BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > B58 - Time slips/0-100kmph/100-200kmph thread!
proTUNING Freaks
      11-18-2020, 01:02 PM   #485
IMS-340MP
IMS-340MP's Avatar
Egypt
147
Drives: 2018 340i MPPSK
It says 100 RON + WMI and no mention of Ethanol in your signature.
Thanks for the clarification, great times and power anyway
Originally Posted by Glemm1970 View Post
100Ron +30% E85+WMI. Dyno 626whp.
2018 340i LCI - MPPSK Catless AT RWD - M Sport - Shadow Edition
MPPSK - Self Tune - Pure Boost Custom Tune - MHD Stage 1 - MHD Stage 2
Fuel: 92 RON - 88 OCT
      11-20-2020, 06:26 AM   #486
chris-c
Drives: F31 340i RWD
Well the F31 is getting quicker still. Shame my brakes are shot or I'd have done more testing.
F31 340i RWD | MPPSK | XHP 3 | B58TU HPFP | BM3 St2+
IMS-340MP146.50
M140_BCS109.50
      11-20-2020, 11:30 AM   #487
IMS-340MP
IMS-340MP's Avatar
Egypt
147
My best Self tune 100-200 running on 92 RON - 88 OCT.
Tune has 510 NM of torque up to 5000 RPM and 410 HP@6500 RPM (Attached)
This is the best I could do with the available fuel, I will try to increase Torque a bit at top end and see if time improves.
      11-20-2020, 11:52 AM   #488
Supr3me
Supr3me's Avatar
Drives: Your mom crazy
Launching in 2nd with DCT completely off is giving me my best times. This is on street tires, unprepped surface. I think I can get low 10s with drag radials next spring. My 100-200kph sucks tho.
2016 340i xDrive M-Sport MPPSK
Pure800; Dorch Stg2 hpfp; VRSF DP; AP intake
MHD; Wedge Performance E50 tune; xHP Stage 3
Forgestar wheels & KW coilovers
10.45 1/4; 2.75 0-60mph
IMS-340MP146.50
      11-20-2020, 11:59 AM   #489
IMS-340MP
IMS-340MP's Avatar
Egypt
147
Impressive times mate how does your 100-200 sucks with those times ? What's your 100-200 ?
      11-20-2020, 12:03 PM   #490
Supr3me
Supr3me's Avatar
Thanks!
My best 100-200 is 6.44. Seem to be consistently between 6.45-6.50
Not sure if I'm not starting in the correct gear, or not at the correct speed or what.
I've tried brake boosting and that doesn't seem to improve matters.
I know xdrive is heavier but honestly doesn't make sense. I'm sure it's operator error, I've consistently gotten better results in launches by figuring out what I'm doing wrong.
      11-20-2020, 12:25 PM   #491
IMS-340MP
IMS-340MP's Avatar
Egypt
147
Bro 100-200 in 6.5 seconds is a very impressive time for a 340i xdrive.
Thanks!
Supr3me471.50
      11-21-2020, 11:12 AM   #492
B58togo
Drives: M240i
7.26 and 7.46, and then the corresponding 60-130 mph on the same runs. The 7.26 was around 32 degrees out and the 7.46 was 52 degrees. Car weighs probably ~3450 with the rear seat removed, I'm a little over 170 lbs dressed, and had probably half a tank on these runs. I will say, the car runs amazing in the colder weather with Paul's tune. Last winter I was running OTS E30 Stage 2 and it would occasionally backfire and throw codes. No issues with Paul's tune.
2017 M240i AW/ ZF8/ BM3 E40 Johnson tuned/ Dorch Stg.1 HPFP/ xHP Stage 3/ ER catless DP/ Remus axle back/ BMS intake/ M Performance LSD 11.6 @ 122 mph
      11-21-2020, 11:44 AM   #493
Supr3me
Supr3me's Avatar
Idk, maybe that's true. SC_B5X has been my benchmark as we're running pretty much identical setups, same tuner. I think he's running like maybe one more lb of boost than I am and he's RWD.
His 60-130 is almost a full second faster than mine tho. 6.78 vs 7.42 Does xDrive vs RWD explain that much of a delta?
