03-07-2020, 11:26 PM | #1 |
as long as it runs :)
40
Rep 164
My nav system is really messed up
I was driving home and I used the sat nav on my 2013 328i with the cic high nav. And on the screen by the gauges it wouldn't display street names. Instead it just gave me this random letters/numbers, but the nav Still Gave me proper directions and the turn by turn was good.
03-08-2020, 12:55 PM | #3 | |
40
Rep 164
I coded, soft on led headlights Soft on iconic lights Video in motion Auto stop start off Sport + mode w launch control Door unlock on power off Cornering lights Idrive on until drivers door open Mph on instrument cluster Video in motion Fog lights and high beams can be on together Rear fog lamps Speed limiter function on cruise control Eco pro mode by default I drive warning off And some other small things I forget. It was all done on BimmerCode |
03-08-2020, 04:38 PM | #4 | ||
Rep 10,473
03-08-2020, 08:24 PM | #5 | |||
40
Rep 164
03-08-2020, 08:59 PM | #6 | ||||
Rep 10,473
03-09-2020, 01:19 AM | #7 | |||||
40
Rep 164
03-09-2020, 01:25 AM | #8 | ||||||
Rep 10,473
03-09-2020, 07:02 AM | #9 |
Rep 2,808
Drives: F33 430 and F39 M35i
Can you restore from a bimmercode backup and start over doing one thing at a time?
03-09-2020, 08:33 AM | #10 |
40
Rep 164
03-09-2020, 08:34 AM | #11 | |||||||
40
Rep 164
03-09-2020, 08:36 AM | #12 | ||||||||
Rep 10,473
03-09-2020, 08:52 AM | #13 | |||||||||
40
Rep 164
03-09-2020, 11:06 AM | #14 | ||||||||||
Rep 10,473
Around $300 would be normal. |
03-09-2020, 03:13 PM | #15 |
Rep 34
Wait a minute
There's an option in esys to code the defaults to your modules considering the VO (FA) you have on your car. This is how I coded the enhanced bluetooth. Changed the VO temporarily without writing it back to the car, and then I loaded the defaults. Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Right-Click on the proper ECU which you modded => Select CODE (Not Code FDL). Repeat this Step for all affected ECUs in order to put it back to the state when you bought the car. Then you can re-try coding the stuff |
03-09-2020, 04:00 PM | #16 | |
Rep 10,473
He'll kill his car on the complicated stuff with esys. Take it to a Dealer. |
steve@codemybimmer664.50 |
03-09-2020, 04:19 PM | #17 |
Rep 34
not really if he follows the exactly described mouse-clicks like I said.
But yeah, probably better taking it to a dealer. You can mess really bad with esys if you try out buttons just for fun |
03-09-2020, 07:27 PM | #18 |
40
Rep 164
Its not that I messed up with BimmerCode, I am well versed in code, it's just that my car has the 2013 nav software and ever since I coded it then drove it in a newly built neighborhood the car hasn't been showing names on the gps. It works, just no names. Regardless of where I am new or old streets
03-09-2020, 11:13 PM | #19 | |
40
Rep 164
03-11-2020, 12:14 PM | #20 |
Rep 34
Nice.
How much $ did you have to pay for that service? Offtopic: Here in Germany, that would probably cost about 600 EUR, and most probably no dealer would touch your car if you coded somethign on it. I had hella problems with BJMW (was even escalated to Munich' central) because they made shitloads of accusions what everythign I have damaged with my coding stuff (which wasn#t the case, as i did my coding clean and flawless). Sucks to have a BMW in Germany! |
03-18-2020, 04:05 PM | #21 | |
Rep 12
03-23-2020, 08:52 AM | #22 | ||
Rep 10,473
