BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Stage 1 or 2? (91 fuel)
      11-19-2020, 06:48 PM   #1
BAKKI
Drives: 2017 440i
About to cop a tune for the F32 – either BM3 or MHD. I already have a CTS catted DP ready to go.
Now my question is if there's any drawbacks to going directly to stage 2 if:
- I only get 91 gas (CA)
- Car is a MT
- First time modding anything
I want to just go stage 2 if possible, but I'm wondering if I should start slow w/ stage 1, see how I like it, get used to shifting gears with the new power before moving up (worried about hitting the clutch limit). I'm also wondering if there are any technical drawbacks to running stage 2 on 91 gas, besides lower power which I'm fine with.
Help a noob out
      11-19-2020, 06:59 PM   #2
G.Newt
Drives: 340i xDrive 6-Speed
BM3 has ACN (Arizona, California, Nevada, and other low grade fuel) maps. So there is a Stage 2 91 ACN. You should have access to ethanol around you though. The ethanol maps are great, also, you can add a gallon or two to clean up timing and be able to run the regular maps (will need to log to verify).
And on regular Stage 2 91, my clutch started to slip. Replaced with 335is/550i clutch and moved to the Stage 2 E30 map. No slipping.
2016 340i xDrive 6-speed.
FBO. Stage 2 E30 BM3. 440hp / 515lb-ft (Mustang Dyno)
      11-19-2020, 07:37 PM   #3
BAKKI
Drives: 2017 440i
@G.Newt thanks that's good to know. Were you experiencing slippage frequently or only when you were really slamming through the gears? I'm hoping to avoid replacing the clutch if I can help it. If it's the former then maybe I should play it safe and stick to Stage 1
I've also heard some people having luck with just a CDV delete on the stock f30 clutch https://f30.bimmerpost.com/forums/sh...1628178&page=3
      11-19-2020, 08:16 PM   #4
G.Newt
On the FB group, all of us B58 6MT owners have had to upgrade the clutch. It's a necessity at this point.
      11-19-2020, 09:00 PM   #5
chrisp3
Drives: 340i MT
+1. Thank you for your service
Had to replace mine as soon as stage 2+ was loaded up
      11-20-2020, 08:27 AM   #6
mike@x-ph.com
mike@x-ph.com's Avatar
Drives: 2007 e92 335i / 2013 F30 328
Expected gains with each stage (bootmod3)
Stage 1 91 octane: up to 18% HP / 26% TQ
Stage 1 93 octane: up to 20% HP / 26% TQ
Stage 1 E30 octane: up to 25% HP / 30% TQ
Stage 2 91 octane: up to 24% HP / 32% TQ
Stage 2 93 octane: up to 26% HP / 32% TQ
Stage 2 E30 octane: up to 30% HP / 35% TQ
Stage 2 Racegas: up to 30% HP / 35% TQ
Stage 2+ 91 octane: up to 37% HP / 62% TQ
Stage 2+ 93 octane: up to 43%HP / 68% TQ
Stage 2+ E30 octane: up to 47%HP / 73% TQ
      11-21-2020, 02:58 PM   #7
BAKKI
Drives: 2017 440i
Have you ever seen anyone go Stage 1 + DP? What kind of power could I expect with that setup?
      11-21-2020, 06:37 PM   #8
mike@x-ph.com
Never tried it, i would assume ~ 10whp more than stage 1
      11-22-2020, 12:26 PM   #9
Ifellapart
Drives: BMW 340i
Thic whips on youtube actually has an intresting video ont his for his supra.
he dynod the car in stage 1 and 2 with the same mods (dp, intake) and got the exact same number in both stages.
In other threads i've seen, it seems the difference between the two stages is more about timing. In stage 2 you actually will run lower boost but wider timing to allow more air to go in. If this is true i guess stage 2 is technically "safer" as it's not pushing your turbo too hard.
2016 340i / M-Sport / Track Handling Package / MPPSK
      11-23-2020, 01:31 PM   #10
BAKKI
Drives: 2017 440i
Ifellapart That's really interesting. I assumed stage 1+DP would still be more conservative than stage 2+DP. Could you link me to the timing discussion?
I'm curious if there are differences in AFR as well -- maybe one of the maps runs richer? (Though the video shows pretty much identical between 1 and 2)
      11-24-2020, 03:13 PM   #11
TheFanatic
TheFanatic's Avatar
Drives: BMW 340i
when I switched from a 91 tune to a 93 tune (stage 2) I gained 32hp and 31tq.
Granted fueling is important but we are all under the impression that stage 2 makes more power because it has to have less back pressure from a catless or high flow DP. I would be curious to see other peoples results.
      11-25-2020, 02:42 AM   #12
eluded
2JZ-GTE
eluded's Avatar
Bulgaria
2450
Drives: 340 6MT
91cali fuel is really bad and this engine loves timing.
