10-17-2018, 09:32 PM | #1 |
Rep 541
New (old) tires - Unsafe?
Hello, I found a set of Michelin PSS from a shop that closed down and is getting rid of old inventory. The tires are brand new and still have the stickers on them but the production date is 0613, meaning they are a little over 5 years old.
Price aside, are these safe? They look perfect but I am weary of the production date.
Now: 2012 F30 335i / 6MT / JB4 / ER Catless DP
Sold: 2010 Jeep GC SRT8 Sold: 2007 E90 335i / 6MT / JB4 / Vishnu Exhaust / VMR 710 19" / BMS DCI / HKS Blow Off Valve / Tinted Tails / Clutch Stop |
10-18-2018, 02:12 PM | #2 |
Rep 233
I think the service limit on tires is 6 years. So the ones you're looking at are pushing it, even if they've never been mounted. Personally I wouldn't do it.
https://www.discounttire.com/learn/tire-aging |
10-19-2018, 07:14 AM | #3 |
Rep 3,679
I'd wouldn't. You don't want to play around with potentially dangerous tires.
10-19-2018, 09:35 AM | #5 |
Rep 1,045
In my experience, they are fine to use, the date attached to any tire is a marketing gimmick, they want to make more money off you. Make sure the tires weren't stored in extreme heat or cold, do a visual inspection for cracks, if it all checks out, its perfectly fine to use for its entire tread life. Tires these days are made to a very high standard, mainly due to something call lawsuit that forced them to be, and this isn't engine oil we're talking about that accumulates contaminants even without driving. Tires are tires. I'm an engineer, and thats my 2 cents.
Mods: Dinan Tuned, Intake, Catless DP
10-21-2018, 01:04 PM | #6 | |
Rep 3,679
kern4174446.50 |
10-23-2018, 11:23 AM | #7 |
Rep 192
As long as you know what you're wearing and drive accordingly, I don't think it should be any issue.
Every time there is tire talk it seems like unless you're short of running semi-slicks, you're gonna crash and burn. We forget the world is filled mostly with cars running 60 dollar tires. Thing is, the people buying those tires sure as heck aren't exploring the limits of grip on a daily basis. If they're cheap enough, I'd say go for it. Lean on them slowly at the beginning and see how, when and how fast they let go. I've never worn anything other than UHP summer tires during the 14 years i've been driving except for the last set on my last car, which were "norauto" brand, which is the spanish equivalent of buying walmart brand tires and I was surprised by how much they gripped and how well they handled. I've always adjusted my driving to the equipment I was driving and I've been fine. The only time I've ever felt "betrayed" by a tire? Once, by a set of very, very fresh (manufactured 2 months prior and with 1500 miles on them) Michelin PS3s, which were supposed to be AMAZING in the wet and had me aquaplaning at 65mph on a very very shallow puddle... |
10-23-2018, 11:47 AM | #8 |
Rep 287
I run a set of 0613 PSS on my 400m wheels (225/45 square set) and I have had no issues. I only run them in the summer and they stay in my climate controlled garage the rest of the year. That being said.. I wouldn't run out and do a high speed track day on them, but they are fine for spirited street use. I say do a visual inspection, if they look good mount them up and learn the limits of them.
10-23-2018, 12:04 PM | #9 |
Rep 541
Thanks all for the feedback. I ended up passing on the set. I'm sure they are fine but decided to go with something else. Thanks again!
10-23-2018, 01:21 PM | #10 |
Rep 775
Good man, old rubber is not a good thing.
Enjoy the Drive,
Steven 2014 435i M-Opt, M LSD, Dinan CAI/IC/BTurbo/Stage 4, ER TIC/CP, GFB DV+, Fabspeed HJS cat DP & Mich PS4S. |
10-23-2018, 02:38 PM | #11 | |
Rep 3,679
I don't mean to say it like this but I don't know how else to: just because you can't feel the degradation of grip with age doesn't mean it's not there. I'm no Matt Farah either, and it's no fault of yours, but tires do grip less and perform worse with age. The rubber gets harder and dryer with age, and it will inevitably start to function worse than a same model newer tire (just talking about age not treadwear). The CGT that Paul Walker was in when he died had 9 y/o tires on it, and they were probably a major catalyst to the crash. 9 years old is pretty damn old, but the same effect can start to happen with 6-7 year old tires. It's also about the fact that old rubber and structural elements of the tires are prone to failure at old age, aka blowouts and tread separation. It's rare, but it's certainly possible and something to avoid. Bottom line: old tires are unsafe. If you want to gamble with them so be it, but I wouldn't advocate that others do the same.
10-23-2018, 02:46 PM | #12 |
Rep 400
I've seen tire flower pots, that are over 15 years old lol no sign of this so called decay everyone is speaking of lol. There is also an old man in my neighborhood with a 99 Camry, with about 87,000kms mint condition with OEM tires (he does have winters)!! I dunno how those OEM tries still function, SMH, word on the street he is changing them this year lol.
10-24-2018, 05:12 AM | #13 | |
Rep 192
10-24-2018, 06:35 AM | #14 |
Rep 3,679
Depending on how old of a tire, probably. A rock hard 8 y/o HPS tire will be less dynamically reliable than a brand new budget basement tire. And more prone to sudden failure.
10-24-2018, 06:46 AM | #15 |
That Libertarian Guy
4039
Rep 6,363
Old tirer have a higher chance of blow outs and are more susceptible to getting puncher. My sister just recently made this mistake and I warn her, she being cheap ignored me and two of the four tirer blow out 5 month after mounting
10-24-2018, 06:55 AM | #16 |
Cheapskate
4447
Rep 4,993
Stop referencing anomalies like they prove the rule of thumb wrong. There's scientific evidence that tires degrade with age just like everything else has a shelf life. Just because you heard somebody has 20 year old tires and somehow gets by doesn't make it right, or safe. It only takes 1 day for that luck to catch up to you.
