06-14-2017, 08:36 AM | #89 |
Rep 103
Thank you, i will give it a try. My car is scheduled for an appointment in service next week. Not sure if i should try before that (itching ) or after that, just in case
06-19-2017, 04:40 PM | #90 | |
Rep 512
Drives: 2020 Z4 M4Misano Blue
It's obviously not very important that the tile show the right car, but it's a small annoyance.
2004 E85 Z4 3.0 Sport - Sold to brother | 2004 E83 X3 xDrive3.0i - Gone | 2011 E89 Z4 35is - Gone | 2011 F25 X3 xDrive35i - Gone | 2014 E89 Z4 E89 35is - Gone | 2014 F25 X3 xDrive 30i X3 - Gone | 2017 F83 M4 Cabriolet - Gone | 2017 F25 X3 xDrive30i - Gone
2020 G29 Z4 M40i Misanoblau | 2020 G01 M40i Phytonicblau Casa Suzana, vacation rental villa in Cozumel, Mexico |
06-19-2017, 07:37 PM | #91 |
Rep 8,364
06-20-2017, 03:32 AM | #92 |
electrified
32
Rep 127
06-20-2017, 12:55 PM | #93 |
Rep 8,364
06-20-2017, 01:23 PM | #94 |
Rep 1,976
Drives: 2020 G20 320i M Sport
I'm on 61.4 and the picture still did not update to a 2 series. I can confirm that X5 works and that's about it.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
06-20-2017, 01:26 PM | #95 | |
Rep 8,364
EDIT: F030 Pictured View post on imgur.com Last edited by Almaretto; 06-20-2017 at 05:14 PM.. |
steve@codemybimmer664.50 |
06-24-2017, 05:50 PM | #96 | |
Rep 308
07-13-2017, 08:40 AM | #97 |
Rep 512
Are you saying those are the only images present in the firmware or that those are the only ones you've confirmed?
I need to figure out a way to get my dealer to do an update. They seem really not to like to do them. I do often get Bluetooth connections dropped or switched weirdly and they spent hours fiddling with that, but wouldn't consider doing an update.
07-13-2017, 10:09 AM | #98 | |
Rep 8,364
Correct. Dealers will only update if paid for time either directly from customer or through BMW warranty by documenting fault. |
11-23-2017, 11:37 AM | #99 |
Rep 216
Drives: F30 335i PWG
sorry to resurrect and old thread but I have a question, I was wondering is it possible to code ID6 lite to 02/2017 production ID5 car? is it just a matter of changing Fdl codes in esys?
11-23-2017, 12:05 PM | #100 |
Rep 8,364
11-23-2017, 10:06 PM | #101 | |
Rep 216
2013 335i BSM ~ Stage 3 turbo, forged internals and more check out my build thread https://f30.bimmerpost.com/forums/sh...7#post23789807
11-24-2017, 12:44 AM | #102 |
Rep 8,364
03-26-2018, 09:03 AM | #103 |
Rep 10
My F31 from 2013, I think that it commes with iD4 (HU_NBT). I there a way to upgrade the idrive to ID5 or ID6_light (lite)?
In BimmerCode expert mode I don't have: HMI_ID_VERSION. |
03-26-2018, 06:46 PM | #104 |
Rep 8,364
03-27-2018, 10:56 AM | #105 | |
Rep 342
If your unit is ID B140 or B143, then it only has 2GB, but if it is B209 or B240 it has 4GB, and can be flashed to ID5, and not suffer reboots.
I keep getting robbed because I leave the front door open..
I could close it but I feel doing so would be a victory for the thieves.... |
MHL13.00 |
03-27-2018, 01:35 PM | #106 | |
Rep 65
03-28-2018, 01:55 PM | #107 |
Rep 342
You don't need to remove it, but you need remove the panel to look at the label on the front of the headunit. Look at the first 4 digits of the serial number, if it's B14x it's 2GB, if it's B21X it's 4GB. There should also be another number below for hardware version if it's HW:2.x it's 2GB for 4GB it should be HW:3.x
MHL13.00 bytejunkie158.50 |
03-31-2018, 02:14 AM | #108 | |
Rep 65
04-13-2018, 04:08 PM | #109 |
Rep 342
On a 2015 G11 7 series that came with iDrive 5 + touchscreen + gesture control what would be the correct setting to change to iDrive 6 UI, the id6_light or the id6_full?
Just to be curious. On a car the today leaves factory (2018)....it still has the same hardware as the 2015 G11.... and the only change is that from factory the HMI_ID_version says id6 by default instead of id5 (or whatsoever) that come on my 2015’s? Or also the the HMI_version says id6? Thank you! |
07-17-2018, 08:11 AM | #110 | |
Rep 23
