BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > [TUTORIAL]Retrofit rear lights BMW F30/F31/F80 LCI
      10-08-2016, 11:40 AM   #45
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Originally Posted by rfcoolz View Post
Pictures are gone
what pictures ?
      10-24-2016, 08:48 PM   #46
Wunsch
Wunsch's Avatar
24
Drives: 2023 i4 M50
This tutorial is great, and I really appreciate it. Unfortunately, I'm finding that the inside of the hatch on the F31 is quite different from the liner inside the trunk lid on the F30. Does anybody have some tips on how to get at the inner lights on an F31?
      10-24-2016, 08:59 PM   #47
Gabreigns
Gabreigns's Avatar
494
Drives: F3x
PMd
      10-26-2016, 03:31 AM   #48
weytie
Drives: BMW M4 F82 Competition
Originally Posted by Gabreigns View Post
PMd
Can you also PM me this?
Thx
      11-04-2016, 04:15 PM   #49
weytie
As the install of the lights on a F31 is a bit more complicated then the F30, here some pics of the wiring for the inner lights.
Here is how I did the wiring.
The only parts you have to remove are the 2 sliding covers (where the lights are), the upper trim of the tailgate.
Also undo the trim where the concertina goes inside the tailgate.(there’s 1 torx screw under the rubber piece, the rest just clicks off). See picture.
Then i took out the inner taillight on the right side.
You can run the wiring of the left taillight tot he right side with a bith routing.
Then I inserted a flexible iron wire from the top of the tailgate tot he bottom of the tailgate where the inner light is.
This is very easy. Now you take the 2 wires and tape them tot he metal wire and pull the wire up and guide the wires easily to the top.
Once this is done, you take out the sealings of the rubber concertina on both sides.
I then sprayed some silicone spray in the concertina and on the wires to guide them easy through the concertina.
Actually this went really easy.
It’s just a matter of opening and closing the uper part of the tailgate and complete tailgate for easy acces of putting in the wires.
Then you release the 2 screw on the D pillar and pull off the rubber seal ( you have to pull strong to take off.
Now you take off the cover fort he battery to access the REM box.
I connected them directly to the connectors with a scotchlock tot he correct wires.
Put everything back together and done 
      12-04-2016, 12:57 PM   #50
Morasool
Morasool's Avatar
108
Drives: 335d xDrive - Mercedes S350
I've fitted these to mine now but I use the original BMW OEM Retrofit cable part no# 61122410220 it was only £40.
In have attached the original BMW fitting instructions for these lights using the original retrofit cable.
GCinFLA284.00
      12-11-2016, 07:29 AM   #51
Aj1000
AJ
Originally Posted by VinnyA320 View Post
Hey guys. I ran a new wire from each inner lci taillight to the box by the battery. Which slots do i put the wires in for the inner turn signals/ brake lights to work? The locations in this guide are currently already used in my F80 for the slot numbers.
Everything else is working besides that. Thanks!
I have run the 2 wires from inner lights to the REM. Where exactly do I plug these in the REM? Which connector and which slot? Did not quite get it.
      03-01-2017, 10:09 AM   #52
david51
david51's Avatar
France
538
Drives: bmw M3 F80
This is indicated on the first page
      03-19-2017, 04:19 PM   #53
Nomana
Nomana's Avatar
1466
What kind of flash on startup if i do not code?
Any vid?
I plan to install it myself since there's no shop around here and I'm too lazy to learn coding
      03-24-2017, 04:07 PM   #54
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Any vid?
The coding of new fires is not required, since there is no error on the idrive but against there will flicker flashing at each startup
      05-26-2017, 11:14 AM   #55
MrChang
Drives: F31 M-Sport MG 2014
Hello!
I am in the progress to install the lci taillights on my f31 and I am going to follow your instructions. But what parts of the tailgate inside trim do I need to remove? And do I need to remove the d-pillar trim? Thanks in advance.
      05-28-2017, 03:44 PM   #56
MrChang
Hello!
I installed the lights today without having to remove any trim panels except for the battery panel, the light covers and the left outside tailgate panel as shown on your photo. I manage to route the cables by using a steel wire (with plastic isolation) to drag the cable through. One issue I got (I dont think I have seen that been mentioned) was the LCI inner tail lights had a M8 screw instead of a M10. I manage to solve it by removing the flared M10 nut and replace it with a washer and M8 nut.
Next step will be coding.
      06-22-2017, 03:23 AM   #57
valtinpaul
Drives: bmw f30
lci taillights instalation
Hi. i downloaded the originalninstructions pdf from bmw. They wrote that you have to plug the 2 extra wires in the A174 13b pin 5 and pin 13.
