12-01-2015, 08:14 PM | #1 |
Rep 1,407
Drives: 13' F30 328i 6MT
Instrument Cluster completely dead, Anyone experience this?
Hey all,
Parked my car, worked 9 hours and when I got back in the car to go home "13 F30 328i" my instrument cluster is completely blank. No illumination, No readings on the gauges and also all the miles per gallon and other readings that show up on the LCD screen are also reading ---- Anyone ever see anything like this? There is nothing on the forums for instrument cluster out etc.. Car runs fine but it sucked driving 30 miles home at night with no speedometer or gauges... Thinking it was a fuse I check all the cluster related fuses on the printed diagram "50,52,121,155" All are fine. After pulling and checking each fuse I start the car up and the cluster is fine, But I have a check engine light now which may have been self inflicted... Has anyone see this behavior before? Gonna whip out the ENET cable and laptop to see what code I have.. Thanks in advance guys!
'13 F30 328i Sport 6MT | '18 G01 X3 xDrive30i | '95 E36 325i Vert 5MT
92 Sentra SE-R SR20DET DET Build Thread 89 E30 325is [sold & missed] Last edited by QUiKSR20; 12-01-2015 at 10:18 PM.. |
12-04-2015, 01:58 PM | #3 | |
Rep 1,407
I did it had CODE P15FE
I scanned it with a generic scan tool and cleared the code, From what I read I really need to scan this with my laptop using E-SYS or Tool32. I found an N55 Fault Code Sheet and it says : ( I have an N20, should be same code ) The fault is recognized when no CAN time signal is transmitted for longer than 5 sec. Quote:
92 Sentra SE-R SR20DET DET Build Thread 89 E30 325is [sold & missed] Last edited by QUiKSR20; 12-05-2015 at 10:39 PM.. |
05-16-2016, 02:42 PM | #4 |
Rep 4
My cluster flashed blank and back on a few times last night on the freeway on my 16 340i with only 1800 miles. what the heck? this was the only thread i found after searching and searching.
07-05-2016, 05:13 PM | #6 |
Rep 2,290
07-05-2016, 05:19 PM | #7 |
Rep 5
07-05-2016, 05:48 PM | #8 |
Rep 4,449
Drives: '23 X1 28i xDrive
Next time it happens, take a video of it on your phone. You can show it to the SA if they say "We couldn't replicate the issue."
07-05-2016, 05:57 PM | #9 |
Rep 3,258
Drives: 2015 F36 Jet Black Sport Line
Hate those 5 words when you try and get something fixed^^....
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint| |
01-24-2021, 12:26 PM | #10 |
Rep 21
Hi all
Not sure if anyone will pick this up now (so will be starting my own thread too), but i have a similar problem with my F30 hybrid (2017) Went to start if today, engine fired up but dead cluster. I have checked the fuses stated by QUiKSR20 but still have the issue. I have codes - P110F (ambient air sensor), P15FE (Engine switch off time signal), and strange one, U119B (possibly ambient temp?) Wondering if anyone can advise more ? Thanks Guys |
01-04-2022, 06:48 PM | #11 |
not good, but bad
333
Rep 361
FWIW I just had this issue, car has been sitting for a while, got some messages in my car that said something along the lines of "battery draining while stopped"
Today went to take her for a drive and my instrument cluster was completely dead. Threw it on a battery charger and charged to full, then pulled fuses 50 & 52 under the hood. Put them back in and the instrument cluster came back.
They are spelled BRAKES not breaks!!!! Oh FFS, not another spark plug thread!
BreadsBMW on Youtube |
