BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Dual Diffuser (435i style)
proTUNING Freaks
      10-13-2020, 07:10 AM   #1
JoshU
JoshU's Avatar
Drives: F32 430d
I recently took my car to have the exhaust converted from twin to dual pipes and the garage also fit the diffuser afterwards. The fitment is horrendous and I haven't had much of a fiddle with it but I think it's the part (eBay replica) rather than the quality of fitting from the garage.
Now I think the oem m performance diffuser is over £400 from bmw but do I have any alternatives to fixing this issue?
      10-13-2020, 08:43 AM   #2
Spendy42
Spendy42's Avatar
Drives: BMW 320D Xdrive M Sport 2013
I would try re fitting it. I bought an original one ( Not the same model of car as yours) as I was also worried about fit ( my dual one for my 320D was £179.99 from a bmw dealer. All the clips popped into place nicely but I had to push from underneath the car not just the front of it. The tips I followed was push the clip in on the middle 1st and then tackle the rest.
JoshU3.00
      10-14-2020, 03:55 AM   #3
JoshU
JoshU's Avatar
Drives: F32 430d
I'll give that a go first then and if I can't force it in a lot neater I'll have to just go to the dealers and get a different one I guess. Very costly for a tiny bit of plastic though
      10-14-2020, 05:48 PM   #4
B58_f32
Drives: 440i
try cotswold bmw, i brought a genuine one from them last year for 249 delivery included.
i tried a carbon one before from ebay, bad fit so went genuine
JoshU3.00
      10-15-2020, 05:45 PM   #5
JoshU
JoshU's Avatar
Drives: F32 430d
M performance dual diffuser?
That's a brilliant price, so certain garages will have different prices. I'll give them a ring tomorrow and ask for a price.
Thanks!
      10-16-2020, 07:53 AM   #6
mk17
Drives: F32 435i
That doesn't look like its seated properly. If its a quality copy and the clips are the same and in the same place as the original it will fit but sometimes you have to get under the car to see where the clips are and "finesse" them through from behind whilst applying pressure from the front. When you have them aligned correctly, a bit of push and shove may be required here, you should find everything clicks into place properly.
      10-16-2020, 09:24 AM   #7
JoshU
JoshU's Avatar
Drives: F32 430d
Yeah agreed I think it's badly fitted, the guy fitting it did say it was a nightmare but perhaps it was worried about damaging the car and just left it. He was only really there to fit the exhaust after all.
Anyway tomorrow I'll have a go at it and see if I can get it clipping in better.
      10-16-2020, 10:50 AM   #8
1QuikWS6
No 55mph
1QuikWS6's Avatar
Drives: F32 435ix MSport ->M6
TBH, your installer may not have given proper justice to your eBay diffuser as far as fitment goes since it is recommended to remove the rear bumper to properly install the diffuser (regardless of supplier)
Pretty sure he didn't go to the trouble of removing the bumper?
I replaced my 435 MPerf Diffuser with an aftermarket carbon fiber version (not from eBay) & it fit perfectly
You might want to try removing bumper & installing b4 you ditch the eBay part & buy a new one...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Leather Int w/M4 Alum Blade Trim//HK Sound+Musicar Stg3//763M Wheels//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoiler-LED Sills-CF Shift Knob/Surround/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Dinan CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
      10-16-2020, 12:42 PM   #9
mk17
Drives: F32 435i
Who recommends this? BMW?
Removing the bumper is unnecessary and whole load of extra work to fit a clip on part. It's a pretty straight forward job with dozens of "how to" DIY's available on line.
Not seen one where the bumper was removed or recommended to be removed.
      10-16-2020, 01:22 PM   #10
1QuikWS6
No 55mph
1QuikWS6's Avatar
Every aftermarket vendor I talked with prior to choosing the one I bought
It was their recommendation for better fitment - if you buy aftermarket you can't always expect it to fit well using OEM install routine
      10-21-2020, 06:35 PM   #11
B58_f32
Drives: 440i
some people use a heat gun, hair dryer to help it into position
      10-27-2020, 09:42 AM   #12
JoshU
JoshU's Avatar
Drives: F32 430d
I managed to improve the fitment but it wasn't perfect and I found it too annoying to leave so I've purchased and fit the oem diffuser. Cost me £330 quid with 10% off as it was an online purchase/enquiry.
It's a shame because the ebay one seemed fairly good quality and looked perfectly fine but just wasn't perfectly snug.
      10-30-2020, 05:55 PM   #13
psyki
E36fiend
Drives: 2014 435i xDrive
2014 435i xDrive  [0.00]
2014 X5  [0.00]
I bought an ebay special, plastic "carbon fiber" rear diffuser and a few of the clips were incredibly hard to get seated properly, it helped to remove the rear reflectors to work with the clips in that area. The fitment on mine is pretty good actually. Did not have to remove the bumper to install.
      11-02-2020, 07:29 PM   #14
horrizenashisland
Drives: 2017 440i 6MT
I bought one off of amazon, it was really hard to fit on first and fitment was extremely tight. Took me a hour but I forced it in, only 150 USD.
      11-05-2020, 09:12 AM   #15
mike@x-ph.com
mike@x-ph.com's Avatar
Drives: 2007 e92 335i / 2013 F30 328
We offer a 435 diffuser with a 30 day money back guarantee. If you are not happy with quality or fitment, we'll take it back
