11-29-2018, 04:51 PM | #1 |
Rep 39
REM ecu swap with different HWAP
Hi guys,
I have to replace REM due a reverse light malfunction not cadable on my F31, so I bought a used REM with different PN, here below the differences Installed: PN 61.35-9392700-01 HWAP 000000F4C HWEL 003.000.002 BTLD 003.029.030 SWFL 003.029.030 Used PN 61.35-9392702-01 HWAP 000000F4B HWEL 003.000.002 BTLD 003.029.030 SWFL 003.029.030 After install it i get 5 error in REM , one of this is 0080482E wrong hardware version. I save a backup configuration from old REM and then write it on the used Rem with BMAicoder but no result. Is it possible to change or coding HW configuration? If it's so, what i need to do? Thanks!!!!! |
11-30-2018, 12:18 AM | #4 |
Rep 2,302
For that you need E-Sys.
Then mark the REM and on the right side „detect caf for swe“. Choose the newest CAFD (highest Numbers) and OK. After that push the button „Code“. That‘s all. |
11-30-2018, 01:27 AM | #5 |
Rep 39
11-30-2018, 10:15 AM | #7 |
Rep 39
I get E-Sys 3.27 running on WIN10 but it has pin activation and i didn't find SWE option.
ISTA+ 4.10 (then 4.14 and 4.09) on WIN10 but it always get error The programming system could not be initializated. The ISTA installation may be damaged or incorrectly configured. I tried ISTA+ 4.12 on a virtual machine which running Win 7 but after test it report error : not enough system resources are available. Restart ista and computer. I cannot reinstall ISTA because it's a virtual disk downloaded, i don't have installation file or anything else about this. I think its easier sell the car and buy a FIAT💔 Does anybody could indicated a esys or ista version running by WIN10 tested on F31? whoever will help me I will propose him as a saint right away😁 |
11-30-2018, 10:26 AM | #8 | |
Rep 2,302
But for coding (not FDL coding) you don‘t need the launcher. So start E-Sys directly from its own folder (EC-Apps). Then you can start to code the REM. |
11-30-2018, 11:51 AM | #9 | |
Rep 39
Connected to car, read FA, read ECU but i cnnot select Detect CAF for SWE. |
11-30-2018, 01:26 PM | #11 |
Rep 39
Ah ok!
I'm sorry but i started now to work on my F31! I have three CAFD same as my REM need to be replaced. Which on have i to choose? Then CODE to the new one REM aftre conneted? Is it right? |
12-01-2018, 09:40 AM | #13 | |
Rep 39
On REM FAULT :0080482E wrong harware version. Is it possibile to change? How could i do it? |
12-01-2018, 01:16 PM | #14 |
Rep 2,302
Now I just found out that you wrote both part numbers wrong.
Instead of 61359392700 and 61359392702 you mean 61359329700 and 61359329702. So i finally found some information. I found the difference between them. The 61359329702 is missing the 8 pins for the PDC behind. The 61359329700 has these 8 Pins. And because you car has the PDC you will get this error. |
12-01-2018, 02:23 PM | #15 | |
Rep 39
Many thanks! How did you get this information? Anyway this means I can't configure used REM... If i solder missing pins do you think i get error anyway? Last chanches before buy same REM is replace IC from used REM to defective... |
12-01-2018, 02:37 PM | #16 |
Rep 2,302
Here you see the differences between the 2 REM.
I was searching on Ebay for a REM and found pictures for both part numbers. And i know the differences of the REM with PDC and without PDC. There is nothing you can solder. To solve your problem you now need another right REM or you renounce your PDC and code it out. |
12-02-2018, 02:28 PM | #18 |
Rep 39
I replaced IC which manage and control the light output with no result....
I think the problem is about the processor. Does any chanche to reprogramming or update SW of the ECU? |
05-14-2021, 07:25 AM | #19 | |
Rep 25
I'm planing to install rear sensors, but I stuck, which REM will be fit to my car... |
05-14-2021, 07:47 AM | #20 |
Rep 522
Check with your VIN number on realoem site and you will know which REM will be compatible with your car.
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
05-15-2021, 04:37 PM | #21 | |
Rep 25
From comment #16, on first picture REM 61359317175 cannot be found on that page/database, but from second picture REM 61359329700 is available... Any other idea? Last edited by pici192; 05-15-2021 at 04:46 PM.. |
05-16-2021, 03:44 AM | #22 | |
Rep 2,302
61359374506 61356809049 61356819332 61356819333 61359362398 61359362394 61359298959 61359866978 61359866982 61359329704 61359499001 |
