02-13-2018, 04:29 PM | #45 | |
Rep 1,348
So I figure I will get sways ,the bushings,strut tower bars,Dinan springs,Dinan Shockware and hopefully I will be all set before adding a tune for more hp. I think the suspension should always be a cars first mod. I thank you guys for the Bushing link. Please continue with your updates
2k15 335i Msport xdrive 6spd
02-18-2018, 01:26 AM | #46 |
Rep 1,291
Way to go
I always believed chassis is the first thing to do, for now my car DME is untouched, if you except a short foray into JB4 territory that i didn't really like (great product tbh, just not the way i like to do things)
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
03-29-2018, 12:05 PM | #47 |
Rep 1,348
I was surprised when I read in one of your threads that you did not like the H&R sway bars. I just purchased the rear. Just received my ASC springs,then powerflex bushings next. So I guess I will get the yellow inserts. I am hoping that this combo will make a difference.
03-29-2018, 12:30 PM | #48 | |
Rep 1,348
03-29-2018, 12:43 PM | #49 |
Rep 1,291
Not sure, price wise it should be about $30 per bushing not $70
https://www.powerflex.co.uk/road-ser...s+-3189/1.html
03-29-2018, 12:47 PM | #50 | |
Rep 1,291
03-29-2018, 01:06 PM | #51 | |
Rep 1,348
03-29-2018, 01:08 PM | #52 |
Rep 1,348
Would just changing the sway bar bushings on the front sway bar help alot also?
03-29-2018, 01:28 PM | #53 | ||
Rep 1,291
03-29-2018, 01:31 PM | #54 |
Rep 1,348
Ok thanks for pointing that out. I had emailed them like 5 minutes ago so they will perhaps respond as well. thanks
03-29-2018, 04:20 PM | #55 |
Rep 1,597
I think it is better to wait until the bushings wear to upgrade them. Many upgrade effects are psychological. The bushings are just rubber or PU dampers. Sure they can be more or less elastic but Bee Pee's subframe braces would contribute more to stability of the rear subframe under high speed cornering and shocks. This was brought up by M-engineer Biermann in discussing the chassis upgrades for the M4. Most of its effect still will not be felt unless tracked hard.
Polo088161610.00 |
03-30-2018, 12:57 PM | #56 | ||
2006 TIME Person Of The Year
9720
Rep 6,445
03-30-2018, 04:38 PM | #57 | |||
Rep 1,291
With rear being more tolerant i also get better rear end grip; and with the LSD i get oversteer on throttle, so i think it should work out. At least that's how i remember from when i got the front end bar fitted alone, before doing the rear end which led to car balance being thrown away anytime the surface was uneven which is basically almost all the time on the road.
07-28-2020, 06:08 AM | #58 |
Rep 241
DVC,
Looks like it's been a few years now - how are these holding up for you? I am planning install in the next couple weeks at the same time as a Wavetrac in my RWD 6MT N55. Thanks! |
07-29-2020, 11:09 AM | #59 |
Diligentia Vis Celeritas
558
Rep 1,477
Drives: 335i
They have been rock solid - no issues.
05-04-2021, 03:41 AM | #61 |
Rep 3,947
Anyone have any thoughts between solid aluminum bushings vs the Delrin/Aluminum combinations from Bimmerworld or Turner Motorsports?
The Bimmerworld Aluminum/Delrin bushings are out of stock right now with no expected inventory for another 4-6 weeks. |
05-04-2021, 11:40 AM | #62 |
Rep 320
What about AKG? They make a 75D polyurethane subframe bushing...75D is rediculously stiff.
Pussiwillow521.00 |
05-04-2021, 01:55 PM | #63 |
Rep 1,148
I say go akg, very good products, used them exclusively in the past on other chassis and have some products from them for this chassis, never had a bad experience and 75D is amazing stuff, from what I hear, they should pop in pretty easily to
05-04-2021, 08:02 PM | #64 |
Rep 1,004
go whiteline or supepro poly
https://www.amazon.com/dp/B00BED6TAW...v_ov_lig_dp_it https://www.amazon.com/dp/B06XP38TNY...v_ov_lig_dp_it |
