BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Help me Build
      10-14-2020, 04:12 PM   #1
Tech UnRaveled
Drives: BMW 440i
Help me Build
I purchased an 18' BMW 440i w/ only 1700 miles on it a few days ago. Today I flash a BM3 Stage 1 93 octane tune. Bye, Bye Warranty
My thirst for more power is very strong and I think I want to jump right to stage 2. Which parts would you guys recommend?
      10-14-2020, 05:04 PM   #2
weehe126
Drives: 2016 340i
You only need a catless down pipe to go stage 2.
      10-14-2020, 05:40 PM   #3
Jay5k
Jay5k's Avatar
Drives: 2017 BMW 340i
Get a catless downpipe then you can run Stage 2 93. Once you get used to that power, buy a Dorch Stg 2 hpfp so you can run the Stage 2+ E30. Then once you are thirsty for more power, get the VTT GC turbo or Pure800 and buy a custom E50 tune.
Mods
- VTT GC Turbo
- Dorch Stage 1 HPFP
- VRSF Catless Downpipe
- MST Intake
      10-14-2020, 05:55 PM   #4
Tech UnRaveled
Drives: BMW 440i
Thanks guys.
      10-14-2020, 06:57 PM   #5
Ifellapart
Drives: BMW 340i
and once you get tired of that power take it to papadakis and throw $100k at him
2016 340i / M-Sport / Track Handling Package / MPPSK
      10-14-2020, 07:39 PM   #6
Tech UnRaveled
Drives: BMW 440i
There are a lot of different down pipes available... from $300-$1200. Is there really a difference?
Also, is there any reason to purchase a CAI?
      10-14-2020, 09:00 PM   #7
jackstrath
Scotland
483
Drives: 16' F31 340i & 03' Focus RS
Get best performance results using a drop in filter, unless spending big money on some of the fancy carbon one, Other than that the open cone ones tend to suck in hot air but sound good...
      10-14-2020, 10:16 PM   #8
luca10
luca10's Avatar
Drives: 2018 BMW 340i xdrive
Get used to it, the thirst for more power never ends unfortunately. A few things I've learned that I can share
- catless downpipe for sure. Required anyways for stage 2.
- b58tu fuel pump if your sticking with stock turbo, dorch stage 2 for upgraded turbo. I thought I'd stay stock turbo but then again, the thirst for more power kicked in and I'm ready for a Vargas GC. I'll be limited with the b58tu so now I need dorch stage 2.
- custom tune, ots maps are great but you will want to max out power. A quality custom tune will get you max power within safe limits.
- spark plugs gapped to .022 anywhere stage 2 or stage 2+, 0.20 for upgraded turbos
- if you have ethanol near by, e85 mixes make a big difference. Just started using it recently, e85 is a hell of a drug
Instagram- f30_luca
Modifications: Custom E50 Tune by David Shoup, B58TU Fuel Pump, Armytrix Exhaust, VRSF downpipe, Big Boost Charge pipe/bov kit, CTS intake, H&R Springs/B8 Struts, 335is Clutch Upgrade
      10-15-2020, 02:17 AM   #9
eluded
2JZ-GTE
eluded's Avatar
Bulgaria
2450
Drives: 340 6MT
Do you gap your plugs for stage 1 or oem ?
      10-15-2020, 07:50 AM   #10
Tech UnRaveled
Drives: BMW 440i
They are OEM plugs. The car has 1780 miles on it. I didn't see a need to change the plugs yet.
      10-15-2020, 07:52 AM   #11
Tech UnRaveled
Drives: BMW 440i
Do you have a downpipe you would recommend? They seem to greatly range in price and I'm not sure what the difference is.
      10-15-2020, 07:57 AM   #12
luca10
luca10's Avatar
I've been running vrsf catless for a while now as many others do on here. Cheap and built well, I recommend it
Instagram- f30_luca
      10-15-2020, 08:05 AM   #13
Tech UnRaveled
Drives: BMW 440i
Cool, that's the one I was looking at getting. Should I also order new plugs?
      10-15-2020, 08:15 AM   #14
luca10
luca10's Avatar
At 1700 miles I really don't think you would need new plugs, you can always gap the stock plugs to the correct gap for stage 2. I believe the interval for changing plugs is around 20k but I will most likely change mine every 10-15k
Instagram- f30_luca
      10-15-2020, 08:17 AM   #15
Tech UnRaveled
Drives: BMW 440i
Thanks, now I am on the hunt for the best priced VRSF downpipe.
      10-15-2020, 08:18 AM   #16
luca10
luca10's Avatar
Check out x-ph, they usually have good sales, and I think they have 5% off with code 5off
Instagram- f30_luca
      10-15-2020, 10:09 AM   #17
Tech UnRaveled
Drives: BMW 440i
ok, I ordered the downpipe, and cai and stage 2 is already downloaded on my phone.
I tried searching but didn't find the answer. Are there any Here's my dyno threads?
      11-13-2020, 12:54 PM   #18
Hkilla00
Drives: Bmw 340i
Might be selling my big boost stage 4 kit at the discounted price driven less then 200kms if your interested
      11-20-2020, 12:28 PM   #19
Supr3me
Supr3me's Avatar
Drives: Your mom crazy
Catching up a little late here. +1 for VRSF catless and for Dorch stage 2 hpfp. And for ethanol. Hopefully it's available in your area because it makes a huge difference.
I don't know of a dedicated dyno thread, especially because dyno readings can vary so much from car to car, dyno to dyno, DA to DA.... etc etc. Comparing two different dynos for two different cars isn't that useful. If you're just generally curious, up to about 500 WHP is possible on stock turbo with max-effort supporting mods, custom tune, etc. But it will definitely shorten the life of your turbo. Well above 600 WHP is possible with upgraded hybrid turbos, but you'll start running into limitations from the rest of the vehicle much over 600 WHP.
If you are competitive by nature I recommend getting a Dragy and subscribing to the 100-200 kph thread as it's the best apples to apples way of understanding how well your car (and your driving technique) is performing for the mods you've done.
GL!
2016 340i xDrive M-Sport MPPSK
Pure800; Dorch Stg2 hpfp; VRSF DP; AP intake
MHD; Wedge Performance E50 tune; xHP Stage 3
Forgestar wheels & KW coilovers
10.45 1/4; 2.75 0-60mph
