06-14-2021, 12:07 PM | #419 |
1296
Rep 3,532
it is not. it was just used as an example.
I can't get anywhere near those numbers and I still have a stock turbo or I'll start spinning the tires before I even launch.
06-14-2021, 01:52 PM | #420 |
Rep 462
06-14-2021, 02:29 PM | #421 | |
1296
Rep 3,532
yes
06-14-2021, 02:59 PM | #423 | |
Rep 18
06-14-2021, 03:58 PM | #424 |
Rep 818
Drives: 2021 BMW X3 M
Has anyone had any issues with the transmission slipping or anything like that after XHP flash? That's my only worry since this is my daily driver.
2014 BMW 335i M-Sport - SOLD
2020 BMW M340i - SOLD 2021 BMW X3M |
06-14-2021, 05:05 PM | #425 |
1296
Rep 3,532
it does but when you change those settings it allows.for.more boost to be built etc.. eventually the power will over power the brakes and tires.
06-14-2021, 05:15 PM | #426 | ||
1296
Rep 3,532
06-15-2021, 08:29 AM | #427 | |
Rep 18
When DSC is completely off the transmission shifts in its most aggressive setting, especially stage 3 flashed. |
06-18-2021, 05:03 PM | #428 |
Rep 818
I went ahead and bought the XHP flash. Mannn this thing is amazing!!! Shifts sooo fast but it's smoother than factory. No hard kicks between shifts. Throttle response is way better in D or S since it goes into the correct gear instantly. 10/10 worth it.
06-20-2021, 09:15 PM | #429 |
Rep 36
Question about going from Stage 2 to Stage 3.
Have been running Stage 2 for about 5 months and looking for a change. When I flash over Stage 2 with Stage 3... Should I still be doing the same break in I did when I initially flashed from stock to Stage 2? I don't need to flash back to stock and then Stage 3 correct? |
06-20-2021, 10:30 PM | #430 | |
Rep 18
06-20-2021, 10:40 PM | #431 |
Rep 36
Let's say I did want to reset the process (start fresh with XHP learning my driving again) after flashing Stage 3.... how would I go about doing so?
06-20-2021, 10:41 PM | #432 | |
Rep 18
06-21-2021, 07:25 AM | #433 | ||
1296
Rep 3,532
06-21-2021, 07:41 AM | #434 | |||
Rep 18
06-21-2021, 08:06 AM | #435 | ||||
1296
Rep 3,532
second, xhp even says so... trans adaptions are for clutch wear etc. it learns slippage and such. resetting it makes it think it has a new or rebuilt trans and can be very bad for the transmission. absolutely do not reset trans adaptions unless you have a new or.rebuilt transmission.
06-21-2021, 08:31 AM | #436 | |||||
Rep 18
06-21-2021, 08:46 AM | #437 | ||||||
1296
Rep 3,532
06-21-2021, 12:52 PM | #438 | |
Rep 7,597
You don't need to redo the "learning" / adaptation when you first install XHP when you just change stage. Also, this is a continuous process, so its not like the car only adapts to what you do the first ~50 miles after. Just keep driving and the car keeps learning. You can think of it like your distance to empty estimates. If you drive hard for 20 miles then start driving on the freeway in eco mode, you can actually see your DTE increase (add miles) even though you are using gas. It's just a rolling average. |
09-16-2021, 09:07 PM | #439 |
Rep 965
Drives: 2016 F36 435x MSport
Interesting... Anyone play with the latest shift map options? You can now select from presets for both D and S from relaxive+ to neutral to sportive+.
09-16-2021, 11:14 PM | #440 |
Rep 7,597
Someone just posted about it in the other XHP thread, but no reports yet of how it works. I am also curious so let me know if you do.