Are there more options for the conection of the 2 wires?
      06-22-2017, 09:02 PM   #58
david51
david51's Avatar
France
538
Drives: bmw M3 F80
If you follow the procedure of the BMW document
Here is the coding to do
Just add to the HO-wort (HELD) and code REM
If after adding HELC and REM code does not work
It is necessary to modify as indicated
REM_01 > LceLampMapping1 3062 > MAPPING_BLINKER_H_L_FIXED_PWM = fixed
REM_01 > LceLampMapping1 3062 > MAPPING_BLINKER_H_L_PWM_LEVEL_1 = 13.7V [Default]
REM_01 > LceLampMapping1 3062 > MAPPING_BLINKER_H_R_FIXED_PWM = fixed
REM_01 > LceLampMapping1 3062 > MAPPING_BLINKER_H_R_PWM_LEVEL_1 = 13.7V [Default]
REM_01 > LceLampMapping1 3062 > MAPPING_BRAKEFORCED_L_FIXED_PWM = fixed
REM_01 > LceLampMapping1 3062 > MAPPING_BRAKEFORCED_L_PWM_LEVEL_1 = 100% [Default]
REM_01 > LceLampMapping1 3062 > MAPPING_BRAKEFORCED_R_FIXED_PWM = fixed
REM_01 > LceLampMapping1 3062 > MAPPING_BRAKEFORCED_R_PWM_LEVEL_1 = 100% [Default]
REM_01 > LceLampMapping1 3062 > MAPPING_BREMSL_L_FIXED_PWM = fixed
REM_01 > LceLampMapping1 3062 > MAPPING_BREMSL_L_PWM_LEVEL_1 = 13.5V [Default]
REM_01 > LceLampMapping1 3062 > MAPPING_BREMSL_R_FIXED_PWM = fixed
REM_01 > LceLampMapping1 3062 > MAPPING_BREMSL_R_PWM_LEVEL_1 = 13.5V [Default]
REM_01 > LceLampMapping2 3063 > MAPPING_NEBELSCHLUSSL_L_FIXED_PWM = fixed
REM_01 > LceLampMapping2 3063 > MAPPING_NEBELSCHLUSSL_L_PWM_LEVEL_1 = 13.5V [Default]
REM_01 > LceLampMapping2 3063 > MAPPING_NEBELSCHLUSSL_R_FIXED_PWM = fixed
REM_01 > LceLampMapping2 3063 > MAPPING_NEBELSCHLUSSL_R_PWM_LEVEL_1 = 13.5V [Default]
REM_01 > LceLampMapping2 3063 > MAPPING_RUECKFAHRL_L_PWM_LEVEL_1 = 13.7V [Default]
REM_01 > LceLampMapping2 3063 > MAPPING_RUECKFAHRL_R_PWM_LEVEL_1 = 13.7V [Default]
REM_01 > LceLampMapping2 3063 > MAPPING_UNIVERSAL_6_OUTPUT = sl_2_l
REM_01 > LceLampMapping2 3063 > MAPPING_UNIVERSAL_7_OUTPUT = sl_2_r
REM_01 > LceLampMapping2 3063 > MAPPING_UNIVERSAL_8_OUTPUT = bfd_l
REM_01 > LceLampMapping2 3063 > MAPPING_UNIVERSAL_9_OUTPUT = bfd_r
REM_01 > LceOutputChannels 3061 > BFD_L_CCM = ccm_blinker_l
REM_01 > LceOutputChannels 3061 > BFD_L_IS_LED = aktiv
REM_01 > LceOutputChannels 3061 > BFD_L_UE_SPG_SCHUTZ = dimmed
REM_01 > LceOutputChannels 3061 > BFD_R_CCM = ccm_blinker_r
REM_01 > LceOutputChannels 3061 > BFD_R_IS_LED = aktiv
REM_01 > LceOutputChannels 3061 > BFD_R_UE_SPG_SCHUTZ = dimmed
REM_01 > LceOutputChannels 3061 > BL_L_IS_LED = aktiv
REM_01 > LceOutputChannels 3061 > BL_L_KALTUEBERWACHUNG = nicht_aktiv
REM_01 > LceOutputChannels 3061 > BL_L_UE_SPG_SCHUTZ = nicht_aktiv
REM_01 > LceOutputChannels 3061 > BL_R_IS_LED = aktiv
REM_01 > LceOutputChannels 3061 > BL_R_KALTUEBERWACHUNG = nicht_aktiv
REM_01 > LceOutputChannels 3061 > BL_R_UE_SPG_SCHUTZ = nicht_aktiv
REM_01 > LceOutputChannels 3061 > FRA_H_L_IS_LED = aktiv
REM_01 > LceOutputChannels 3061 > FRA_H_L_KALTUEBERWACHUNG = nicht_aktiv
REM_01 > LceOutputChannels 3061 > FRA_H_L_WARMUEBERWACHUNG = aktiv [Default]
REM_01 > LceOutputChannels 3061 > FRA_H_R_IS_LED = aktiv
REM_01 > LceOutputChannels 3061 > FRA_H_R_KALTUEBERWACHUNG = nicht_aktiv
REM_01 > LceOutputChannels 3061 > FRA_H_R_WARMUEBERWACHUNG = aktiv [Default]
