06-16-2020, 03:50 PM | #221 | |
Rep 242
06-17-2020, 03:45 AM | #222 |
Rep 1,010
Come on mate, when your car was stock you would have dreamed for those numbers you almost have a 10 seconds 1/4 mile car that's seriously quick
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - Stock HPFP
-------- Tunes: Self Made Tunes - MHD ------ Fuel: 92RON/87OCT -------- |
06-17-2020, 03:57 AM | #223 | |
Rep 242
06-22-2020, 02:43 PM | #224 |
Rep 242
6th revision paul start increasing timing 12.5 now, there is still room for improvement
06-23-2020, 07:15 AM | #225 |
Rep 1,010
Your 1/4 mile time 11.16 is really impressive with your DA, that's M5/M8 Competition and AMG 63S territory.
But your 100-200 should be much better IMO.
06-26-2020, 05:34 AM | #226 |
Rep 1,010
My fellow drivers using MPH, can you please add 62-124 MPH in the Dragy custom measurements which is equivalent to 100-200 Km/h so we have equal comparison to all the cars. Thanks
Supr3me551.00 |
06-26-2020, 09:13 AM | #227 |
Rep 13
My result:
M240ix, Pure 800, Dorch stage2, xHp, Pureboost.de custom tuning per MHD, 25psi E40mix (98ron+ethanol), downpipe, AFE filter, Wagner charge air radiator, Fuel-it ethanol sensor, stock spark plugs with 0.45mm gap. Outside temperature 20°C |
06-26-2020, 02:12 PM | #228 |
Rep 684
Drives: Your mom crazy
Garage List 2020 BMW X3M CURRENT [0.00]
2016 BMW 340i BEAST [0.00] 2011 BMW 335i RIP [0.00] 2003 BMW 330i SOLD [0.00] |
Really solid time, gotta love that DA, too lol
2020 X3M
MG Flasher; Wedge Performance E50 tune MSS Urban; Rohana RFX11 |
06-26-2020, 02:45 PM | #229 |
Rep 1,367
Solid. That’s definitely well into the 10’s with the X-Drive. Any chance you can get a Dragy 1/4?
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ Pure 800 cast/ DS2/ E40 Doug Newton tuned/ ER catless DP/ Remus axle back/ BMS intake/ FTP CP/ M Performance LSD
06-26-2020, 06:27 PM | #230 |
Rep 164
06-27-2020, 05:30 AM | #231 |
Rep 13
06-28-2020, 12:34 PM | #232 |
Rep 684
OK just started playing with Dragy today and I'm embarrassed to post my times, not sure if I'm doing something wrong lol.
When doing a 60-130 run how are you typically rolling into it? I'm xDrive 8AT, so I was starting my run rolling around 40 mph and then mashing in Sport Drive, DSC active. I also did a 0-130 run. Neither one has any times worth discussing. On an important separate note, I think my brakes are Definitely my next maintenance item lol
2020 X3M
06-28-2020, 01:30 PM | #233 |
Rep 3,179
I'd suggest being in 4th gear and go WOT at 3k rpms. I think 60mph is right around 4k rpms in 4th so gives time to spool up/torque hit. However if the pure turbo is laggy starting in 3rd at 4500rpms might be better.
Supr3me551.00 |
06-28-2020, 02:06 PM | #234 |
Rep 1,010
I suggest Manual mode Sport+ starting at 50 mph in 3rd gear and shifting at 6500 RPM and also try another run starting in 4th gear some tunes do better starting in 4th gear.
Normally 60-130 mph is slower than 100-200 km/h, I suggest adding 62-124 mph in the Dragy custom measurement along side 60-130 mph.
-------- Tunes: Self Made Tunes - MHD ------ Fuel: 92RON/87OCT -------- Last edited by IMS-340C; 06-28-2020 at 02:56 PM.. |
06-28-2020, 02:32 PM | #235 | |
Rep 242
06-28-2020, 05:19 PM | #236 |
Rep 1,367
I know this is 100-200, but I'll throw in my 1/8th time on Dragy from a couple nights ago.
7.82 @ 96.28 mph on a pathetic 2.09 sixty. (77 degrees, 568' @ 3,080 DA) Car is making decent power but 0-60 is slower now with the Dorch pump and custom E40 tune. Comparing this to my quickest 1/4 at the track last fall, that 11.88 @ 117.92 showed a 7.72 @ 93.79, but on a semi decent 1.91 sixty. DA was much better as well. If I can get back to the track in decent air and cut low 1.90's I should be running 11.50's @ 122-123. BTW, how do I set Dragy for 62-124 mph? I want to try this. Guessing I'm around 7.8
06-28-2020, 08:03 PM | #237 | |
Rep 242
06-28-2020, 08:21 PM | #238 |
Rep 1,367
No, rear wheel.
06-29-2020, 03:15 AM | #239 |
Rep 1,010
Dragy Custom Mode Settings
Guys, B58togo, here's how you add a custom speed or distance measurement in the Dragy.
- Connect to the Dragy. - Before making any run tap the "+" sign like shown in the picture. - It will take you to the screen where you can add multiple custom speed or distance measurements. I highly recommend the guys using mph to add 62-124 mph to the Dragy Custom mode as the difference between 100-200 Km/h and 60-130 mph is big. Cars running 100-200 Km/h in 7.5 seconds will run 60-130 mph in 8.7-9 seconds.
-------- Tunes: Self Made Tunes - MHD ------ Fuel: 92RON/87OCT -------- Last edited by IMS-340C; 06-29-2020 at 05:15 AM.. |
B58togo805.50 |
06-29-2020, 08:35 AM | #240 |
Rep 684
OK, here they are lol
2020 X3M
06-29-2020, 08:54 AM | #241 |
Rep 242
06-29-2020, 08:59 AM | #242 |
Rep 1,010
That doesn't make sense, 22 PSI and 15 degrees timing does not equal 8.4 100-200 Km/h.
Return the Dragy again
Supr3me551.00 |
