BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > B58 Log Review Thread
      08-24-2020, 12:43 PM   #1563
N420i
Drives: 2016 420i lightly modded
Originally Posted by pauli18c View Post
Flashed the MHD OTS stage 1, 91 octane tune on Friday afternoon, topped the tank off with shell 93 and ran it all weekend. So should have had plenty of time to adapt (like 200 miles).
ran a log tonight
https://datazap.me/u/pauli18c/mhd-ot...36-37-38-39-40
I will say that it is on the stock plugs and I have not pulled them to gap them. I have NGK 1 step colder plugs coming tomorrow hopefully and plan to gap them at .022 and get them in ASAP
That log looks VERY similar to what BM3 Stg1 91 looks like in my fully stock M140i. Same timing pull. The pull is similar with Stg1 93, but the car is significantly faster.
I swapped out the stock champions for gapped NGKs and that didn't make the slightest difference.
The only thing that seems to make SOME difference is using Shell gas. Even then I still have significant timing pull, as do many, many people using the OTS maps without ethanol... I've logged friend's B58s and they have the same pull as you and me...
Apparently there's no solution besides using ethanol if you have access to it, or getting a custom tune.
      08-24-2020, 01:21 PM   #1564
IMS-340MP
IMS-340MP's Avatar
Egypt
147
Drives: 2018 340i MPPSK
Yes bro I noticed lately that most logs are not looking good without Ethanol.
But no this is not the normal these engines are designed to run on Gasoline so they shouldn't pull timing when using the correct octane.
There are many good logs on this thread running without Ethanol it's just lately logs are not so good maybe it's because of the pandemic fuel companies are messing up adjusting the required octane percentages.
2018 340i LCI - MPPSK Catless AT RWD - M Sport - Shadow Edition
MPPSK - Self Tune - Pure Boost Custom Tune - MHD Stage 1 - MHD Stage 2
Fuel: 92 RON - 88 OCT
      08-24-2020, 01:33 PM   #1565
pauli18c
pauli18c's Avatar
Drives: 2017 BMW 340i M Sport
Yeah, I'm in the process of getting a custom tune. If you go back a few messages you can see the log from that as well. Was still pulling timing, which is why I flashed stage 1 to see if it was still doing the same thing.
My end goal is a custom E50 tune, but I'd still like a 93 tune as well for when it's not around and easily accessible which is why we were working on the 93 tune first.
2017 340i M Sport Alpine white / Coral
Dorch Stg2, CTS catless, xHP, Custom MHD
      08-24-2020, 07:21 PM   #1566
Jay5k
Jay5k's Avatar
https://datazap.me/u/jptsunga/b58-vt...=0&data=3-5-28
It is possible to see cracked intake manifold based on logs? My tuner said I have a boost leak. If my boost (pre-throttle) and MAP is the same, then my intake manifold is fine right? The leak should be somewhere pre-throttle?
      08-24-2020, 09:25 PM   #1567
pauli18c
pauli18c's Avatar
Well put the NGK 94201 plugs in gapped to .022, flashed the custom tune back on, reset the octane adaptation and drove around for a bit before logging. Doesn't seem have done anything from what I can tell.
My fuel-it ethanol sensor is reading E10, with the 93. Could that have anything to do with it, although that should give me more room no? Or could they have changed over to crapyy winter blends already?
https://datazap.me/u/pauli18c/custom...22-23-24-25-26
Should I flash back to stock and try that?
      08-25-2020, 05:48 AM   #1568
IMS-340MP
IMS-340MP's Avatar
Egypt
147
Bro I really like this 93 Custom tune but with the current IAT it has too much boost for your fuel.
Ask your tuner to adjust the tune so that LOAD REQUIRED is 10% lower across the RPM range and you should get good results.
      08-25-2020, 07:23 AM   #1569
pauli18c
pauli18c's Avatar
Yeah it's been really hot here the past few days, even at night. Took another log this morning and IATs were 93 instead of 117. Can definitely see the load actual start dropping off around 5k.
Also, what's up with cylinder 1? Why does it keep dropping so much timing comparatively, is that normal?
I'll have to get on the phone with the tuner, he's been swamped so taking a few days for him to get back to me the last couple times.
Thanks again for the help / insight
https://datazap.me/u/pauli18c/custom...&data=14-18-41
IMS-340MP146.50
      08-25-2020, 07:37 AM   #1570
alyabiev
Russia
104
Drives: BMW M240i xDrive, Mazda 3 MPS
Originally Posted by Jay5k View Post
https://datazap.me/u/jptsunga/b58-vt...38;data=3-5-28
Please re-do the logs with these parameters:[IMG][/IMG]
Solid67162.00
      08-25-2020, 08:18 AM   #1571
IMS-340MP
IMS-340MP's Avatar
Egypt
147
When timing is pulled usually it's cylinder 1 that suffers the most, it's been noticed on many logs in this thread.
