map and use 93 octane fuel meth would help if you either don't want to use some E85 or don't have access to it.
Here's a link to a 4th gear data log with E30 blend fuel https://f30.bimmerpost.com/forums/sh...&postcount=111
M140i LCI Mineral Grey
Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s 10.93@127mph
Stock DP, XHP, MHD 95/102 OTS E30 fuel, Hoosier DR2 11.5@121mph about 8.0s 100-200
      10-23-2019, 12:14 AM   #85
enemigo13
Drives: F30 340xi
what spark plugs do you recommend for B58?
_______
- S55 update
◦ Pricing reduced!
- b58
_______
_______
      10-23-2019, 04:22 AM   #86
IMS-340MP
IMS-340MP's Avatar
Egypt
147
Drives: 2018 340i MPPSK
Isn't Decat required for running stage 2 ?
2. Nope
2018 340i LCI - MPPSK Catless AT RWD - M Sport - Shadow Edition
MPPSK - Self Tune - Pure Boost Custom Tune - MHD Stage 1 - MHD Stage 2
Fuel: 92 RON - 88 OCT
      10-23-2019, 07:25 AM   #87
OzBMR
OzBMR's Avatar
Australia
537
Drives: BMW M140i
They recommend it, but I'm not doing that.
The car goes great, logged data is very nice, making more power and torque than previous DervTech tune that ran 11.8@118mph.
If I can get a decent 60ft I think it'll do 11.5 or better with the MHD tune. This is in a little 1 series, so a nice weight advantage.
      10-23-2019, 09:19 AM   #88
viperstang1
2. Nope
thanks for your reply. ill install stage 2 today
