09-01-2020, 09:01 PM | #1 |
Rep 201
Not a ton posted on this piece so here we go!
Over the last several months I have gone back and forth between catless, catted, bracket, no bracket, etc. Finally decided that I did not want to risk the smell of catless, and also didn't love the idea of being environmentally unfriendedly- 19 mpg city is enough for me! Found this CTS Turbo 200 cell catted unit for $329 from MAPerformance. It took a couple of weeks to ship (they stated 3-4) and finally arrived today.$329 is as cheap as I have found for a catted pipe from reputable brand, let us know if you have done better! Looks great so far and the flex joint has some give. Am excited to get it installed! [IMG]undefined[/IMG] |
09-01-2020, 09:07 PM | #2 |
Rep 180
CTS is a great brand in my opinion. I got their catless downpipe and charge pipe. Fit and finish are spot on, and great pricing too.
AFE Filter | BMS Intake Pipe
CTS DP | CTS CP | CTS Heat Exchanger PTP Turbo Blanket | AEM WMI Kit | Custom Exhaust PJ ACN91 + Meth tune| XHP Stage 3 |
09-01-2020, 11:13 PM | #3 | |
Rep 1,454
2022 CT4-V Blackwing 6-speed
09-02-2020, 07:21 AM | #4 | |
Rep 201
I will see how long I can go before I get a CEL, but I run bm3 anyway. |
G.Newt810.00 |
09-02-2020, 11:06 AM | #5 |
Rep 190,804
Congrats
09-25-2020, 11:50 AM | #6 | |
Rep 13
Have you installed it? Any CEL so far? I was thinking about adding a Wagner O2 sensor eliminator but I don't know if it could keep me clear from CEL. |
09-25-2020, 04:49 PM | #7 |
Rep 558
For anyone that has actually installed this DP:
How was the fit? Plug & play? How is the sound? Deep & throaty, or tin can full of nails? Thanks!
My 2017 M240i: MHD, xHP, Modded OE Intake, AA GESi 400 CPSI Cat DP, Dinan Mid-pipe, M Performance LSD & Rear Diffuser, BMS Exhaust Tips, Apex EC-7 Wheels, M-Tech Front Lip, iND Painted Mirror Caps, Smoked Reflectors
09-26-2020, 03:45 PM | #8 |
Rep 558
Well, I hope it sounds good, 'cause I just bought it. LOL!
09-29-2020, 10:14 AM | #9 |
Rep 190,804
plug and play sound really nice and you get the same power increase as the catless. Unless you have a flash tune, you will get a CEL
09-29-2020, 06:48 PM | #10 | |
Rep 558
I'm still debating whether or not to use an elbow on the 2nd O2 sensor to avoid the CEL, because I'm concerned that using an elbow might mess up AFR. I haven't seen any definitive answer regarding that.
09-30-2020, 06:27 AM | #11 | |
Rep 519
2017 340i M Sport Alpine White / Coral
Dorch Stg2, CTS catless, xHP, Custom E50 Tuned by Shoup |
09-30-2020, 07:20 AM | #12 | |
Rep 558
Are you saying that a flash tune would prevent or suppress it? That was not my understanding.
09-30-2020, 09:05 AM | #13 |
Rep 519
yes the flash tune will keep it off for good, you wont need to clear it or anything
09-30-2020, 10:14 AM | #14 |
Rep 558
Ah, I did not know that. Thanks for sharing that info. Is there anything I'll need to do in the MHD OTS map settings to achieve this, or does the software just ignore this code and not throw a CEL?
09-30-2020, 10:25 AM | #15 |
Rep 519
Just click the catless option when flashing, dont need to do anything else
09-30-2020, 10:56 AM | #16 |
Rep 558
Cool, thanks. No issues with that setting if using a catted (200 cel) downpipe, like the CTS Turbo?
09-30-2020, 11:45 AM | #17 |
Rep 519
I would suggest buying a higher end catted one (like AA, fabspeed, HJS) if that's the route you're going for as there's a reason they're priced higher. They use higher end metals that actually do their job and wont prematurely fail
09-30-2020, 12:24 PM | #18 |
Rep 558
Thanks for the info. But, too late now because I already bought the CTS DP. So, fingers crossed that it works out OK...
09-30-2020, 08:01 PM | #19 |
Rep 558
So, since my plan is to use the CTS Turbo 200 cell 'sport' cat downpipe with the MHD stage 2, 93 octane map, I emailed MHD.
My questions and their answers are below: Q: Would that "catless" setting in the flash tune suppress the CEL? A: that setting will suppress catalytic convertor effectiveness codes Q: Would the AFR be correctly maintained? A: AFR will be maintained correctly Q: Would that setting cause any problems with, or damage to, the 200 cell sport cat in the CTS Turbo downpipe? A: no it will not, it only affects codes I hope this helps anyone considering using a 200 cell 'sport' cat and an MHD flash tune.
09-30-2020, 08:49 PM | #20 | |
Rep 314
'16 340i M-Sport F30 Estoril blue, Oyster, Bootmod3, CTS high flow cat, CTS intake
Sold:'07 335i E90 Montego Blue on black leather, Navi, premium, sirius, sport pkg, CA, logic7 Sold: '07 328i E92, SG, Saddle Brown, Gray Poplar, ZSP, CA, Heated Seats, BMW Performance Exhaust, BMW performance SSK, Valentine1, european delivery - Military Sales |
10-01-2020, 09:06 AM | #21 | |
Rep 519
10-01-2020, 11:25 AM | #22 | |
Rep 558
I plan to leave the burble settings the same as stock. I figured that should be ok. Are you recommending that, or turning off burbles completely?
