Login
11-04-2020, 05:11 PM | #2 |
![]() ![]() ![]() ![]() 286
Rep 785
The physical replacement is easy, 15 mins each, tops. They pull out by hand.
Be extra careful with the fuel return clips on top. They can get fragile and break. Simply clean the bore if it's dirty, do not grind or anything invasive like that!!!! Original injector is lubed on the outside with some grease, you should do the same. Coding depends on what tools you have. It's as hard as typing in a few numbers and letters.
-2014 328d Wagon 2WD, 8HP flash, self-tuned, 270hp/430ft-lbs.
-2019 M2 Competition, Alpine White. Self-tuned 530hp Others: -E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe. |
11-20-2020, 08:17 PM | #3 | |
![]() ![]() 84
Rep 181
Max |
11-21-2020, 02:13 PM | #4 |
Rep 785
It's basically a registering the new code that is inscribed on the injector body, into the engine ecu with BMW diagnosis software.
Usually you can use ISTA-D or even Tool32. Some mobile diag apps may do it too. |
11-21-2020, 06:31 PM | #5 | |
![]() ![]() 84
Rep 181
*EDIT* contacted BimmerLink support and this function is not supported Max Last edited by clemsonf31; 11-23-2020 at 04:54 AM.. |