Edit: he also has an amazing DA lol
      11-21-2020, 11:55 AM   #494
IMS-340MP
IMS-340MP's Avatar
Egypt
147
I think the delta 100-200 to RWD is around 5% which still makes his car faster than yours which is most probably a result of DA.
Anyway you should be more than happy 6.5 seconds 100-200 is faster than an M5/M8 Competition.
Supr3me471.50
      11-21-2020, 12:33 PM   #495
M140_BCS
M140_BCS's Avatar
110
Drives: 440i Gran Coupe
Quick time for F31 on 99 RON fuel.
Much faster than your 8.9 a few weeks back.
Are you in 3rd or 4th when you pass 100kph?
I'm running MHD Stage 2 98RON tune with Momentum 99 fuel.
Best time I've run recently with the Dragy is 8.6
2016 440i RWD - Quaife LSD - MHD Stage 2+ E30 - B58TU HPFP - xHP - BCS DP - Bilstein B6 Damptronics - Eibach Pros - BBS CH-R - MPS4S - aFe Drop In & Scoop
IMS-340MP146.50
mgeller18.00
      11-23-2020, 06:55 AM   #496
chris-c
Oh hell no! That time was running an E30 map.
BM3 logs indicated ~515hp.
Even my 99 ron run was with 3-4l of ethanol for added "pep"
      12-20-2020, 10:58 AM   #497
Skyhigh
Skyhigh's Avatar
780
Drives: BMW F36
Has anyone measured 0-100 with MHD Stage 2 (or any other Stage 2)? Just curious if that alone can compete with stock M4.
      12-26-2020, 04:22 AM   #498
trescuarenta
Drives: BMW 340i xDrive
My 340ix on Pure800 and HCP E30 tune.
BMW 340i xDrive Melbourne Red | 613 WHP 830 WNM | Pure 800 - HCP E30 Tune | Instagram: daddy.340
B58togo719.50
      12-30-2020, 05:17 PM   #499
FLF30
Drives: 2017 340i
340i stock turbo E50 custom tune
      01-04-2021, 12:50 AM   #500
yokata
yokata's Avatar
Bulgaria
153
Drives: Bmw F30 340xi
Im 340xi with pure800 dorchst2 Paul 100ron tune 6.47 best 100-200. But usually its around 6.6-7 if its not -temps.My timing is very low when DA is more then 1000 (around 1300-500 in winter) so i think E should improve alot my times https://www.bootmod3.net/log?id=5fd7...90c60d7521fdcf one log to have clearer picture
      01-04-2021, 05:03 AM   #501
F80Moe
F80Moe's Avatar
271
Drives: 2016 F80 M3 6spd
Solid runs!
How much boost is your tune targeting?
My best for the Supra is 5.94sec (Pure800 + Meth)
      01-07-2021, 04:13 AM   #502
luchocamp
Drives: 15 BMW M4
yes, rwd vs xdrive difference ...
rwd very difficult to down from 10.9sec 402mts run on street
13 BMW 335ix Full Weight 10.64 @129mph N55 WR SOLD
15 BMW M4 Full Weoght 10.69@133mph stock turbos SOLD
18 BMW XXXX Car in Process
drag track online set up contact on Instagram @luchocampusano YouTube Lucho Campusano
      01-07-2021, 11:47 AM   #503
Supr3me
Supr3me's Avatar
Updated times
OzBMR536.50
luchocamp193.50
IMS-340MP146.50
      01-20-2021, 11:40 AM   #504
Hkilla00
Drives: Bmw 340i
Slipped a entire gear (4th) around 130 kmp otherwise would have been a nice clean low 5s high 4 run
Supr3me471.50
      01-21-2021, 01:38 PM   #505
IMS-340MP
IMS-340MP's Avatar
Egypt
147
It's embarrassing to post my time guys after seeing your times
Anyway it's a self tune running on a full tank of 87-88 octane (92 RON)
All stock except catless downpipe and MPPSK exhaust.
      01-21-2021, 03:03 PM   #506
luchocamp
Drives: 15 BMW M4
you pass for 100kph full of traction, you could see G force on dragy...orange line... great time ! keep it up
