BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > F30/F32/F33 Classifieds (For Sale / Trade / Wanted) > Sponsors Classifieds > Engine / Drivetrain / Exhaust / Bolt-ons > Switchable Maps On-The-Fly update for BMW F Series B58
      07-30-2020, 05:18 PM   #1
Jarek@JRAuto
Jarek@JRAuto's Avatar
Drives: G20 340i
MG Flasher update v234
First in the world, our entirely revised custom code for MG Flasher’s Switchable Map On-The-Fly feature brings officially support for F-Series B58. B48 and G series support will be rolling out in the following weeks. Our new custom code (v5.1) allows to switch between OTS Octane, Ethanol blends map, new Stage 2.5 (HPFP upgrade required) without the need to reflash the vehicle! Through a simple combination of the Brake Pedal, Accelerator Pedal and the Driver Select Switch you can quickly select between mapping. Please refer to OTS map release notes for which map slot contains which map.
Existing users should synchronize your App and update/flash new maps. Just before flashing you will be informed that the procedure will take approximately 3 – 4 minutes. This is a one-time flash that will not occur again unless new updates are released in this specific new code. Minimum OTS map version 2.11 is required to access Switchable Map option. Tuners should contact us about accessing Switchable Maps when using “Custom Flash Menu”.
Watch our instructional video on YouTube to see how it works and read our User Manual for details! F and G series vehicles: https://www.youtube.com/watch?v=2DSUhvuXu9c
Upgraded High Pressure Fuel Pump support has also been added. From the flashing menu, select the HPFP Installed option for B58TU pump, Spool Performance FX-150 & FX-180 or Dorch Engineering Stage 1 & 2. This will allow the ECU to properly control the pump. To gain any performance benefits of these high flow pumps, you’ll also need to select a Stage 2.5 map (part of Switchable Maps option). Please refer to OTS map release notes for which map slot contains Stage 2.5.
When using Stage 2.5, it is required to have an upgraded HPFP (B58TU, Spool Performance FX-150 and FX-180 or Dorch Engineering Stage 1 and 2) and downpipe. To prevent unintentional damage, do not switch to this map without installing these upgrades and selecting HPFP Installed in the flashing menu first.
Custom Code version 5.1 also bring bug fixes and improvements to Cold Start Delete, Max Cooling and Burble On-The-Fly selection. Burbles will no longer change aggressiveness (eco to comfort) on its own with engine start. Switching Burble mode on F series now requires 4 MSA presses and to return to default requires 6 presses in any mode. F and G series share the same instructions now.
Regards,
The MG Flasher Team
www.mgflasher.com
      07-30-2020, 08:37 PM   #2
luca10
luca10's Avatar
Drives: 2018 BMW 340i xdrive
Any idea of when v234 will be available for iPhone? Seems to only work on Android
Instagram- f30_luca
Modifications: Custom E50 Tune by David Shoup, B58TU Fuel Pump, Armytrix Exhaust, VRSF downpipe, Big Boost Charge pipe/bov kit, CTS intake, H&R Springs/B8 Struts, 335is Clutch Upgrade
      07-31-2020, 01:48 AM   #3
Jarek@JRAuto
Drives: G20 340i
We apologize for the inconvenience. It has been under review by Apple all day. Due to Covid-19, their review department is slower than usual. We're hoping that by tomorrow it will be available.
      07-31-2020, 12:41 PM   #4
Jarek@JRAuto
Drives: G20 340i
v234 is live on iOS now. Android is also ready as of yesterday.
      07-31-2020, 01:06 PM   #5
luca10
luca10's Avatar
Originally Posted by jarek@jrauto View Post
v234 is live on ios now. Android is also ready as of yesterday.
Instagram- f30_luca
      07-31-2020, 02:46 PM   #6
luca10
luca10's Avatar
Just one more question, if I click the hpfp when flashing the car, does that bring it to stage 2+ or do I still need to change through switchable maps? Thanks
Instagram- f30_luca
      08-01-2020, 12:59 AM   #7
chenry
Drives: M340(15 before)& Boston Whaler
love the innovation nice work
      11-17-2020, 08:24 PM   #8
Jarek@JRAuto
Drives: G20 340i
By selecting HPFP in app, you're enabling proper control over the pump in any map you're flashing. You'll still need to select the stage 2+ slot to fully utilize the pump's potential.
Thank you so much!!
      11-20-2020, 05:58 PM   #9
Jarek@JRAuto
Drives: G20 340i
MG Flasher Black Friday and Cyber Monday 2 Week Sale
We are offering 15% off all MG Flasher Licenses and our official ENET Adapter!
Available through our dealer network and at shop.mgflasher.com
Offer is valid from November 20th until December 3rd, 2020
Also, checkout the new list of supported Gen 2 B48 and B58 vehicles at www.mgflasher.com
      11-22-2020, 08:36 PM   #10
dmanb2b
dmanb2b's Avatar
222
Drives: F30, E90, E46, E30
Sent you a PM
      11-25-2020, 02:28 PM   #11
Jarek@JRAuto
Drives: G20 340i
MG Flasher’s latest App, version 266, contains an important Custom Code patch (v5.4), for F-Series B46, B48 and B58 vehicles. This update will correct low torque and significantly improve performance for vehicles with Custom Code v5.x software. Please update the app from your respective app distributor, Play Store or App Store. Once you have app v266 installed, reflash your current map (OTS stage 1, 2 or Custom Map). You will be asked to confirm flashing to Custom Code version 5.4. Once complete, you should immediately see significant improvement in performance, most noticeably on the B48 platform.
The MG Flasher Team
dmanb2b221.50