REM_01 > LceOutputChannels 3061 > NSL_L_IS_LED = aktiv
REM_01 > LceOutputChannels 3061 > NSL_L_KALTUEBERWACHUNG = nicht_aktiv
REM_01 > LceOutputChannels 3061 > NSL_L_UE_SPG_SCHUTZ = aktiv [Default]
REM_01 > LceOutputChannels 3061 > NSL_L_WARMUEBERWACHUNG = nicht_aktiv
REM_01 > LceOutputChannels 3061 > NSL_R_CCM = NEW_ccm_nsl_r
REM_01 > LceOutputChannels 3061 > NSL_R_IS_LED = aktiv
REM_01 > LceOutputChannels 3061 > NSL_R_KALTUEBERWACHUNG = nicht_aktiv
REM_01 > LceOutputChannels 3061 > NSL_R_UE_SPG_SCHUTZ = aktiv [Default]
REM_01 > LceOutputChannels 3061 > NSL_R_WARMUEBERWACHUNG = nicht_aktiv
REM_01 > LceOutputChannels 3061 > RFS_L_CCM = NEW_ccm_rfs_l
REM_01 > LceOutputChannels 3061 > SL_2_L_CCM = Fxx_ccm_sl_2_l
REM_01 > LceOutputChannels 3061 > SL_2_L_IS_LED = aktiv
REM_01 > LceOutputChannels 3061 > SL_2_R_CCM = Fxx_ccm_sl_2_r
REM_01 > LceOutputChannels 3061 > SL_2_R_IS_LED = aktiv
REM_01 > LceOutputChannels 3061 > SL_L_IS_LED = aktiv
REM_01 > LceOutputChannels 3061 > SL_R_IS_LED = aktiv
      06-30-2017, 09:02 PM   #59
Djmf30
Djmf30's Avatar
Drives: F30 few oem upgrades
I followed this and my inner blinkers won't function the brake light works but no inner blinker. Also lost the blink when lock/unlock
      07-01-2017, 05:50 AM   #60
gpdrama
gpdrama's Avatar
Greece
Drives: F30 316i
Just tick it on the iDrive menu, it deselected because of that coding.
      07-01-2017, 05:52 AM   #61
gpdrama
gpdrama's Avatar
Greece
Drives: F30 316i
Because of the 2 or 3 threads of the Mperformance tail lights on the forum, I asked the following and I leave it here for anyone who knows...
Originally Posted by gpdrama View Post
On the coding, does anyone know what exactly FRA_H (L & R) means and why should the FRA_H WARMUEBERWACHUNG be set to aktiv despite that all of the rest WARMUEBERWACHUNG options are set to nicht_aktiv ?
      07-01-2017, 09:35 AM   #62
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Did you connect the following wires correctly ?
      07-01-2017, 09:36 AM   #63
david51
david51's Avatar
France
538
Drives: bmw M3 F80
The fastest procedure and which works very well is on the first page
      07-01-2017, 09:43 AM   #64
Djmf30
Djmf30's Avatar
Hi yes I did connect blue and green cable to rem as instructed and coded rem 3061 for led flickering
I get no lamp errors on dash, all 4 pieces of the tail lights power on but when using the turn signals I don't see the inner led working.
      07-01-2017, 05:04 PM   #65
david51
david51's Avatar
France
538
Drives: bmw M3 F80
After adding HELC you have right click CODE on REM module ?
connect the wire of the inner light left to REM 174*12b pin17 and
and the wire of the inner light right to REM 174*14b pin12
Djmf301.50
      07-01-2017, 05:32 PM   #66
Djmf30
Djmf30's Avatar
Yes I fdl coded rem after adding HELC but that made no change. Yes I saw another post where they instead wired the inner tails to rem 174 12b pin 17 snd 174 14b pin 12 as you noted below. I know that's where the outer tails get power for turn signals. Sounds like that will be final solution. Be back with results thanks for the help