      08-25-2020, 08:34 AM   #1572
pauli18c
pauli18c's Avatar
Good to know, thanks
IMS-340MP146.50
      08-29-2020, 04:16 PM   #1573
Denys_BMW
Ukraine
Drives: M340i xDrive
Two pulls on E22 (98Ron/93Oct + 100% ethanol in fuel tank). It is much more better than one pure 100Ron fuel.
Stock M340i xDrive. Timing is really cool if i understand it right.
https://datazap.me/u/denysbmw/m340i-...-26-27&solo=22
p.s. I know that this is F30 topic, but i have B58 too and maybe someone would be interesting is this.
OzBMR535.00
IMS-340MP146.50
      08-30-2020, 04:02 AM   #1574
IMS-340MP
IMS-340MP's Avatar
Egypt
147
You are welcome mate definitely interesting to see B58 M340i logs.
      09-02-2020, 06:15 PM   #1575
Eldotbe
Drives: M140i
Bit of a scary moment. So was driving home and car came up with OIL PRESSURE TOO LOW, Stop immediately and turn engine off. So I did just that. Checked under car and where oil filter is and no oil anywhere. Did an oil change yesterday put 6.5L in and have done around 100 miles since. So abit strange. Started it again and no code, Slowly drove the rest of the way home and logged it. At idle was sitting around 23psi and while driving normally was between 30 and 45psi. Not really sure what it could be. Gonna check oil filter housing tomorrow as seems to be a common problem on B58ís. Whatís the normal idle oil pressure for the B58 and whatís normal oil pressure when driving
      09-02-2020, 06:27 PM   #1576
T_H_O_M_A_S
Drives: M135xi
pls do your logs in psi
M140i DP , OPF delete , MHD stg2 93oct , xhp stg3
      09-02-2020, 11:52 PM   #1577
Supr3me
Supr3me's Avatar
Drives: Your mom crazy
New logs for rev 17
Steve turned things up a bit, car feels monstrous right now. Gotta be close to 600 whp.
https://datazap.me/u/tnilson/pure800...=0&data=4-5-21
2016 340i xDrive M-Sport MPPSK
Pure800; Dorch Stg2 hpfp; VRSF DP; AP intake
MHD; Wedge Performance E50 tune; xHP Stage 3
Forgestar wheels & KW coilovers
10.45 1/4; 2.75 0-60mph
OzBMR535.00
IMS-340MP146.50
kern4173239.50
      09-03-2020, 03:06 AM   #1578
OzBMR
OzBMR's Avatar
Australia
535
Drives: BMW M140i
Originally Posted by Supr3me View Post
New logs for rev 17
580 - 590 WHP and 550 lbft
The torque over 5000 RPM holds so strong
Dropping a little timing, especially over 6000 RPM in a couple of the logs.
Are you sure you're at E50? Maybe increase the ethanol % a bit to see if it cleans the timing up? Rail pressure looks good.
M140i LCI Mineral Grey
Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s 10.93@127mph
Stock DP, XHP, MHD 95/102 OTS E30 fuel, Hoosier DR2 11.5@121mph about 8.0s 100-200
      09-03-2020, 10:38 AM   #1579
Supr3me
Supr3me's Avatar
Thanks Oz. I haven't tested my local ethanol pump in a couple of weeks, I'll test it again and adjust my pump calculation a bit, err on the side of E55ish
      09-04-2020, 06:19 AM   #1580
Uni-Rapide
Uni-Rapide's Avatar
Netherlands
24
Drives: 2018 F30 340i
New logs for rev 17
Seems to be pulling all the way up till 6800 rpm, must be a really nice feeling!
Mods: 19" HRE FF15 Gloss Bronze Metallic, M Performance diffuser
      09-04-2020, 07:22 AM   #1581
IMS-340MP
IMS-340MP's Avatar
Egypt
147
Looking good happy for you bro it seems lowering the load from 240 to 225-230 fixed the timing dipping issue.
Only thing I noticed Load is fluctuating a bit under 4800 RPM could be fixed by lowering the Load a bit under 4800 RPM.
New logs for rev 17
      09-05-2020, 01:20 PM   #1582
IMS-340MP
IMS-340MP's Avatar
Egypt
147
Self tuned running on 92 RON and amb. temp. 34 Celsius.
https://datazap.me/u/ims/self-tuned-...52-53-54-55-56
      09-05-2020, 01:47 PM   #1583
M140_BCS
M140_BCS's Avatar
110
Drives: 440i Gran Coupe
https://datazap.me/u/ims/self-tuned-...-5-13-16-17-25
What causes the throttle closures you seem to have in that log?
2016 440i RWD - Quaife LSD - MHD Stage 2+ E30 - B58TU HPFP - xHP - BCS DP - Bilstein B6 Damptronics - Eibach Pros - BBS CH-R - MPS4S - aFe Drop In & Scoop
      09-05-2020, 02:04 PM   #1584
IMS-340MP
IMS-340MP's Avatar
Egypt
147
The tune base is MPPSK and it was always like that with MPPSK, BMW uses both waste gate and throttle to control boost.
M140_BCS109.50
