05-04-2021, 01:50 PM | #1 |
Rep 456
How to run E85?
I just picked up a 2016 328i last night. Is anyone running E85 in these? I did some searching, found threads where people say it needs a full fuel system upgrade, others say only a tune and its good. Gas prices where I am are $5 a gallon, E85 is 2. I usually ran about E50 in my M5 without a tune and it was fine.
2018 BMW M5
2018 Porsche GT3 2023 Porsche Macan S 2023 Porsche 911 Turbo S |
05-05-2021, 12:31 PM | #2 | |
Petrolhead
1945
Rep 3,521
Current:
2020 BMW 330i xDrive 2018 Audi SQ5 Prestige 2017 Audi A7 Prestige |
05-05-2021, 12:40 PM | #3 |
Shima Tatsuya
45
Rep 61
The n26 Sulev can run full e85 with the stock fuel system, from what I read on Jordan tuned website. In most places, the f3x 328i came with the n20, but some places like California have the n26. Same engine small differences to comply with emissions. I suspect the fuel system is one of these differences in n26 engines, and that is why it is possible to run full e85.
Current:'15 BSM F32 435i Msport, FBO, BM3 stg 2
Previous: E36 328i->F30 320i->F32 428i IG: Blackbird_f32 |
05-05-2021, 08:44 PM | #4 |
Rep 456
Thanks! I'll check out Jordan tuned. I'm sure stock they can run E40 without an issue. Everyone said the M5 couldn't do it too, i was ran up to E60, maybe E70 a few times without any issues. I don't plan on driving this car hard so supplying enough fuel shouldn't be an issue.
2018 BMW M5
05-05-2021, 11:46 PM | #6 |
Rep 6,297
Drives: 2018 340i M Sport
Garage List 2018 BMW 340i M Sport [8.58]
2020 BMW M340i xDrive [9.00] 2018 BMW 340i M Sport [7.38] 2006 BMW 330i Sport [5.83] 2004 BMW 330i ZHP [7.13] 2000 BMW 328i [6.17] |
There should be a label under the hood. If the car was originally sold in Cali itll be an N26.
www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ |
05-06-2021, 05:56 PM | #7 |
Big Turbo Boys N Girls
327
Rep 579
BootMod3 has E30 blend maps. So you can run E30. Just test your E85 with the test kit and add in enough to be under the E30 mark to stay safe. And PLEASE DATALOG your pulls when doing this to see how your engine is working and if you are having knock or timing issues... This is a sure fire way to blow the motor! Also I would not run e85 long term as the injectors at least pre 2016 were not meant for e85 use nor is the fuel pump and sediments will cause blockage.
TO run e85 you should get a flex fuel kit installed with a gauge to read the fuel content along with a proper fuel pump that can handle e85 without deterioration which causes injectors to get clogged. Also you are playing with fire on a N20/N26 with e85 as the rods will let go cause all the tunes put all the torque at the early part of the RPM range. 4 Bangers need to have a Progressive J curve when tuning to put the power at the top end after 4K to keep the motor otherwise with all the current tunes they cram it all at the 2 to 3K mark and rods bend. My car with the big turbo is nice and healthy with no issues on stock block as most of the Power is after 3800K. We track it and beat on it on the street.
2012 F30: G25-660 Bottom Mount Mani+ DP+ Intake, CSF FMIC, VRSF CP, Walbro 450 LPFP, PR Injection with AIC 4, S63TU Injectors, Tuned with BM3, ZF Race 4 Puck and Non SSA Pressure plate, Catless, 3.5" Quad Muffler, Custom Valved Bilstein B8 + H&R SS. Max 456 WHP - 452 WTRQ. Currently tuned down to 434 WHP and 362 WTRQ to save the rods.
VipinLJ1944.50 |
05-06-2021, 10:58 PM | #8 | |
Rep 456
I was doing the math on this all tonight and 87 octane from costco is actually cheaper than E85 because you lose ~30% mpg with E85. So I'm going to run E85 mixed with costco 87 octane at E20. E20 shouldn't be enough to cause any issues at all considering they're designed to run at least E10. And that mixture will get the octane up to ~90.
2018 BMW M5
05-07-2021, 12:11 PM | #9 |
Rep 261
Drives: 2017 320i xdrive
So I am also a bit confused here. I run a tuned N20 stg1 93oct with no hardware (yet).
I wanted to try out some E30 blend or something like that but I have no idea where to start. As far as I an aware you dont need any hardware for E30 right? Where do you buy this stuff? How do you put in the right amount? I probably sound like a noob because I am. |
