BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Catless downpipe or catted downpipe
      08-12-2020, 09:01 PM   #1
Dav340
Dav340's Avatar
Drives: BMW 340i xdive msport
I'm looking at the VRSF B58 catless and high flow catted Downpipe. I dont think I will pass inspection with a catless downpipe but I still want that aggressive tone to my exhaust.
      08-12-2020, 09:57 PM   #2
TK335iMSPT
TK335iMSPT's Avatar
Drives: F30 335ixdrive M Sport
Check with your states/local areas emissions and inspection regulations. There are only a few catted downpipes that will pass inspection. Fabspeed has a near perfect track record of being CEL free and passing emissions, Active auto works and CG Precision catted pipes also claim to be CEL free and pass emissions; but both are fairly new and don't have the same long term data Fabspeed does. All of these downpipes come at a cost though, as you will see when you look into them. If you have patience, you may be able to score one of these used. I was amazingly fortunate to score a used (500 mile) fabspeed catted pipe for 700 USD.
      08-14-2020, 01:22 AM   #3
alpinweiss340
Drives: 340i
I got the catless because I was on a tight budget. Installing it myself was about 2hr (mainly because I only had a ramp and a second pair of hands would be better to help guide the DP into the flange) other than that, the only thing that bothers me is the spouse complaining about the smell after some spirited driving and then pulling up to a red light. (Oh yeah. Based in California too)
*i have taken it out one other time and installed it again, was a lot quicker doing it the second time around, I really donít mind putting the factory DP back on for smog check
PS. Definitely invest in a pipe extender from amazon or something. It would have been even more of a task without it *for some reason the pic uploads upside down from what Iím seeing?
      08-14-2020, 04:06 AM   #4
Sleeper340i
Drives: BMW 340i
Started off with a high flow downpipe till the catalytic converter melted, ended up gutting it and went catless so I've experienced both.
If you're not going to go ham with the pops/burbles and want a more refined sound and less stink go high flow.
Catless definitely smells worse and can be smelled with window rolled down but I got used to it. Also has a louder/raspy sound but I feel like torque is increased and the louder sound has definitely grown on me. I'll pick catless any day over high flow now.
      08-17-2020, 11:23 AM   #5
mike@x-ph.com
mike@x-ph.com's Avatar
Drives: 2007 e92 335i / 2013 F30 328
If legal, catted, in my opinion, is better
  • Same performance
  • deeper and more refined tone
  • No fuel smell
OzBMR536.50
Skyhigh779.50
      08-21-2020, 01:57 AM   #6
misguided_will
misguided_will's Avatar
Australia
37
Drives: 2018 BMW 340i M Sport
not sure if this would be useful to anyone but i have the vrsf catted and after about 1000km it's throwing the P0420 code
2018 F30 BMW 340i M Sport
Injen EVO intake, OEM 437m rims, Catted VRSF dp, Magnaflow catback, Activ8 piggyback, Pedalbox.
BMWILUVU421.00
      08-21-2020, 01:46 PM   #7
Uni-Rapide
Uni-Rapide's Avatar
Netherlands
24
Drives: 2018 F30 340i
Originally Posted by mike@x-ph.com View Post
  • Same performance
I think it depends, as soon as you start running E-fuel, adding meth and/or bigger turbo you will get more performance from a catless downpipe.
Obviously in combination with a proper tune
Mods: 19" HRE FF15 Gloss Bronze Metallic, M Performance diffuser
      08-21-2020, 01:59 PM   #8
mike@x-ph.com
Correct, catless will make more power once you are running a larger turbo. I should have made that clear
      11-12-2020, 01:29 PM   #9
Dav340
Dav340's Avatar
Catted downpipe
Does anyone have videos of how the catted downpipe sounds also will I have to check engine light if I do catted downpipes ?
      11-12-2020, 02:04 PM   #10
BMWILUVU
Drives: 340ix
I've read posts on this forum on this topic and this is what I see.
For a catless downpipe, this will give you a CEL guaranteed. You need to clear the codes or have a tune do it for you. A possible solution is an O2 spacer though I have not heard of a catless 340 owner successfully using an O2 spacer.
