11-24-2015, 04:22 PM | #1 |
Rep 138
"Read (VCM)" versus "READ (ECU)"
So I'm preparing my knowledge to code the car myself. I purchased a cable on Ebay and got an instruction from here http://www.bmwesys.com/guides/
In this guide they use E-Sys 3.26 and ESysLauncher 2.3.0 I also found another guide with E-Sys 3.27 and ESysLauncher 2.4.3 Both provides very clear steps, however the one on top tells me to use "READ (ECU)" and the one below uses "Read (VCM)". I wonder what do they mean? Thanks all Last edited by casperM4; 11-24-2015 at 05:00 PM.. |
11-25-2015, 05:17 AM | #2 |
Rep 3,227
ECU - engine control unit
VCM - vehicle control module Our man Knightsabers has put together a coding tutorial which you can find here. http://f30.bimmerpost.com/forums/sho...1177641&page=5 Follow this and you will be sweet. |
11-27-2015, 08:23 AM | #4 | |
Rep 1,980
Drives: 2020 G20 320i M Sport
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
12-12-2015, 12:53 PM | #5 | |
Rep 902
Drives: 13' F30 385xi VNV Speed Custom
Garage List 2013 Mercedes SL63 ... [0.00]
2010 VW Tiguan 2.0 ... [0.00] 2015 Tesla P85D [0.00] 2014 Mercedes S63 AMG [0.00] 2007 Mercedes GL450 [0.00] 1967 Ford Mustang [0.00] 2013 BMW F30 335xi [0.00] |
This confused me quite a bit at the start as well.
13' 335xi, ACF Tuned, ACF Stage 3 Turbo Kit (67mm),PDU PI, ACF Stage 4 LPFP, M-Perf Brakes, AEM CM10 Meth/Nitro, CG DR-1 + VS-1 3.5" Turboback, AFe S2 CAI+Ram Scoop, ER Chargepipe, Wagner EVOII Comp. FMIC, Stop-Tech SS Brake Lines, BMS Sport Oil Cooler Valve+Spacers F10mm R15mm, 19" Bridgestone Potenzas, KW EDC Coilovers, CF Seibon Hood + CSL trunk. Track:Pagid Race Pads, Stop-Tech Custom Pads Front+Rear Racing Tow Hooks
12-12-2015, 07:14 PM | #7 |
Rep 902
I can only add that I always "Read ECU"
