10-09-2020, 12:49 PM | #23 | |
Rep 1,109
Drives: 2015 BMW 435i Xdrive MSport
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
10-09-2020, 02:29 PM | #24 | ||
Rep 1,934
10-09-2020, 04:23 PM | #25 |
Rep 833
Drives: BMW F36, E36, E93
Somebody did a great job here:
https://f30.bimmerpost.com/forums/sh...d.php?t=858607 Rotors bigger than 340 at the front will require 18" wheels.
Such Fun
If you finde any spelling mistakes in my posts you may keep them, no return required |
10-09-2020, 07:47 PM | #26 |
Rep 895
I had 340/330 in my car and after i retrofitted 370/345 I couldnt tell the difference between coding and not coding spbr.
10-10-2020, 05:55 AM | #27 |
Rep 74
I clearly wrote that will be 340mm front, 345mm rear.
They DO fit with 17”. Stock Bmw 17” wheels come with this combo two. My question was only about rear discs which they change depending on drum’s size which can vary between 160 or 185 mm. This is my only question and i have explained it on first message.. |
10-10-2020, 05:57 AM | #28 |
Rep 74
04-07-2021, 07:22 AM | #30 |
Rep 9
Hi, I have a 2013 330d with standard 1 piston brakes all round and 18 inch rims.
I believe one or both of my front calipers may be fu****d as I replaced the disks and pads around 1000 miles ago and I have already started to get severe juddering under braking as previously (hence why I replaced them). I also occasionally can hear brake squeal which tells me one of the pads is in contact with one of the disks. I want to retain the 18 inch wheels (pothole Britain), and have found out I can have the 340mm brake upgrade. I know now some 335d and 335i cars have front 340mm Brembo with single piston rear caliper and 330mm disk. Therefore I want to upgrade my front brakes to 340mm brembo and not touch the rears. Do I still need to carry out the coding after installing the 340mm brembo? Do I need to upgrade the master cylinder? I have read various threads but have not found a definitive answer. Thank you |
05-12-2021, 08:35 PM | #31 |
Rep 4
Drives: BMW F30 320d M Sport
In the Thai F30 model mostly the handbrake is 160mm.
But there is an alternative solution for M Performance BBK with 345x24mm disc (drum size 185mm) By (Picture) Sleeve |
05-27-2021, 02:27 AM | #32 | |
Great Teacher
1076
Rep 1,303
Drives: 06 e91 325ix
You will need to find out if you can use the 330s, if not you could still do 340s but it would throw the brake balance off.
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
