11-16-2020, 12:54 AM | #1 |
Rep 22
(won't crank only clicks 1-2 times and buzzs)
(just replaced my battery, starter, and alternator) car started for 1 whole day with a small knock it stalled out when i engaged the brake for the second time after driving around for a hour and wouldn't start again any suggestions what to check?
Izaak Latta
11-16-2020, 07:27 AM | #2 |
Rep 16,082
That's the classic dead battery symptom, where it doesn't even have enough juice to engage the starter solenoid. You need to charge the battery, then when the car's running test the alternator output.
Missouri_f301.00 |
11-16-2020, 02:22 PM | #3 | |
Rep 22
Izaak Latta
01-18-2021, 07:27 PM | #4 |
Rep 22
into 2021 now i still some what clueless but the starter clicks and buzzs for 8-10 seconds and stops i have some copper or plastic shavings in my oil too but im well over 130k miles with the stock timing chain
Izaak Latta
01-18-2021, 09:49 PM | #5 |
Rep 16,082
If the battery is good and it does that it could be loose or corroded cable connections at the battery or the solenoid or a solenoid that's toast. Any kind of shavings in the oil is bad news.
