Login
11-17-2020, 12:31 AM | #1 |
![]() 43
Rep 109
Do I need a transmission cooler? (ZF 8HP50)
Greetings,
I recently started tracking my car more often and was wondering if I could add a transmission cooler to my 2016 340i. I push my car to the limit on the track, but was wondering if a transmission cooler is really needed? What is the typical operating temp or normal temps on the 8HP50? Any feedback greatly appreciated!
340i RWD (IG @340i_pa)
AFE Drop in Filter CTS Catless DP, Chargepipe & Heat Exchanger PTP Turbo Blanket: AEM Meth Kit: Custom Exhaust BM3 + XHP Last edited by Alan340; 11-17-2020 at 06:46 PM.. |
11-18-2020, 05:44 AM | #2 |
![]() ![]() 148
Rep 153
No matter how fast my car drove, the temperature at 8HP50 never rose above 90C
M140IX. Turbo VTT GС,Flash Wedge Steven.
xHP stage 3. CSF. Dorch 2. 100ron+30%E85,+WMI. 1620kg. 1/4ml 10.50s. 100/200 5.91s +8C. |
11-19-2020, 02:45 PM | #4 |
![]() 43
Rep 109
I am pretty sure I don't. The only auxiliary cooler I know I have is on the passenger side fog light vent, but from what I have read thats the engine oil cooler.
AFE Drop in Filter CTS Catless DP, Chargepipe & Heat Exchanger PTP Turbo Blanket: AEM Meth Kit: Custom Exhaust BM3 + XHP |
11-19-2020, 02:46 PM | #5 |
![]() 43
Rep 109
But do you have the transmission cooler or without it?
11-19-2020, 09:05 PM | #6 |
![]() ![]() 148
Rep 153
Here is my whole cooling circuit
11-20-2020, 07:43 AM | #7 |
![]() ![]() 52
Rep 157
The image on the right shows your trans cooler, the front drivers side cooler is a remote radiator.
Here is the remote radiator you're missing, it is not part of the transmission cooling system. https://www.realoem.com/bmw/enUS/sho...diagId=17_1012 Last edited by TheFanatic; 11-20-2020 at 07:51 AM.. |
11-20-2020, 11:04 AM | #9 |
![]() 43
Rep 109
Oh... well if that is the case then I guess all I would need is the radiator. I will double check anyways. Thank you!
11-23-2020, 07:52 AM | #10 |
![]() ![]() 52
Rep 157
The trans cooler isn't a front mount radiator but uses engine coolant to cool the transmission fluid. The two pictures that were posted show the trans cooler
11-23-2020, 12:20 PM | #12 | |
![]() ![]() 52
Rep 157
also its listed as a trans cooler in realoem https://www.realoem.com/bmw/enUS/sho...diagId=17_1013 |
11-24-2020, 07:46 AM | #14 |
![]() ![]() 148
Rep 153
I know. But our climate rarely pampers with heat in summer. Only two weeks in August. So the box temperature on the M140IX does not exceed 90C.
11-24-2020, 07:51 AM | #15 | |
![]() ![]() 52
Rep 157
The overwhelming majority is far below that, the engine is the last thing the coolant goes through before going to the radiator, if you're your coolant is at 200 degrees after it went through the radiator there wouldn't be enough room left in it to cool the engine properly and you'll overheat. |
11-24-2020, 07:58 AM | #16 |
![]() ![]() 52
Rep 157
This photo will help you greatly in understanding how radiators work.
11-25-2020, 01:27 PM | #18 |
![]() ![]() ![]() 329
Rep 573
Never any problems with it here either
11-26-2020, 10:33 AM | #19 |
![]() 43
Rep 109
I appreciate all the feedback! I will just leave the car as is then.
11-29-2020, 01:20 AM | #20 | |
Rep 2
Checked the tube connections, transmission use an independent cooler, to reduce the temperature of engine.
BDC Automotive Workshop China
12-07-2020, 01:59 PM | #21 |
Cheapskate
![]() 3251
Rep 4,296
Guys, there is a separate heat exchanger for the sport auto trans. It's #13. You'll see it in the kidney grilles, it's a thin heat exchanger mounted at the top edge of the main radiator.
12-08-2020, 08:32 AM | #22 |
![]() 43
Rep 109
Yeah exactly, that is what I was referring too. My model doesn't have that, but many say they have no issues with overheating without that radiator, so I guess it's not really needed?
