10-16-2018, 02:47 PM | #1 |
Rep 272
Door squeaking
So my F30 LCI went in for the squeaky door trim, was given some "BMW Silicone remover concentrate" fixes it for a couple of days and then its back with vengeance. has anyone else received different? I'm feeling like I've just been fobbed off
Brad |
10-17-2018, 01:58 AM | #3 |
Rep 448
Drives: G20 330i M Sport
Door squeaking
I have the same problem. (2017 335) Took it to the dealer 3 weeks ago for them to check. Its going back on Friday to replace all seals.
10-17-2018, 03:20 PM | #5 |
Rep 797
Current: 21 G21 330e | Portimao Blue | 791 M | M Sport Pro | Vis/Tech/Comfort Plus packs
Previously: 19 F20 M140i Shadow Edition | EB II || 16 F31 340i | EB II || 13 F31 330d Luxury | MG |
10-20-2018, 11:11 AM | #6 |
Rep 448
All seals replaced and seems to have done the trick but only time will tell
10-21-2018, 06:04 AM | #7 |
Rep 2,060
teaston posted on previous threads about using Gummi Pfledge to treat the seals.
I tried this and it seems to have worked on mine albeit it does need re-applying every so often. |
JustChris17487.50 Blacktemplar3481.00 |
10-21-2018, 06:20 AM | #8 |
Rep 1,162
10-21-2018, 06:37 AM | #9 | |
Rep 25,114
My car made front page of Bimmerpost
11-04-2018, 09:53 AM | #10 |
Rep 631
Hi, same for mine, squeaky/creaky doors, went to my local dealer, he applied very expensive @ £80 pm tape to all doors. Now squeak free, although he did comment that the centre HK speaker needed to be replaced. Gotta love a warranty.
11-05-2018, 07:56 AM | #11 | |
Rep 3,691
Annoyingly, if I drop the driver's window even by a mm or two the creaking on that side stops. Driving me mad at the moment, so need to get it into the dealer for a tape/renew seals job. Anyone had this done at Harry Fairbairn in Giffnock? |
11-05-2018, 08:30 AM | #12 |
Jeff
318
Rep 1,451
I have mentioned several times in the past that I have cured my last 2 cars now - simply by applying some lubricant to the felt strip across the top of each door.
Before that I tried the entire seals and it seems (to me) that the felt is the main culprit. For the sake of 10 minutes work and some grease or oil, just try it and see if it works. |
11-05-2018, 02:18 PM | #13 |
Old Fart
361
Rep 694
Mine started squeaking while on holiday, all I had was some plumbers silicon lubricant (no, I had been doing some plumbing for a mate), so I blathered the felt bit of the seals then wiped the excess off later.
That was the beginning of last month and they're still silent..... What worries me more is that the car is so damn flexible as to cause this issue in the first place
The doctors said it's OK to listen to the voices..... just don't do what they tell me
