11-14-2020, 07:14 PM | #45 | |
Rep 2,653
11-14-2020, 07:17 PM | #46 |
Rep 2,653
I gotta get an analyzer... I won't know E content in my tank after adding a gallon of 93. It's a guessing game after that.
11-14-2020, 07:54 PM | #47 |
Rep 1,288
amazon has the tester and the hose... lol... it's the only way to really know what your car will run on.. then you can always mix for that... E20 is pretty simple for me... 2 gallons per tank... E30 is 4 gallons per tank... I think if you went that formula it will work cause you added 4.21 the first time right? it would be a 1/2 gallon of E per 1/8 of tank to fill then.. pretty easy... so 3/8 of a tank would be 2.5 gallons... 1/4 tank would be 3 gallons... then your fuel pressure should be okay... maybe.... might have to lighten it up a little more... logs will tell... but for the most part should work..
11-14-2020, 07:59 PM | #48 | |
Rep 2,653
11-14-2020, 08:07 PM | #49 | |
Rep 1,288
I also read somewhere 3.8 gallons was the magic number for E30 for these cars... go the 4 gallon route and log... now that I think about it... I calculated I was on the edge of E19/E20 when I added the 2 gallons since I burnt 2 gallons already when I added... |
11-14-2020, 08:10 PM | #50 | |
Rep 2,653
11-14-2020, 08:16 PM | #51 |
Rep 1,288
If you want to run E20 ... yeah... but your tune is for E30... this was your first full tank ...no? ... or you only did a 3/4 tank or something? ... for E30 full tank would of been 4.21 by the calculator for the first ever fill up... but I think you got the picture... for now just add the gallon and log it.. 1st/2nd pull you don't really need to go over 45/50mph ... basically can do it anywhere... I think the 1/8tank =1/2 gallon E is safe if you want to be lazy for E30
11-14-2020, 08:23 PM | #52 | |
Rep 2,653
11-14-2020, 08:51 PM | #53 | |
Rep 1,288
11-14-2020, 08:57 PM | #54 | ||
Rep 2,653
11-14-2020, 09:03 PM | #55 | |
Rep 1,288
Actually fill it up to 3/4 on the nose and the rest "E" and it should be just about perfect... |
11-14-2020, 09:07 PM | #56 | ||
Rep 2,653
Here's the thing. If my logs still look like this can I run a E20 mix with the E30 map or are we looking at an upgraded HPFP?
11-14-2020, 09:15 PM | #57 | ||
Rep 2,653
11-14-2020, 09:23 PM | #58 | |
Rep 1,288
As for the fuel pump.. looking at JerryBMW... he was dipping into the high 1800s with a spool 150... that's why I'd go dorch 2 or spool 180... now do I have to add a new lpfp???... don't know yet... or just go WMI... I haven't heard anyone complaining about WMI so might just go that route... or just be content with everything as it stands... yea right... lol.... I can order BoostJuice from amazon prime... lol... Last edited by FastF30; 11-14-2020 at 09:51 PM.. |
11-14-2020, 09:28 PM | #59 |
Rep 1,288
11-14-2020, 09:56 PM | #60 | |
Rep 4,140
11-14-2020, 09:59 PM | #61 | |
Rep 2,653
11-14-2020, 10:01 PM | #62 |
Rep 1,288
11-14-2020, 10:02 PM | #63 |
Rep 1,288
11-14-2020, 10:03 PM | #64 |
Rep 1,288
11-14-2020, 10:05 PM | #65 |
Rep 1,288
AmuroRay2270.50 |
11-14-2020, 10:08 PM | #66 |
Rep 2,653
