05-20-2021, 03:58 PM | #1 |
Rep 24
I screwed up. Piston dust boot seal ripped. Please help!
Hey everyone
I have a 2015 335i with 54k miles. My front brake pads and rotors were due. I decided to do them myself since there are many videos on YouTube. I thought While I will be there half way, might as well paint the calipers red. While cleaning the calipers to paint, I accidentally ripped the rubber dust boot seal on the caliper piston. The dust boot is there to prevent dust and water and other particles to get in to the piston. Otherwise, the piston could rust and cease and cause more damage to the whole brake system. I searched online and from my understanding, boot seal on the piston can be replaced and should be replaced if it’s damaged. I don’t want to take this job to my self since I already done enough damage. I called around at least 8 shops in NYC, all recommended changing the whole caliper. Now I either get a new caliper and get it installed or get the boot replaced. I even ordered new genuine BMW boot seals specifically for my car from FCP euro but no shop is willing to install it for me. What do you guys recommend? New caliper or replace boot seal? Is there any shop in NYC that can take this job? Any Car enthusiast out there that can help me install it? Willing to pay. Getting a new caliper is too expensive but if that’s the only option then I will let it go for few more months and get it replaced later when I have enough money. Or is this very serious and needs to be replaced right away? Any recommendations or suggestions is appreciated. Thanks for your help in advance. 🙏 |
05-20-2021, 04:24 PM | #2 |
Rep 440
Drives: 2013 335i xDrive
It's best to replace the boot. Look at it this way - the boot kit is cheap, the caliper/installation can be pricey. If you can replace the boot yourself, great. If the replacement does not go well, you still have the option of caliper replacement.
There may be some caliper rebuild videos online, watching somebody else put boots on calipers may be helpful. Youtube is your friend.
I'm not completely useless, I can be used as a bad example.
05-20-2021, 05:02 PM | #3 |
Rep 24
Thanks for your suggestion. I already got the boot kit. I do want to save some money by just replacing the dust boot. I don’t want to do it myself. If I can’t replace the boot and have the whole caliper apart, then I’m stuck with a job half done in my parents driveway. Any shop in the NYC 5 boroughs you can suggest?
Thanks in advance. |
05-26-2021, 08:59 PM | #4 |
Rep 8
No shop is going to want to take on replacing a dust boot. There's more labor and liability if something is installed correctly when they replace just a boot. Faster and more reliable repair in their eyes.
Check out this series by Keis Motorsports. Should give you an idea for what you need to do. |
johnung4526.50 |
06-04-2021, 07:55 PM | #5 |
Rep 24
Hey thanks for the your reply.
I have watched this video and thought of doing it myself. But I don’t have a air compressor. I don’t even have half of the tools that Brian have. I’ve never worked on a car before. Now that I have damaged my dust boot, my confidence level is really low to to take the caliper apart. As I mentioned above, if I don’t get it fixed while I have the car parked in my parents driveway, then I’m stuck with the only car I have in a driveway that I can’t even take to workshop. Now I need a tow truck and spend even more. I hope this makes sense why I don’t want to do it myself. Anyway, Thanks for your suggestion. |
06-04-2021, 07:58 PM | #6 | |
Rep 867
johnung4526.50 |
06-04-2021, 11:16 PM | #7 | |
Rep 24
I’m not challenging your comment, I’m just trying to understand why are they so scared to do it? Also, someone commented that the labor is too much along with liability. Sorry for my naive/rookie questions. |
06-05-2021, 10:03 AM | #8 | ||
Rep 867
06-05-2021, 07:26 PM | #9 | |
Rep 24
Also, Can you take care of this for me? I can drive to you. Willing to pay. |
06-05-2021, 09:54 PM | #10 |
Rep 1,934
Buy a compressor form harborfreight for $100 and return it when you are done. You only need the piston to come out about a half inch. The you can remove the old boot and press on the new without a full disassembly.
The inner diameter of the boot fits in the ridge on the upper portion of the caliper piston. The outer diameter of the boot is just press fit into the caliper surrounding the piston cavity. It's dead simple.
06-06-2021, 12:19 AM | #11 | ||
Rep 5,392
Underneath the dust cap is the actual piston with a piston seal wrapped around it. It's this piston seal that is more difficult and requires an air compressor to get the piston out. |
