Login
12-04-2019, 04:02 PM | #243 | |
Cheapskate
![]() 3240
Rep 4,289
![]() At a minimum, I'd switch to Map 0 and flash the actual MHD E30 tune to see if you feel an improvement over the JB4 ethanol map. That should answer some questions before you actually ditch it. |
12-04-2019, 04:12 PM | #244 | |
![]() ![]() ![]() ![]() ![]() 469
Rep 655
Drives: Your mom crazy
Since I'm planning on buying a custom tune from Wedge, I hate to also pay for an MHD OTS map if I don't have to. |
12-04-2019, 09:08 PM | #245 | |
Cheapskate
![]() 3240
Rep 4,289
12-05-2019, 03:08 AM | #246 |
![]() ![]() ![]() 229
Rep 530
latest log :
https://datazap.me/u/enemigo/bmw-340...2-7-9-11-12-13 with this setup 340xi runs 1/4 mile at 11.93 @ 189.51km/h (118.4mph), 60ft 1.88 (slipping all 4 wheels on launch) and 100-200km/h 9.13 sec. ROZ98 petrol is used, all hardware including downpipe - stock. Only mod is NGK 94201 spark plugs. |
janea120727.00 |
12-05-2019, 06:50 AM | #247 | |
![]() 27
Rep 137
b58
very good time 100-200 |
12-05-2019, 10:11 AM | #249 |
Cheapskate
![]() 3240
Rep 4,289
can you translate the descriptions to english? I think I see engine speed and fuel pressure but not sure about the others or their units of measure.
12-05-2019, 10:24 AM | #250 | |
Rep 530
*laderdruck* absolute pressure *zuendwinkel* ignition timing 480c - desired load. please ask if something else is not clear |
kern4173239.50 |
12-08-2019, 05:09 AM | #251 |
![]() 27
Rep 137
340i stage2
Hi, 2016 340i stage2 Ron98
from 3th gear but with wheel spin. It is good? https://datazap.me/u/janea1207/bmw-3...8;data=5-12-24 |
12-08-2019, 06:59 AM | #252 | |
![]() ![]() ![]() ![]() 535
Rep 579
![]() -0.5 C ambient is going to make it difficult to do a 3rd gear pull. You'll need to wait till the temperature warms up a bit and try 4th gear? The only data point that looks useful is 6900 RPM and everything looks good for a Stage 2 93 octane map
M140i LCI Mineral Grey
Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s 10.93@127mph Stock DP, XHP, MHD 95/102 OTS E30 fuel, Hoosier DR2 11.5@121mph about 8.0s 100-200 |
janea120727.00 |
12-08-2019, 07:16 AM | #253 |
![]() 27
Rep 137
B58
Today made in 4th gear
Please check https://datazap.me/u/janea1207/bmw-3...&data=5-24 https://datazap.me/u/janea1207/bmw-3...&data=5-24 |
OzBMR535.00 |
12-08-2019, 07:37 AM | #254 | |
Rep 579
![]() How does it feel?
12-08-2019, 09:20 AM | #255 | ||
![]() 27
Rep 137
my 340i stage2 should be ~8 sec 100-200 |
OzBMR535.00 |
12-08-2019, 05:26 PM | #256 |
Rep 579
Very quick, enjoy!
12-09-2019, 02:28 AM | #257 | ||
![]() 27
Rep 137
b58
12-12-2019, 02:18 PM | #258 |
Rep 655
Alright, update on the MHD/JB4 saga.
I yanked the JB4 and reflashed back to stock via MHD, then flashed to the stage 2 E30 OTS map. (side note, man the wifi adapter makes that a breeze. Wish I had known it was an option when I first purchased MHD because it's only like 10 bucks more than the K+DCAN cable from bimmergeeks. Here are the first 3 pulls at operating temp after the flash to the E30 map. Interested in your thoughts because my butt dyno didn't register much. Car felt like stock at 50% throttle from stoplight to stoplight when getting up to operating temp and WOT pulls weren't anything write home about. Do the MHD OTS maps learn/adapt over time? Do I need to do some additional pulls to see additional gains? https://datazap.me/u/tnilson/mhd-e30-pull-1-3rd https://datazap.me/u/tnilson/mhd-e30-pull-2-2nd https://datazap.me/u/tnilson/mhd-e30-pull-3-2nd Edit: Technically SC_B5X did reply to one of my earlier posts with a recommendation to purchase the wifi adapter instead and my dumbass didn't see it before I bought the cable. ![]() |
12-12-2019, 04:45 PM | #259 | |
Rep 579
Do you have draggy?
12-12-2019, 05:04 PM | #260 | |
Rep 655
I also sent these to Ken at Wedge, he's going to do a custom tune once the Supra hpfp is installed. I'll share his comments with the group as well. Edit: No go on reset adaptations for the high pressure fuel system. Thinks for a minute then says: "Failed. Connected" Last edited by Supr3me; 12-12-2019 at 06:52 PM.. |
12-13-2019, 11:03 AM | #261 | |
Cheapskate
![]() 3240
Rep 4,289
12-13-2019, 04:55 PM | #262 | |
Rep 579
kern4173239.50 |
12-14-2019, 02:10 AM | #263 |
![]() ![]() 339
Rep 261
Updated Setup, here is my datalogs from my E50 Base Map.
New Setup: VRSF 4.5" Catless DP Remus Axleback Dorch Engineering Stage 1 HPFP Custom E50 Tune by Wedge Performance Wedge E50 V1 3rd Gear (Dorch HPFP) Wedge E50 V1 4th Gear (Dorch HPFP)
Instagram: SC_B5X
2016 BMW 340i M-Sport Pkg Pure 800 Turbo, Dorch Engineering Stage 2 HPFP, VRSF 4.5" Downpipe, Remus Axleback, CTS Turbo Intake, 8HP70 Transmission Swap w/ XHP Stage 3 Trans Tune, and Custom E50 Wedge MHD Tune |
12-14-2019, 08:27 AM | #264 | ||
Cheapskate
![]() 3240
Rep 4,289
I know for sure, my V2.0 logs changed the boost curve. It targets 14ish psi until it peaks 14-15, and then target bumps up to 16. It still overshoots a bit sometimes, depending on how fast boost comes on. I think higher rpm pulls have more difficulty controlling boost. But again, I just don't understand how it can be so difficult to lock in an EWG's boost control. I never had these issues with other OEM/aftermarket boost controllers and normal wastegates. Quote:
How are you guys approaching it? Seems like a lot of boost and timing for a base map. Are you just slowly increasing the E to see how it responds? |
