07-19-2018, 06:59 PM | #1 |
Rep 234
Headlight on in bright conditions???
I was out this evening when the sun was about an hour or so form setting. It was darn bright out! Car is switched to automatic headlights and daytime lights selected on in settings. I could not believe the headlights were on all the time. Fog lights switched off. I looked up the below pg 87 in the on-line manual.....I suppose this is what they are talking about. I guess there is no sensitively control!
Automatic headlamp control Switch position (automatic headlights) the low beams are switched on and off automatically, e.g., in tunnels, in twilight or if there is precipitation. The indicator lamp in the instrument cluster lights up. A blue sky with the sun low on the horizon can cause the lights to be switched on. The low beams always stay on when the fog lamps are switched on.
2015 Mineral White 335xi Sport trim
07-19-2018, 09:19 PM | #3 |
¯\_(ツ)_/¯
537
Rep 1,000
I mean most states have a law that your headlights must be on when visibility is low, the sun being in that position causes low visibility, so it's not a bad thing
07-20-2018, 07:22 AM | #4 |
Rep 16,054
I agree with the OP that the sensitivity is too high. My lights come on a good half hour or more earlier than they should IMO with respect to how dark it is. They also seem to respond more to the position of the sun in the sky than the actual ambient light level, as they don't come on prematurely when the sun is high but the sky is overcast. There's no statutory reason for the headlights to come on unless you actually need them to see, as the DRLs allow others to see you. It doesn't bother me enough to have taken the time to code them to reduced sensitivity, but I can see how having the lights come on for no good reason can be irritating.
07-20-2018, 07:47 AM | #5 |
Rep 234
Ok..... How do we code them???? If my Subaru automatic lights work ideally (and provide easy owner adjustment), why can't BMW?
07-20-2018, 10:09 AM | #6 |
Rep 16,054
07-20-2018, 10:56 AM | #7 | |
Rep 234
Thanks for the link...
07-20-2018, 12:49 PM | #8 |
Rep 2,499
When it's overcast, it's actually much brighter than you think. Anyway, as far as I remember, it's either the law (or just good practice) to have your headlights on 30 minutes before sunset and after sunrise, regardless of how bright it is. I'm not sure why it's a big deal to have your headlights on though?
