BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Turn off rear pdc when in D
      01-24-2021, 01:26 PM   #1
VeErik
Drives: BMW 320i 2014
Lightbulb Turn off rear pdc when in D
Hi all,
I got an aftermarket front and rear camera on my bmw 320i, f31 2014.
They are connected to my aftermarket carplay/android auto mmi unit from andream (other topics say it is the same as the bimmertech mmi unit, except the software)
They both work fine, but have the following question I want to code.
At the moment when putting my car in "R" the rear camera switches on. When putting it back in "D" I need to go a certain speed to switch to the front camera.
But for parallel parking I want it to switch immediatly if possible . (Or at a speed lower than 5kph, which is the minimum I can set in bimmercode)
Does anyone know how to program this with bimmercode? I assume it is in expert mode, but don't know where to search.
Thanks in advance.
      01-24-2021, 04:32 PM   #2
larrylarry
Maybe FDL code this
REM/PMA V_SCHWELLE_2 werte = FF werte = 0F The speed when it auto disables rear camera view (FF = 255 km/h)
Use your mirrors like a man?
      01-24-2021, 05:31 PM   #3
VeErik
I'm a noob in this coding.
I do can find the V_SCHWELLE_2 in bimmercode how do you know what it means? What does it set?
You say 0F and later FF, is this a certain speed, and if so FF = 225 KPH, 0F =?
Lol, yeah I could use my mirrors like a man. But I also like gadgets, so therefore I have em. And it's cheap if you install it yourself.
      01-24-2021, 05:34 PM   #4
VeErik
That V_SCHWELLE_2 is the camera I see when googling this. Any idea which one is the pdc? As the camera is talking with the mmi unit...it ain't OEM.
      01-24-2021, 06:06 PM   #5
larrylarry
I guess I'm confused. You want the front camera or the beeps/radar from the PDC? I uploaded a quick guide for what most people code that has been passed around here for a couple of years. Maybe a combination of vehicle in motion settings can get you want you want.
mahe0.00
      01-24-2021, 06:08 PM   #6
VeErik
I want the rear camera/rear pdc to be turned off as fast as possible when changed to D
      01-24-2021, 08:19 PM   #7
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
I'm curious why. I know that the speed and distance can be increased from default, but I don't think it can be decreased.
      01-25-2021, 03:49 AM   #8
VeErik
Why:
When I parallel park, and switch from R to D, I want to see the distance in front of me to the car in front.
If it doesn't switch to this front camera because I don't catch enough speed...which I never will atm...the camera actualy has no use. This is the main reason I got this camera for.
Maybe I have to program the bmw thinks I have a front camera?!? I would assume if you have a OEM camera it switches immediatly for the purpose I mentioned above?
Edit: just searched and found a youtube video the OEM switches immediatly.
      01-25-2021, 06:26 AM   #9
SerTan
SerTan's Avatar
24
Drives: BMW 320i M Sport F34
I have original iDrive and retrofit front and bk camera as soon as i change from R to D camera switches from back to front. Before camras fitted if i go from R to D screen would go to idrive what ever was on before R was engaded. And it happens instantly. Maybe you need to ask ppl u bought your android unit from for changing this or even from Developer mode in settings once unlocked. Settings, About, tap Build number/version 7 times. Look for any settings there.
But from bimmercode:
You right 5kpm for switch to happen or 10m distance is the min threshold.
      01-25-2021, 06:34 AM   #10
SerTan
SerTan's Avatar
24
Just to add i did not have to add any extra coding, plug and play again as you said my unit seems the same like you have.
Did you connect both positive wires from back and front to the wire that comes from aftermarket supplied harness? And make sure you plugged front to front and not to 360
      01-25-2021, 12:45 PM   #11
Billfitz
Billfitz's Avatar
Originally Posted by VeErik View Post
Why:
The reason I asked is that when my OEM rear camera is active my PDC sensors are active both front and rear. If I had a front camera I wouldn't need it anyway, I set my distance warning for a constant tone at 30 cm.
      01-25-2021, 02:58 PM   #12
VeErik
Originally Posted by larrylarry View Post
Maybe FDL code this
Tried 0F, did not work
      01-25-2021, 03:02 PM   #13
VeErik
Both correct video input.
The positive is not assigned for both cameras. 1 is specific for the rear cam. The other one is a "General" 12V+ from the mmi unit.
I think it is something in the unit itself...but cannot find it in the settings, might be in the developer settings if there are any...
      01-25-2021, 03:03 PM   #14
VeErik
Don't have front pdc...so that's why the camera
      01-27-2021, 08:04 AM   #15
Siki78
Something like this
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH
      01-31-2021, 09:26 AM   #16
VeErik
Originally Posted by Siki78 View Post
Something like this
That is exactly what I want. Immediatly switch to the front camera without any speed.
      02-02-2021, 05:21 AM   #17
Siki78
That mmi was from aliexpress and it is just for rear and front view camera. I think it is not coding it is because of mmi
pdc threshold speed distance
