05-14-2021, 11:51 AM | #1 |
Rep 141
Drives: 2019 440i | 2020 X3 X30i
N55 EWG Wastegate Replacement
Just for clarification my 435 has been mechanically stock since new and is used as a daily since my E92 N54 likes to break something every 5 miles
Since last July I've been hearing a strange knocking/ticking sound when I hit boost and at first I thought it was the motor making some strange sound but I guess I was wrong because two weeks ago, I got a drivetrain malfunction and when I scanned for codes it said "123511 - Electric Wastegate, wastegate flap: sluggish" so I figured okay it's the wastegate going bad.. However I cannot find many other N55 EWG owners who experienced this, fast forward to today the wastegate acted up again and I got the drivetrain malfunction with the same exact code.. and this time I got another code for charge air pressure too low (keep in mind I didn't drive the car for a week because I was using the E92) Has anybody DIY replaced the EWG on the N55? I only found videos pertaining to the N20 wastegates but nothing on the N55, and most forum posts I found were regarding the PWG so that was no help. Also, is this rare for an EWG to go bad on an N55? What are the odds my 435 wastegate goes bad before my rattling N54 wastegates
2019 F36 440xi B58 | 2011 E90 328xi N51 | 2010 E92 335xi N54 (sold) | 2015 F32 435xi N55 (sold) | 2020 G01 X3 30i B46 | 1996 E36 328iS M52 (RIP)
05-14-2021, 12:02 PM | #2 | |
Rep 67
10-14-2021, 11:52 AM | #3 |
Rep 3
Hey! Running into the same exact issue now. Code p126b, as well as under boost codes. Some place saying has to be done at a dealership but may have to replace turbo. Saw an N20 on here say they just reprogrammed the EWG. What was the result of this? Thanks!
10-15-2021, 07:18 AM | #4 |
Rep 67
I had to get my wastegate re adjusted using the BMW ISTA software it told you exactly how many millimeters it needed to be adjusted been squared away ever since.
10-25-2021, 12:52 PM | #5 |
Rep 3
DEALERSHIP
Took it to the dealership they quoted 1600 to replace the actuator, not many options as I took it to several shops, not near any BMW specialized shops as I'm in school right now.
10-25-2021, 01:02 PM | #6 |
Rep 87
Hey, take a look at my last post,
Same codes, So for the first one, I found out my charge pipe blew a clamp, got that fixed for the remainder, I had to get my wastegate adjusted accoridngly to ISTA, I highly doubt your wastegate is shot, and most likely just need to be calibrated or adjusted. I'm on a 2015 335i. Also when you clear the codes, do they all disappear or stay? as when I would go to clear my Wastegate codes, none of them would disappear and just stay there untill I kept restarting it till it wasn't in limp. |
10-25-2021, 02:08 PM | #7 |
Rep 141
Hey I got rid of my 435 shortly after making this post and now own a 440. But back then every time I cleared the code it would come back every few days and it would rattle under boost, not sure if the new owner fixed the issue (hopefully lol)
So refreshing though I have not had a single issue with my B58 compared to my N54 and N55.
terryd5150507.00 |
10-25-2021, 03:18 PM | #8 | |
Rep 1,109
Drives: 2015 BMW 435i Xdrive MSport
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
