03-29-2018, 09:38 AM | #1 |
Rep 10
F30 xDrive & 373m fitment help
As the title states, I'm currently looking at a set of 373m rims to put on my 2013 335i xDrive and tried to do so research before buying. Noticed that since my care is an xDrive that I needed to be careful on the wheels I add since it could damage the xDrive system. Wanted to know if there would be any issue if I put these wheels on especially since they are staggered.
These are the measurements.... Front Size: 20x8.5 Offset: 33mm Rear Size: 20x9 Offset: 44mm If there were no issues running these I also wanted to know what tire specs I should be running as well. Thanks in advance! |
03-29-2018, 09:48 AM | #2 |
Rep 4,325
235/35/20, 265/30/20
wdeerfield2745.00 |
03-29-2018, 10:03 AM | #3 |
A family of bimmers
2745
Rep 7,742
They will sit nice and flush without the need for spacers and running what alohasurftoad stated for tires sizes will be perfect.
Front fitment (compared to 400m): 2mm LESS clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 10mm Rear fitment (compared to 400m): 5mm LESS clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 7mm
03-29-2018, 10:10 PM | #5 |
Rep 4,325
235/35/20, 265/30/20, diameters are 26.5"/26.3" = 0.8% < 1.0% okay for x-drive.
forgot to add you may also run 245/30/20, 255/30/20, diameters 25.8"/26.0" = 0.8% difference, okay for x-drive, this is the best tire fitment for 8.5" and 9" widths. Last edited by alohasurftoad; 03-29-2018 at 10:23 PM.. |
