02-27-2016, 12:51 PM | #10033 |
Rep 41,044
You can Code DME with Motor off and no Charger. It takes only a minute, and Battery Voltage should be fine. Normally though, there is no reason to be coding DME though.
02-27-2016, 12:56 PM | #10034 |
Rep 208
Can anyone provide me a working tool32? Perhaps with an idiot proof install manual inclusive additional needed software? I have already tried 3 different versions but none of them worked. Rheingold & esys are working...
Thank you in advance! |
02-27-2016, 01:39 PM | #10035 |
Rep 41,044
PM sent.
02-27-2016, 01:53 PM | #10036 | |
Rep 1,201
Current - 2021 G20 330i M Sport+
Gone - 2017 F30 335d M Sport + in San Marino Blue Gone - 2015 F30 LCI 320d M Sport+ Step Auto Gone - 2012 F30 320 ED Gone - 2011 E87 118d |
02-27-2016, 02:36 PM | #10037 | |
Rep 10
But no progress with the Cruise Control. Still not working. Any ideas? Here are the ECUs under SVT tree: ACSM2(1),BDC_BODY(40),BDC_GW(10),BKOMBI(60),DME_BA C(12),DSC2(29),EGS(18),EPS(30),FLE(43),FLE(44),FZD (56),HKFM(d),HU_ENTRYNAV(63),ICAM2(6),IHKA3(78),PM A2(2c),TCB(61),ZBE3(67) I-step : F056-15-11-505 E-Sys ver 3.27.1 (build 44813) , PSdZ data ver. 5.01.02-2015-08-12T Extracted from ISTA-P version 3.57.3.002 Last edited by mekatu; 02-27-2016 at 02:57 PM.. Reason: ECUs under SVT |
02-27-2016, 11:55 PM | #10039 |
Rep 3
Drives: 2014 BMW 328i
I tried to enable enhanced bluetooth. But at the last step when I try to edit FDL, I get a error saying saying PIN is wrong and enter correct PIN. I tried couple of time deleting the token and recreating the token with different new PIN. But still it gives the error and am not able to proceed. Not sure where is it going wrong. I have followed all the steps in the installation guide. One possible cause could be "when I run Esys Launcher it does not automatically launch Esys for me I have to launch Esys seperately" i guess it is a related problem.Please let me know if any of you had similar issue and how to resolve
02-28-2016, 12:11 AM | #10040 | |
Rep 41,044
I have no idea why though Launcher is not not opening E-Sys in your case. If you can't figure it out, you will need to email the developer of E-Sys Launcher, TokenMaster, and ask him.
02-28-2016, 01:13 AM | #10041 |
Rep 3
Thanks for your response shawn! I tried a work around , invoked launcher from command prompt(will try to figure out actual issue later), this way it launches Esys automatically.. I hope it should fix the problem with PIN, will try to code and update soon.
Directory of C:\Program Files (x86)\TokenMaster\E-Sys Launcher Premium 02/27/2016 08:35 PM <DIR> . 02/27/2016 08:35 PM <DIR> .. 12/27/2015 04:33 AM 1,503,232 BouncyCastle.Crypto.dll 12/22/2015 10:59 PM 44,482,800 CafData.dat 01/06/2016 12:12 AM 5,940 Changelog.txt 10/03/2015 06:10 PM 150,352 Dat1.bin 01/05/2016 10:39 PM 173,264 Dat226FV.bin 01/05/2016 10:41 PM 114,576 Dat227FV.bin 01/05/2016 10:38 PM 117,584 Dat2FV.bin 01/05/2016 11:56 PM 514,010 E-Sys Launcher.pdf 01/06/2016 02:58 AM 1,497,088 ESysLauncher.exe 02/27/2016 08:35 PM <DIR> FDLCodes 01/02/2016 09:33 AM 101,779 FDLCodes.xml 03/22/2015 03:19 AM 196,608 ICSharpCode.SharpZipLib.dll 09/10/2014 09:37 PM 494,948 ICSharpCode.SharpZipLib.xml 10/05/2013 01:38 AM 455,328 msvcp120.dll 10/05/2013 01:38 AM 970,912 msvcr120.dll 01/05/2016 10:47 PM 77,312 PSdZAPI.dll 12/22/2015 10:55 PM 3,669,920 PSdZdata.dat 01/06/2016 02:58 AM 272,896 PSdZHandler.dll 05/07/2015 02:08 AM 2,771 ReadMe.txt 05/07/2015 01:58 AM 0 Un.lck 10/05/2013 01:38 AM 247,984 vccorlib120.dll 20 File(s) 55,049,304 bytes 3 Dir(s) 3,361,898,496 bytes free C:\Program Files (x86)\TokenMaster\E-Sys Launcher Premium>ESysLauncher.exe |
02-28-2016, 01:55 PM | #10043 |
Rep 41,044
PM sent.
02-28-2016, 05:06 PM | #10047 | |
Rep 41,044
02-28-2016, 08:22 PM | #10049 | |
Rep 1,236
02-28-2016, 09:59 PM | #10050 | ||
Rep 902
Drives: 13' F30 385xi VNV Speed Custom
Garage List 2013 Mercedes SL63 ... [0.00]
2010 VW Tiguan 2.0 ... [0.00] 2015 Tesla P85D [0.00] 2014 Mercedes S63 AMG [0.00] 2007 Mercedes GL450 [0.00] 1967 Ford Mustang [0.00] 2013 BMW F30 335xi [0.00] |
13' 335xi, ACF Tuned, ACF Stage 3 Turbo Kit (67mm),PDU PI, ACF Stage 4 LPFP, M-Perf Brakes, AEM CM10 Meth/Nitro, CG DR-1 + VS-1 3.5" Turboback, AFe S2 CAI+Ram Scoop, ER Chargepipe, Wagner EVOII Comp. FMIC, Stop-Tech SS Brake Lines, BMS Sport Oil Cooler Valve+Spacers F10mm R15mm, 19" Bridgestone Potenzas, KW EDC Coilovers, CF Seibon Hood + CSL trunk. Track:Pagid Race Pads, Stop-Tech Custom Pads Front+Rear Racing Tow Hooks
02-29-2016, 04:56 PM | #10052 |
Rep 41,044
02-29-2016, 05:48 PM | #10054 |
Rep 41,044