For the 200 cell high-flow downpipes my preference is in order, CG Precision DS-1 then AA catted downpipe. Most 200 cell high-flow downpipes will give a CEL after X number of miles but I have only seen 2 owners of DS-1 who claimed they get CEL once in a while over many years. The sense is the AA downpipe seems to give a few more instances of CEL than DS-1 and has just recently arrived.
For 300 cell high-flow cats, the euro-compliant HJS catalysts used by Wagner and Fabspeed and HJS downpipes are very expensive and I have not heard anyone getting a CEL but at 300 cells per inch, the restriction is close to asking yourself why even bother.
I think the B58 stock downpipe has 2 catalysts 400 cell and I think the second is 600 cell but over 5" diameter sections where most downpipes are over 4" diameter sections some even 3".
I decided on catless.
      11-12-2020, 09:47 PM   #11
G.Newt
Drives: 340i xDrive 6-Speed
You have IG or social media? I can send you an exhaust clip. I'm running CG DS-1 5" catted + AWE catback. I don't have one of just the downpipe itself, unfortunately. This is a VERY aggressive combo, but no CELs (I've gotten it once, cleared, and hasn't come back since) and I'm emissions compliant.
2016 340i xDrive 6-speed.
FBO. Stage 2 E30 BM3. 440hp / 515lb-ft (Mustang Dyno)
      11-13-2020, 05:33 AM   #12
Skyhigh
Skyhigh's Avatar
780
Drives: BMW F36
If you are asking yourself that for 300 cell, you must as well be asking it for the 200 cell.... the difference in backpressure / gas flow is minimal, see the diagram below. However one comes with an emission standard retention guarantee and type approval (and of course no CEL), the other - with a user manual how to cross fingers. After all, you get what you pay for....
There are a lot of threads related to Downpipes here.
I did my own research, whereas my priorities were (in that order):
- Performance increase
- Retention of the environmental standard of the car
- Quality and sustainability
- Sound improvement at the cost of minimal to moderate noise increase (I'll keep repeating this - "sound" and "noise" are 2 terms confused way too often...!)
- Price
I concluded I need to go for a HJS-based downpipe.
Dav340 Since your priorities may be different, my best advice is to simply search the forum and read the existing DP-related threads.... You will be able to draw your conclusions after that. Also don't forget that sound is dependent not only on the DP, but on your entire exhaust system. If you already have a sport exhaust system or parts of it or are planning to upgrade it, I would strongly advise you against catless.... you may very quickly end up in a very loud car with harsh and corrupted exhaust sound.
My experience is somewhat limited, but it confirms the advice @mike@x-ph.com gave you above.
      11-13-2020, 09:31 AM   #13
FirstBMWLA
FirstBMWLA's Avatar
61
Drives: 2007 335i Coupe
I recently went catless having already done dual resonator delete
I couldn't be happier.
sounds wicked on throttle and tame when not.
No drone.
Everyone's opinion is different but lots here seem to think it would be obnoxious.
Cold start is though. Tune with cold start noise reduction is kinda a must.
      11-13-2020, 12:44 PM   #14
dmanb2b
dmanb2b's Avatar
222
Drives: F30, E90, E46, E30
Tune can suppress the check engine light, but you will still have that monitor in not-ready status. In NY you can't have more than 2 monitors in not ready status before trying to pass the OBD2 plugin test. Whether you pass the visual inspection depends on the shop/inspector and how picky they may be.
      11-13-2020, 01:41 PM   #15
Icy340
Icy340's Avatar
Drives: BMW 340i
Have you looked into CTS ? I have a CTS high flow catted downpipe with dual resonator delete. Has a great tone, not obnoxious. No cel because running bM3 Stg 2
      11-16-2020, 03:07 PM   #16
F30_Paul_
Drives: BMW 340i xDrive
Can you post a clip?
      11-19-2020, 05:00 PM   #17
Icy340
Icy340's Avatar
Drives: BMW 340i
quick vid before work ignore the shity edit & quality lol
vcx24.00
