Login
09-24-2020, 11:40 PM | #1 |
![]() 24
Rep 135
BMW 340i Downpipe to Turbo V-Band. Magnetic Oil Drain Plug
Long story short a shop told me I had an exhaust leak at my downpipe to turbo mate. I'm wondering if I should replace the V-Band (Any recommendations for a good aftermarket v-band also what size v-band?). I'm already planning on replacing the crush washer.
Also since i'm looking at buying parts I wanted to buy a magnetic oil drain plug but cant find one for the 340i. Any recommendations? Last edited by WrxToBeamerGuy; 09-24-2020 at 11:55 PM.. |
09-25-2020, 02:51 AM | #4 |
![]() 42
Rep 61
I’ve bought the gasket from here before
https://www.getbmwparts.com/oem-part...w2LWdhcw%3D%3D And here’s a link to the Vband clamp https://www.getbmwparts.com/oem-part...bC1sNi1nYXM%3D |
WrxToBeamerGuy23.50 |
09-25-2020, 07:16 AM | #5 | |
![]() ![]() 1732
Rep 2,409
What's different about the oil drain plug in the B58 in the 340i? Have you checked Dimple? https://drainplugmagnets.com/ |
09-25-2020, 10:49 AM | #6 |
![]() 24
Rep 135
Well since you asked. I dropped my car off at a shop (at 8AM) for a turbo blanket install and they fucked around all day then decided to start the job at 4PM. They contacted me "Hey you have an exhaust leak at the turbo to downpipe connection and also we wont have enough time today to install your blanket. We don't want to install the blanket before we fix your leak. It'll be $530 to fix the leak and the parts will get here in 5 days."
09-25-2020, 10:51 AM | #7 | |
![]() 24
Rep 135
09-25-2020, 10:54 AM | #8 | ||
![]() ![]() 1732
Rep 2,409
09-25-2020, 12:08 PM | #9 |
![]() 24
Rep 135
09-25-2020, 03:35 PM | #11 | |
![]() ![]() 1732
Rep 2,409
I've been using a Dimple Magnetic Drain Plug for two years now. Dimple uses a special magnet that is extremely powerful yet it still works under high heat conditions, unlike cheaper inferior magnets. See photos. My Dimple Magnetic Oil Plug is inexpensive insurance for my $6,000 BMW engine. Below is the link. Make sure to choose the size M12x1.5x18 https://drainplugmagnets.com/cars/bmw/ |
09-25-2020, 03:47 PM | #12 | |
![]() 24
Rep 135
09-25-2020, 11:23 PM | #14 | |
![]() 42
Rep 61
09-26-2020, 12:46 PM | #15 |
![]() 24
Rep 135
11-19-2020, 02:25 AM | #16 | |
Rep 15
do you have the sizing for plugs for the diffs, TC, and zf trans? cant dm you since ur inbox is full |
11-20-2020, 10:24 AM | #17 | ||
![]() ![]() 1732
Rep 2,409
11-20-2020, 04:08 PM | #18 | ||
![]() ![]() 1732
Rep 2,409
Dimple Drain/fill plug sizes M12x1.5x18 Oil M18x1.5x12 ZF Automatic Transmission M22x1.5x9 Rear Differential, Front differential and Transfer Case Same oil drain plug fits B58 engine. If anyone has a question whether their car uses the same size plug, the answer is simple. Go to Realoem website, then lookup part number for the plug for the car above, and their car to see if the part numbers match. Hope this helps! |
